Dealer Overfill Engine Oil, Should I Be Concerned?
Discussion in 'Gen 5 Prius Main Forum' started by Humble Bear, Oct 20, 2025.
  1. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
    1/2" is more than slightly... And I bet if you did statistical analysis on the lifespan of Prius engine the dummies that trust minimum wage workers to not overfill with motor oil owned a Prius for less time than people who made sure they always kept their oil at the exact amount recommended.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    Just sayin' I wouldn't worry about it at all.
  3. PriusCamper
    13,021
    5,291
    If a Toyota Stealership did something wrong it's essential to make the most of it... These folks destroy lives with outrageous repair charges that people can't afford.
    For example, when there's corrosion in a plug to a hybrid battery cooling fan (known Gen2 problem) they'll tell the customer they need a new hybrid battery and a new cooling fan for near $5K even though I can clean that plug in 5 minutes and never charge the Prius owner for that fix. And that's just one example. If we had legit consumer protection laws Toyota Stealerships would all be in Bankruptcy.
    #23 PriusCamper, Oct 20, 2025
    Tande likes this.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I don't like promoting youtube channels, but this one actually takes a good look at what happens when you overfill your oil:
  5. VelvetFoot
    VelvetFoot Active Member
    1,176
    461
    New York State
    2026 Prius
    I've seen similar experiences with VW TDI's. Dealer tells them they need a new turbo, and all that needs to be done is clean out the EGR pollution (lol) from the turbo's vacuum control and lines.
    PriusCamper likes this.
  6. PriusTech
    PriusTech Active Member
    259
    117
    Reno
    1/2" on the dipstick is about 1 quart, which is real close to the amount that will start to cause problems. Unless you are racing on a road course in which case you would intentionally run at that level for the high G starvation issues
    Winston Smith, PriusCamper and bisco like this.
  7. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    Why do you let people you don't know touch your car? Change the oil yourself. You can do it in less time than it takes to drive to an oil change place.
  8. Paul Gregory
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    a half inch is quite a lot more than what I was originally led to believe.
  9. Brian1954
    Brian1954 Senior Member
    2,397
    960
    South Central PA, USA
    Did you read post #1?
    I guess you did, because you quoted post #1 in your reply in post #3.
  10. AzusaPrius
    AzusaPrius Senior Member
    2,230
    930
    Wow....notice he posted and then was bombarded with nonsense.
    @Humble Bear
    At what point did you notice the oil level was high?
    At the dealership?
    At home when you got back?
    Both would get bad readings.
    You need to check the oil in the morning before you start the engine.
    That is the only way to get an accurate reading of the oil level.
  11. PriusCamper
    13,021
    5,291
    Thank you!!! It's so insane that something as simple as an oil change leaves people powerless and willing to accept a shorter lifespan of their vehicle they spent big money on because they can't even be bothered by the need to change their own oil...
    Tande likes this.
  12. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    1) I normally change my own oil, but I am surprised that a lot of you don't know Toyota gives 2 free services in first 2 years which includes oil change @ 10K & 20K.
    2) @AzusaPrius, the owner's manual says check the oil when the car is in operating temperature but let car sit for 5 minutes so the oil will flow to the bottom.
    3) Owner's manual says from min to max mark on the dipstick is 1.5q and it's about an inch, so 1/2 inch is about .75q that's about 20% of the oil capacity which is way too much.
    4) I had my wife take it to the dealer and have them remove the excess oil and now it's 90% between the min & max which is great. Next service, I will tell the dealer not to overfill and I will check the level afterwards to make sure they do their job right!
    bisco and Brian1954 like this.
  13. bisco
    52,360
    not everyone is capable of changing their own oil, for various reasons
  14. Mendel Leisk
    41,873
    You're adding to it, lol. I've never seen more than an 1/8'th inch variation, regardless of time/temp.
    Between the full and low pips? My gen 3 at least, it's just shy of 1.5":
    Could be different with gen 5.
    #34 Mendel Leisk, Oct 22, 2025
  15. William Redoubt
    1,228
    1,173
    Would you let some kid without even a GED give you a blood transfusion or dialysis? That is the equivalence of an oil change for your car. Get it wrong and the results are devastating.
  16. AzusaPrius
    2,230
    930
    @Mendel Leisk
    No offence but you are the one adding more nonsense to this post for a 5th gen.
    I only stated when it is best to check your oil level.
    Also it has nothing to do with the time of day or the temperature of the day, that is your own perception of what I said and you are wrong.
    If you change your oil and check it right after, it will not be accurate.
    If you check your oil after you have driven around and you check it, it will not be accurate.
    The time to check it is best when it has sat over night and right before your start it.
    All the oil is where it is supposed to be.
    #36 AzusaPrius, Oct 22, 2025
  17. William Redoubt
    1,228
    1,173
    I agree with this post. However, I check my oil at the gas pump, every fill up. I also look at the coolant (both reservoirs). I know how much oil I put in (I change my own) and am very familiar with the proper level on the stick (although it is often hard to see).
  18. VelvetFoot
    1,176
    461
    New York State
    2026 Prius
    Are the engines in the Gen 5 using any oil?
    #38 VelvetFoot, Oct 23, 2025
  19. Mendel Leisk
    41,873
    Ok, fresh on the heels of an oil change, I concur.
    When I change mine, I put in the specd amount, with a graduated pitcher, and ignore it for a few days.
  20. Hammersmith
    Hammersmith Senior Member
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    no
    VelvetFoot likes this.
