Dealer Overfill Engine Oil, Should I Be Concerned?
Discussion in 'Gen 5 Prius Main Forum' started by Humble Bear, Oct 20, 2025 at 8:04 PM.
  1. PriusCamper
    PriusCamper Senior Member
    12,498
    5,060
    Pacific Northwest, USA
    1/2" is more than slightly... And I bet if you did statistical analysis on the lifespan of Prius engine the dummies that trust minimum wage workers to not overfill with motor oil owned a Prius for less time than people who made sure they always kept their oil at the exact amount recommended.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    Just sayin' I wouldn't worry about it at all.
  3. PriusCamper
    12,498
    5,060
    If a Toyota Stealership did something wrong it's essential to make the most of it... These folks destroy lives with outrageous repair charges that people can't afford.
    For example, when there's corrosion in a plug to a hybrid battery cooling fan (known Gen2 problem) they'll tell the customer they need a new hybrid battery and a new cooling fan for near $5K even though I can clean that plug in 5 minutes and never charge the Prius owner for that fix. And that's just one example. If we had legit consumer protection laws Toyota Stealerships would all be in Bankruptcy.
    #23 PriusCamper, Oct 20, 2025 at 11:08 PM
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    I don't like promoting youtube channels, but this one actually takes a good look at what happens when you overfill your oil:
  5. VelvetFoot
    VelvetFoot Member
    301
    74
    New York State
    2026 Prius
    I've seen similar experiences with VW TDI's. Dealer tells them they need a new turbo, and all that needs to be done is clean out the EGR pollution (lol) from the turbo's vacuum control and lines.
