Attention Prius Owners, I believe I have discovered a previously unknown Mechanism of Low MPG.
Discussion in 'Gen 2 Prius Main Forum' started by TheLastMojojomo, Nov 2, 2021.
  1. Randycoureton
    Randycoureton Junior Member
    17
    US
    Four Touring
    Have u tried sweeping or reprogramming the throttle body Just an idea. I know on some cars this can fix a lot of the glitches
    iPhone ?
  2. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
    Just curious...has anyone tested out if the issue persists after swapping out the traction battery? I'm wondering if the ECU is triggering a different usage profile based on what it determines the health of the battery pack is?
  3. Meter guy
    Meter guy Junior Member
    53
    I had a friend with a Prius report the low 40s mph and then got the traction battery replaced and said she's back in the 50s now.
    Like others have said, I noticed mine dropping immediately when I replaced the 12v battery back in 2017. I'm lucky to get 42mpg on mine and I never use the AC. I've got 274k on original traction battery 2009
  4. .T treboR
    .T treboR New Member
    America
    Not a Toyota tech, but you’re correct that many “test conditions” in modern cars require more than just starting the car and driving. Time spent at or above a specific speed, ambient air temperature, cold soak (where the car gets up to temp and then back to ambient before restarting), some or all MIL being off and having passed their own checks, and more, can be requirements for cars to pass their own self-tests. Besides this, some systems are gating items for other systems. That is to say: until system X has passed its tests, system Y will not attempt to run its tests. Factory technician training documentation should have retirements to fulfill these tests so they can meet them using your car after certain repairs, but I worked at an independent garage and know only vagaries, not specifics.
    dex3703 and dolj like this.
  5. dolj
    dolj Senior Member
    8,445
    4,290
    Wellington, New Zealand
    In addition to what was said in the last post, I'm pretty sure the start-stop style of driving of a postal worker is never going to get the Prius configured for max MPG.
  6. Paul Gregory
    Paul Gregory Senior Member
    2,153
    563
    Alberta
    2024 Prius Prime
    XSE
    This stuff is too thick for me, or I'm too thick for it.
    Either way, I'll give it a pass. I prefer the old fashioned way; I record my mileage and fuel quantity at fill-up each time, and do the math.
  7. Azorias
    Azorias New Member
    2020 Prius Prime
    You can easily fix this issue by replacing your 12 volt battery with a brand new high quality.
    Everyone who does this and makes a video about it will recieve $2500.
    I gave Mr mojo the solution to this problem years ago and he refused to try it, he tried everything but the correct solution,
    Don't repeat his mistake.
  8. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Is there a new billionaire or 12V battery store owner on the forum?
    Kromis likes this.
  9. dreybay
    dreybay Junior Member
    cali
    Two Eco
    Experiencing this issue on my 4th gen and for the life of me couldn't figure it out at first. It feels like a completely different car and about 8-10 lower mpg's :/
    dex3703 likes this.
  10. VelvetFoot
    VelvetFoot Active Member
    664
    237
    New York State
    2026 Prius
    Did you fix it?
  11. dreybay
    cali
    Two Eco
    No I have not. Just diagnosed it and this seems like the exact issue I have. Even feathering the pedal causes the engine to constantly kick on during city driving/slow driving and drastically reduces mpg. It started happening after a recent 12v disconnect. Also I don't know how I would re-calibrate the system because I generally drive a similar route and nothing has changed.
    dex3703 and VelvetFoot like this.
  12. VelvetFoot
    664
    237
    New York State
    2026 Prius
    Is the battery old (see post 147)?
  13. dreybay
    cali
    Two Eco
    Battery is 1.5 years old and in good condition. I guess maybe swapping it out could possibly change something but sucks I have to spend money for some software issue
    dex3703 likes this.
  14. VelvetFoot
    664
    237
    New York State
    2026 Prius
    I'd wait for someone who actually knows something chimes in. :)
    Mendel Leisk and dreybay like this.
  15. dreybay
    cali
    Two Eco
    Would something like an obd2 memory saver prevent this issue? Like would it save the driving data you’ve had in the past when disconnecting 12v
  16. PriuSocal
    PriuSocal Member
    202
    SoCal
    I am exactly in the WEAK EV situation. I had to connect and disconnect the battery multiple times during a transmission swap and now I am getting roughly 40-43 MPG as to where before it would be 47-48 mpg as well as my fuel levels are completely off. It reads near empty (beep and blinking bar) and when I go to fill up, it only takes 6-7 gallons, which would indicate I have roughly 5 gals left (based on the 11 gal tank capacity.
    I miss my MPG but it all started after the 2 month long time the car was being diagnosed (battery would die after a week or so of not moving it) and transmission was being replaced.
    dex3703 likes this.
  17. VelvetFoot
    664
    237
    New York State
    2026 Prius
    Again, I know next to nothing, but I've read that some systems need to be 'initialized' after disconnecting the battery. Exactly what that means, I don't know.
  18. dolj
    dolj Senior Member
    8,445
    4,290
    Yeah, nothing exciting. Reset the auto-up/down on the driver's window. Reset the radio stations. All your consumption values reset to zero. A number of EMC PIDs reset to factory defaults. It's all covered in the initializing section of the repair manual.
    It can take a bit of driving that includes specific scenarios to get all the engine PIDs relearned, and that is where you see lower MPG. I don't know the exact timeframe, because that depends on completing all the driving scenarios that need to be completed. Driving style very much influences how the EMC configures itself for performance or economy.
  19. VelvetFoot
    664
    237
    New York State
    2026 Prius
    I wonder if there is a way to obdc read the status of these 'relearnings', similar to readiness in the main engine codes? Perhaps with Techstream if too esoteric for the cheapies. Again, I know nothing specific.
    dex3703 likes this.
  20. Mendel Leisk
    41,442
    Yes.
    but resetting is no big deal. I purposefully disconnect 12 volt battery for DIY brake work.
    if I was just swapping 12 volt, then yeah, I’ve got a memory saver cable, use it with a jump pack.
