Prius spare tire
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Oct 21, 2025.
  1. HamiltonPrius
    HamiltonPrius Member
    203
    98
    Parts unknown in Virginia
    2026 Prius
    Has anyone tried to cut out a circle cavity in the trunk styrofoam to store a dummy spare?
    52,294
  3. HamiltonPrius
    203
    98
    2026 Prius
    Exactly……thanks for the photo. How did you attach the tire tie down to the body of the car?
  4. HamiltonPrius
    203
    98
    2026 Prius
    I see from your bio you have an older car. I believe back then the lower trim cars had dummy spares so the attachment point was still on the upper models without a spare.
    I’m guessing that attachment point isn’t on the 5th gen car since none have spare tires.
  5. VelvetFoot
    VelvetFoot Active Member
    1,146
    452
    New York State
    2026 Prius
    You really have to read a little more carefully.
    The post was by @GcinFl .
  6. bisco
    52,294
    that's not me, i just searched for it. you can click the link and ask him.
  7. HamiltonPrius
    203
    98
    2026 Prius
    Thankyou….I didn’t see the little post at the top of the picture
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you'd head over to the Maintenance sub-forum, you'll find a long thread about how to install a spare tire as factory as you want it. A spare is an option in Japan, and standard equipment in Mexico. Any Prius HEV(FWD or AWD) can add a spare. Prius PHEV cannot. I've had mine for well over two years.
    You can have a complete conversion for around $600-$700. Or you can do a bare minimum install for around $100. Or anything in between. All depends on how much money you want to spend and how polished you want the finished product to be. Parts list is available in the other thread.
    Easiest conversion is FWD XLE or LTD. AWD XLE and LTD is just a tiny bit harder(1 additional part + 3 nuts to hold it on). FWD LE is more involved. AWD LE just a tiny bit worse.
    Here's my setup. It's as complete of a conversion as you can do:
    (even did the decals)
    #8 Hammersmith, Oct 22, 2025
    GcinFl and Gokhan like this.
  9. Gokhan
    Gokhan Senior Member
    6,483
    2,594
    Paramount CA
    Link to parts?
  10. Blackat
    Blackat Active Member
    476
    338
    Colorado
    2023 Prius
    Limited AWD-e
    It's all in an older thread he started.
    Gokhan likes this.
  11. Gokhan
    6,483
    2,594
    Paramount CA
  12. Bruce Cutcliffe
    Bruce Cutcliffe New Member
    Merrimac, MA
    2026 Prius
    XLE AWD-e
    I was surprised to see the molded Styrofoam beneath the flimsy deck board on my 2026 Prius, as my prior 2012 Prius 2 had a solid board with locking latches. Beneath the solid carpet covered board was a large plastic tray, and beneath that was the small spare along with stored jack. My initial thought was that the Styrofoam was there simply a filler-like packing material to be removed by purchaser, GUESS NOT!
    Gokhan likes this.
  13. Bruce Cutcliffe
    Merrimac, MA
    2026 Prius
    XLE AWD-e
    I purchased the 2026 Prius based upon its great styling, and the excellent service and extremely low maintenance provided by my 2012 Prius 2; only had 182,000+ miles on it when traded for the 2026 but still ran great! Did I check out the compartment below the truck area? No, I never drove or even sat in the vehicle prior to purchase! Of course, I am learning as an elderly new owner that the 2026 is only slightly easier to get in and out of than a 1962 Corvette I once owned!
  14. Gokhan
    6,483
    2,594
    Paramount CA
    @Mendel Leisk, your dream car has arrived!
  15. Gokhan
    6,483
    2,594
    Paramount CA
    Congrats!
  16. Gokhan
    6,483
    2,594
    Paramount CA
    Wow, is this the first Gen 5 reported with a factory-installed OEM spare?
  17. Mendel Leisk
    41,830
    I think he’s talking about his previous 2012. Got one of those. :)
  18. longshot
    longshot Junior Member
    83
    I just cut it out. Then covered the high voltage cabling with protection and used a long bolt, washer wing nut thru the wheel bolt hole to hold it secure. Had an old scissor jack laying around
    Gokhan likes this.
