How to jack up 2009 prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lastradakiwi, Oct 21, 2025.
  1. lastradakiwi
    lastradakiwi Junior Member
    22
    Fairfax, Virginia
    2017 Prius c
    I have been sifting through this forum looking for a visual guide on where to jack up the gen 2 Prius but it left me with more questions than answers. I have seen the diagrams but I'm still confused. Is there a video showing step-by-step instructions on how to do this? This will be the first time jacking up any car and I just want to learn the right way.
  2. BiomedO1
    3,591
    1,857
    SacTown, Ca
    Use rhino ramps. The front jack point on these cars are way back, just in front of the firewall. If you really need to jack up the car; drive it up on the ramps - you'll then have a clear view of the jack point. If you rely on someone else to steer you in, your jack may slip and do some major damage.
    Hope this helps.....
    fragglestickcar likes this.
  3. fragglestickcar
    87
    47
    New York
    First time? Welcome to the magic of hydraulics. I assume you just need to jack a corner, which any of 25 YouTube videos can show you. Jacking up the entire front is harder. As someone else pointed out the front jack point is too far back for the jack to reach without first driving the car up onto ramps. I've never had to jack up the entire front, so it wouldn't seem necessary for you either, a first-timer.
    Edit: Since it's your first time, I'll repeat something you probably already know. Never get under a car with just the jack supporting the weight. Use jack stands! Push in the parking brake. Use a chock on a slope, etc.
    BiomedO1 likes this.
  4. BiomedO1
    3,591
    1,857
    SacTown, Ca
    Chock the wheels even if your flat. If someone leans on the car or you grab the car or jack as leverage to pull yourself out, you may start loosing body parts.o_O:rolleyes:
    Use those pinch wield blocks so you don't smash your pinch wields - that'll allow rust and leaks to form there.
  5. rjparker
    10,141
    6,301
    The owners manual shows how to jack it up.
  6. Mendel Leisk
    41,433
    Presumably just the front, for starters. Take a look at the oil change link in my signature (on a phone turn it landscape to see signatures): it's gen 3 specific, but mostly applicable to gen 2.
    With gen 2 I think you're in for a "treat" with the front jack point, apparently it's waaaay back, so to get a typical floor jack to it and started raising, you may need to roll the front onto low-rise ramps first. Even if the jack will fit under sans ramps, the handle may be hitting car underbody so soon that it can't start the lift.
  7. fragglestickcar
    87
    47
    New York
    It's not going up I'm worried about. It's coming back down.
    I once had a nice M-class bmw and decided to forego the ramps. At that angle, a controlled release is impossible. Managed to put a jack lever shaped indentation into the undercarriage. I should just be happy the car didn't lunge forward into my face.
    Mendel Leisk and Danno5060 like this.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,624
    777
    Southern California
    On our 2007 I drive the front of the car up on 2x10 boards about 2 feet long. Then slide the floor jack in, carefully center it on the big metal butterfly, and jack the car up. Place jackstands at the pinch welds behind the front wheels. Lower it gently onto them.
    In theory the car can be lowered straight to the ground (without the boards). This is because the jack I have fits under, it just cannot be pumped in that position - the lever hits the bumper. Lowering doesn't require moving the lever up and down, just rotating it. That said, I always lower it onto the boards anyway. Controlled descent is difficult and if the car comes down too fast it might descend hard onto the jack in its most retracted state as the springs compress from the momentum., Then it would be a bunch of metal parts hitting each other very hard, which is best avoided.
  9. Mendel Leisk
    41,433
    I would wholeheartedly recommend these points:
    picture is gen 3, but gen 2 is very similar. Got the idea from Hobbit I believe, a former PriusChat member, very active, maintained a very detailed Prius website of his own.
    note: even scissor jack does not bear on the knife edge of the “pinch weld”; it cups around it and the actual bearing point is slightly inboard, and dimples with even a single use, even on a back corner.
    try placing the scissor jack, to confirm.
    #9 Mendel Leisk, Oct 24, 2025
  10. BiomedO1
    3,591
    1,857
    SacTown, Ca
    You lower the car back down onto the ramps - NOT directly onto the ground. The car is so low slung, chances are that your jack will end up stuck under there and you may damage your lower air foil shield.
  11. priumium
    priumium Member
    176
    Sweden
    This is how I unofficially lift my gen 2s, with a lovely banal Vevor remote controlled 21V pneumatic jack.
    The package also includes a 450Nm lug nut wrench device. Price is apx 200usd for the bundle.
  12. BiomedO1
    3,591
    1,857
    SacTown, Ca
    I use a simple floor jack for a quarter of the price; break loose the lug nuts and use my drill to half-inch socket adapter to run them in n out; because you need to torque them down when your finished.
  13. priumium
    priumium Member
    176
    Sweden
    Most people use a floor jack. Me to before for 20 years..
    It’s not all price, it’s convenience. When you have three cars that need winter tires, this is super fast and smooth.
  14. Mendel Leisk
    41,433
  15. priumium
    priumium Member
    176
    Sweden
  16. Mendel Leisk
    41,433
    Four is even better. :)
    My other trick, whenever practical: push a tree trunk section under there, before I get under.
    #16 Mendel Leisk, Oct 26, 2025
  17. Collie
    Collie Junior Member
    Thanks to everyone trying to help the original poster.
    Respectfully, I have to say - it is absolutely wild that there is just not a simple ******GEN 2 SPECIFIC****** video on how to do this.
    When we have to start saying it’s similar to Gen 3 and referring to their diagrams - or use the factory jack (that may not of came with their purchase of the used car) or a manual that a half a dozen people have still been confused by the illustrations, we’re setting our novices up for a dangerous failure although it’s all in good faith and kindness.
    I don’t have the means to, but it sure would be nice if someone would just make a video. Not everyone has the mental capacity to go through manuals. Some people are visual learners and the devil is in the details.
    priumium and BiomedO1 like this.
  18. BiomedO1
    3,591
    1,857
    SacTown, Ca
    Use a car ramp or have someone with experience show you. Your correct, the devil is in the details and if you get it wrong - you may only damage the car or worse you get squished.
    Collie likes this.
  19. Collie
    Problem, not everyone has someone to show them.
    I’ve been reading these threads for years - MANY people have the diagram from the manual and are still confused… we can’t expect everyone to get things just because we do. Some people need a video.
    In a world where there is a video to show how to do a million things to a gen 2 prius, there should be a simple, concise video on how to get it up on 2-4 jack stands ( with or without the factory jack as some people buy cars that do not include it)
    If any YouTubers are reading this, here’s your sign.
    #19 Collie, Nov 8, 2025
  20. Mendel Leisk
    41,433
    "their diagrams" is just somebody who had their 3rd gen up in the air, thought to take some pictures. Again, the idea for the front safety stand points (in my pic above) came from priuschat member Hobbit’s website , who had a gen 2. It’s in there, somewhere, but it takes a bit of hunting.
    Suffice to say, the pic I posted above IS the spot, for front jack stands, per Hobbit. The rear points I came up with myself, they’re on the reinforced low points, where there’s oblong body plugs (used for locking pins at some point during manufacture or shipping, I’d speculate.
    What's "absolutely wild", is that we used to manage, muddle through, figure things out, without taking opinion polls on the internet, being spoonfed YouTube videos. I'm not faulting them, but just use your noodle, be methodical and careful, and you'll get there.
    #20 Mendel Leisk, Nov 8, 2025
