Car mpg lies
Discussion in 'Gen 4 Prius Fuel Economy' started by Buggs1a, Sep 13, 2025.
  1. Buggs1a
    Buggs1a Junior Member
    112
    So ok. The car shows over 61 avg mpg for me. That’s a lie I just realized. Toyota should be punished for lying. We rely on that info. It says your ODO. Is that a lie too? How do we know? Mpg is lying. So why not odo too? It says how many miles I’ve gone on my trip meter. Is that lying too?
    right now im at half tank. I’ve gone 310 miles so far. Mpg shows 61.x. I forget the x. So this makes sense though. At half tank. 310 miles. But hmm.
    I’m confused. But I know the avg mpg isn’t accurate. I got over 60 mpg it always shows. But never 600 miles on my tank. At most 525 or so from full to right when the gas light came on. Then I went 15 miles or 20 to fill up. This was about 525 miles.
    I prefer to fill it when gas is at the last line before the min. That gets me 440 miles or so.
    I don’t have the mindset tho to manually figure this out. No biggy to be that accurate. Not manually. But dang it the car should not lie.
  2. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    Dang, wait until you find out why the speedometer reads high... :rolleyes:
    PrimeDan and bisco like this.
  3. Mendel Leisk
    41,826
    1. If it’s similar to gen 3, multiplying the displayed mpg by 0.93 should be close. (It’s 7% optimistic)
    2. speedometers tend to show slightly higher than true speed, a mostly vain attempt to get drivers to slow down.
    3. odometer will VERY likely be accurate, reasonably so.
  4. bisco
    52,286
    wait until you have a warranty claim after the car hits the end of warranty mileage, only to find out that toyota math is off, and you are really under the mileage. dealer will laugh at you
  5. Mendel Leisk
    41,826
    AFAIK the car knows (and displays) the odometer value very accurately (assuming owner sticks with stock tire sizes). It fudges high on the speedometer for various, commendable reasons, and fudges high on the mpg, for more questionable reasons. From reports here, with Gen 5 it's given up on the mpg exaggeration.
  6. Buggs1a
    112
    I don’t like the car lying about mpg. I only know it’s lying but not the real amount. I don’t care enough to manually figure it out.
    my 2013 cmax sel was good. It showed good info.
    My Prius is getting better mpg I’m sure. Even if it is lying to me.
  7. bisco
    52,286
    nobody likes a liar
  8. John Ross
    John Ross New Member
    Del Mar,CA
    2021 Prius
    What does AFAIK mean? Thanks, John Ross
  9. rjparker
    10,412
    6,521
    Google is your friend
  10. fuzzy1
    10,588
    In the U.S., many odometers are now biased slightly low, ever since some product liability lawyers drew class action lawsuit settlements alleging warranty fraud for defective odometers, reading too high. All four cars I've purchased this century -- 3 Toyotas and 1 Subaru -- exhibit this odometer bias, in the 0.5 - 1.5% range.
    My last two 20th Century cars -- a Honda and a Subaru -- were class members on such lawsuits. Neither of mine exhibited this alleged defect, at least down to the 0.2% level. But both companies settled for 2% warranty extensions.
    To calibrate your own odometer, try to compare its distance readings against a GPS, or against a very long stretch of highway milepost markers. But do remember that highway milepost series can exhibit survey discontinuities, especially were existing roads are re-routed by improvements. Some of these are explicitly marked (e.g. special mileposts reading XXX.yy Ahead, XXX.zz Behind), some are not. And individual mileposts can be offset from their correct positions by mounting obstacles. Watching many mileposts along a route comparing each to the odometer, can pinpoint these anomalies.
  11. fuzzy1
    10,588
    How do you determine "half tank"? The fuel gauge commonly lies, for a variety of reasons, so is not an accurate measure of gallons used. A significant portion of tank capacity is set aside as safety margin and not shown on the fuel gauge, but is still used in the EPA's fuel range estimate.
    Have you computed your MPG by dividing distance driven between fillups, by the fuel added, as shown on the fuel pump? This is the only reasonable way for consumers to determine MPG. Beware that fillup levels can be inconsistent, so you may need to average multiple consecutive tanks to reduce this error element.
    If you are treating the low fuel warning lights as the "empty" mark, note that there are several more gallons left in the tank. The Owners Manual gives an estimate for how much, my cars have had a bit more than that. One member here drove his cars to fuel starvation numerous times, for a variety of tests and engineering curiosities, and his 2010 Prius went 130-ish miles beyond the low fuel warning light. I never took Prius more than about 65 miles past that light, and still had a full gallon left, based on the refill amount. (I have since driven another brand car to intentional fuel starvation, well beyond the low fuel warnings, and found its claimed fuel tank capacity to be accurate.)
    If you are getting EPA MPGs, then the only way to get the full EPA fuel range is to keep going until the car runs out of fuel and quits. Most people find this to be very highly inconvenient, so leave a respectable safety margin. Because most drivers don't fully understand just how highly variable MPG is under varying conditions, and are also very poor with mental math, most car makers start flashing the low fuel warnings with plenty of margin remaining, to minimize angry customers calling to complain that their gauge showed enough fuel for a trip segment, but then ran out of gas and left them stranded on a dark and stormy night in the mountains with no cell phone service, causing a huge inconvenience.
    If you aren't computing MPG by dividing distance driven by gallons added when refilling, then you don't know your real MPG.
  12. fuzzy1
    10,588
    Then you are doomed to not fully understand what is really happening.
    If averse to the calculations, then try this:
    1) What is the rated capacity of the fuel tank?
    2) How much gas are you putting in when refilling? The full rated capacity, or less?
    The difference is the amount of the available fuel tank that you are not using. But getting the EPA range requires using the whole tank, with the engine quitting from fuel starvation, unless you manage to get better-than-EPA MPG.
  13. Templeton
    Templeton Active Member
    321
    114
    usa
    2024 Prius Prime
    SE
    I am all on board with saying that car companies should not lie.
    But how in the world do you "know" that the computer's mpg numbers are a lie unless you manually do the math to find out what the true mpg actually is??
  14. Buggs1a
    112
    Because I’m not getting the stated mpg. Not even close. The car shows over 60 mpg. I’m not even close to that. I don’t go 600 miles on a tank. Not even close. I wish.
    So ok. My car. 11.3 gal tank. 11.1 maybe.
    I filled it up at the fuel light on. This was the gas tank light lights up when very low fuel. I put in 9-10 gallon maybe. Maybe 8.6 or so. Ugh. Don’t remember. I had gone 515 miles. So ok. Maybe it is a bit more accurate than I thought.
    however others here have said it’s not accurate and maybe 7% high.
    I’m just confused. I can make a note tho. How many gallon I put in. Then how many miles I went and how many i put in again. I can note this.
    I like to fill up at the second line to the right. You have the left most line. Then the fuel light comes on. I like to fill it at the next line. So the first one after the left most line. I don’t know what this is but I think of it as a good spot to fill up. That’s 8.5 gallon to full I think. And I am 400 plus miles here. Don’t remember exactly.
    #14 Buggs1a, Oct 18, 2025
  15. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    The "size" of the tank does not really matter, what matters is its capacity in terms of usable fuel because every fuel tank has some amount of unusable fuel.
  16. Buggs1a
    112
    So when I gas up. Note how many miles I went. Then note how many gallons i put in. Then same thing next time? That gives mpg?
  17. Mendel Leisk
    41,826
    With a bit of math. Say you went 400 miles, and it took 8 gallons. You divide the 400 by 8, that’s your miles per gallon.
    with our third gen, every time the car is shut down, the dash displays just the odometer, for about 30 seconds. No matter what the car displays when it’s on.
    Hopefully gen 4 is similar. If you write down that number at every fillup, and subtract the previous reading from the latest, that’s your miles travelled. It’s good to also reset the trip meter, for a cross check, but that odometer reading is safest, can’t be reset.
  18. Buggs1a
    112
    Yes. I always reset trip a. Trip n is since I bought it. To know how many miles Ive put on it.
    bisco and Mendel Leisk like this.
  19. bisco
    52,286
    that's the best way to do it. then you can use the info for a long term average
  20. fuzzy1
    10,588
    515 miles divided by 8.6 gallons equals 59.88 MPG. If the display showed 60, then it would be more accurate than normal.
    That is what some members have reported for at least Gen3 Prius, but it varies between cars and drivers and conditions.
    Recording those details is essential to figuring out your car's display accuracy.
    Just don't try to get the EPA's estimated range unless you enjoy, or can afford, the risk of running out and possibly getting stranded.
