Car Scanner Pro app for Diagnostics
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A.J, Oct 10, 2025.
  1. A.J
    A.J Junior Member
    57
    Worldwide
    I see only few people talk about Car Scanner Pro app on here for Gen 2, so i am opening this thread to show how cool this app is for Gen 3 too.
    I got it yesterday and so far, it's amazing. If you have an experience with it, you can also share.
    PROS:
    -It has alot of sensor reading for Prius
    -Customisable Dashboard
    -Custom Action PID
    -Coding
    CONS: Electric Pump RPM reading isn't functional for me at time of writing.
    I can display upto 30 sensors and action on the app dashboard, which includes Engine, Battery, Distance since codes clear, warms up e.t.c
    Also create a custom action to clear DTC on the go without leaving the Dashboard screen. (04 is the custom command for ELM327 DTC code clearing)
    My current Dashboard look:
    priumium likes this.
  2. rjparker
    10,170
    6,323
    Car Scanner coolant temp diagnostic aids
    Stuck Exhaust heat Recirc valve coolant temperature sensor in red
    Good exhaust recirc valve
    xliderider and Brian1954 like this.
  3. VelvetFoot
    VelvetFoot Active Member
    758
    278
    New York State
    2026 Prius
    Text output works on CarPlay.
  4. Brian1954
    Brian1954 Senior Member
    2,232
    880
    South Central PA, USA
    CONS: It is not capable of communicating with all the ECUs in a Gen 3 Prius, but it comes very close. You just need to know its limitations. https://priuschat.com/index.php?posts/3564647
    It is a very nice app for most people to use. It is better than 95% of the scanner apps that are available. I like it very much.
  5. VelvetFoot
    758
    278
    New York State
    2026 Prius
    I'm curious how it compares with OBD Fusion, which also communicates to CarPlay?
  6. Brian1954
    2,232
    880
    I do not use the OBD Fusion app. Maybe someone else can answer your question.
    VelvetFoot likes this.
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Has anyone been able to get the inverter coolant temp to display in Fahrenheit instead of Celsius in the Car Scanner Pro app?
    For some reason, the global setting of imperial measures doesn't apply to the readings from this sensor.
    I can confirm that the engine coolant pump rpm sensor doesn't return any value. On the other hand, inverter coolant pump rpm can be monitored, but it seems to be a constant value.
  8. rjparker
    10,170
    6,323
    The inverter temps work in f for me.
  9. A.J
    A.J Junior Member
    57
    Worldwide
    This means some reading might be working in Fahrenheit and not work in Celsius. Nice observation.
    Is there somewhere to get all the temperature RED limit pointers for Gen 3?
  10. rjparker
    10,170
    6,323
    The alarm limits are in the repair "manual".
    Portion
    Engine coolant temp is 248f.
    I setup separate temperature alarms lower than the vehicle's.
    A.J likes this.
  11. VelvetFoot
    758
    278
    New York State
    2026 Prius
    Newbie here.
    Two questions:
    1) What is this "repair manual" you speak of, and where can one find it?
    2) Does one have to purchase the Pro version of Car Scanner to get access to these hybrid-specific readings?
    Viewing these parameters on the infotainment screen via CarPlay while driving should be fun...for about a week or so, until the novelty wears off, lol.
    The best part would be no physical changes to car, unlike a previous gauge project of mine.
    Thanks
  12. A.J
    A.J Junior Member
    57
    Worldwide
    1. I attached 2010 repair manual, Temperature measurements at Page 593
    2. For the Dashboard, No.
    It sure look nice because it's highly customisable. View recent photos 2.png .
  13. VelvetFoot
    758
    278
    New York State
    2026 Prius
    Thanks! I'd be looking for a '26 version. I downloaded a late model manual the other day, but I don't think it has this info. I guess it'll surface once they start screwing up, lol.
    CarPlay, which along with Android Auto is on the late models, is a revelation for me.
    edit: Upon looking closer, what I downloaded might have that info!
    A.J likes this.
  14. rjparker
    10,170
    6,323
    If you are getting a gen5 you should be researching and asking questions in the gen5 forums. You are liable to get different answers for the vastly different gen3s here.
    The only complete "manual" is not a manual but thousands of pdf files available online from Toyota. For a price per day, month or year. The same documents used by dealer techs which have updates, links and other dynamic capabilities.
    They are not written to the beginner although some basics are included. Dealer techs are expected to get Toyota training and become certified at various levels. As a result many Toyota techs can not work on certain hybrid issues or perform more complex work or tsbs.
  15. ChapmanF
    18,250
    This page explains:
    Toyota Service Information and Where To Find It | PriusChat
    The Repair Manual isn't written for beginners, but assumes you already basically understand what the different parts of the system are for and how they do it. That's in the New Car Features manual, which you also find alongsude the Repair Manual. Also, still the the same subscription, you find the training materials for Toyota's technician training courses. And more.
  16. priumium
    priumium Member
    258
    66
    Sweden
    2013 Prius Plug-in
    Car Scanner Pro for the win. No paywall, no account (tracking) and no online required….customizable.
  17. ChapmanF
    18,250
    Sounds great, for cases where its capabilities include what you need.
  18. priumium
    priumium Member
    258
    66
    Sweden
    2013 Prius Plug-in
    Why do so many people here keep pdfs of gen 3 repair manual private?
    Share here or drop at mega.
    In EU the right to repair is a movement that will force full release of these repair/workshop manuals. Very reasonable legislation.
    What are y’all with these manuals so afraid of? Toyota is not Nintendo. And never will be. :whistle:
  19. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    What do you do with the money you earn from working? Do you give it away to people you don't know, for free?
    I doubt it. So why would you expect anyone else who has spent money on something to give it away?
    I believe if you BUY something, it is yours. Do with it as you wish. If it breaks, fix it.
    But manufactures do NOT have to make any of their manuals available, free or at cost.
    It's nice if they do.
    But they shouldn't be forced to put that information out there either. They work hard and spend a lot
    of money to produce that produce and information.
  20. ChapmanF
    18,250
    Manufacturers did agree in the US to the terms of a right-to-repair law passed in Massachusetts. The law was perhaps not as strong as what primium is seeing in the EU.
    The Massachusetts law calls on manufacturers to make their service information available to anyone at a reasonable cost. The availability of all Toyota's service literature and technician training course materials at techinfo.toyota.com just satisfies the terms of the law. Toyota and other manufacturers don't seem very interested in going much beyond what the law requires.
    If I remember right, an association of manufacturers agreed very quickly to abide by the Massachusetts RTR law throughout the US, as a way to preempt legislative efforts in other states that might have produced stronger RTR laws.
    priumium and Brian1954 like this.
