Submerged MAP sensor, replace?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by logbiter, Oct 19, 2025 at 6:31 PM.
  1. logbiter
    logbiter Junior Member
    Lafayette, LA
    So, new to me V w/ ~153k miles. Since I’m furloughed right now, tackling cleaning the EGR & manifold.
    I missed taking off the exhaust manifold MAP sensor (oops! I was still kinda numb after the hassles of removing the EGR cooler ) and it was submerged in degreaser solution for a few hours. Should I replace it??
    Also going to change the plugs, replace water pump, both coolants (seems to have been done around 100k) & tranny fluid.
    I wasn’t sure about the inverter water pump… my ‘05s went out ~170k miles, a year ago. It gave me plenty of warning, so I’m not stressing it right now. Also plan to do a brake bleed. Some brake work was done ~30k miles ago according to carfax. Aside from regular oil changes and rear hubs done recently, carfax doesn’t show any of the work I’m doing.
    thanks!!!
  2. ChapmanF
    17,861
    Do you have a scan tool that can show the MAP reading?
    Does it match your local weather station's barometer reading when the engine is off, and go down to something near 4 kPa when the engine is idling?
    If so, it'd seem to be still doing its job.
