Blower motor issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jimbo22, Oct 21, 2025.
  1. Jimbo22
    Jimbo22 New Member
    I have hit a dead end. My AC had inconsistent flow for a few days then stopped blowing altogether. The heater does not blow either. I have replace all the fuses, the blower motor and the 12v battery with no success. When I turn on the fan it moves about 1/4 inch and that’s it. Any idea on where to go next?
    thanks
  2. PriusCamper
    PriusCamper Senior Member
    12,741
    5,153
    Pacific Northwest, USA
    Head to a junk yard and pull a fan... Of course maybe there's a fan relay that's failed? If it's a capacitor I would think that's probably built into fan, but have never taken one apart.
    Everything already vacumed out and cleaned?
  3. ChapmanF
    18,158
    There's no relay (except in trims with the solar ventilation option, which have the SPDT relay that switches the fan power between the solar panel and the 12V system).
    The blower you put in, where did that come from? Does it test ok on the bench?
    PriusCamper likes this.
  4. BiomedO1
    3,584
    1,856
    SacTown, Ca
    Make sure your HVAC is clean and clear. Check your interior air filter and wiper cowl is clear.
    If your fan is not turning when activated, check connections and wire damage. Don't know if those has a ballast resistor, that sometimes opens up on other cars.
  5. ChapmanF
    18,158
    No Prius generation had a blower resistor. Gen 1 and gen 2 had a blower motor PWM controller that mounted separately in the air duct, the same way older cars' resistors would be mounted, leading some people to still call it a 'resistor'. Gen 3 moved that into the blower motor itself and doesn't have the separate unit.
    BiomedO1 likes this.
  6. rjparker
    10,137
    6,299
    First thing I would suspect is the replacement blower motor is bad. Unless it was new oem.
    I would check three fuses
    Then do an active test with Techstream if available
    Then check power and ground across the blower motor itself to ensure power and ground are good. A bad ground is just as bad as no power.
    Finally you need a scope or meter with graphing capabilities to check the SI pulse train input.
    If the replacement blower is not new Toyota oem from Toyota then my bet is it's bad.
