Walmart Coolant
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 22, 2025.
  1. Prodigyplace
    12,533
    11,755
    Central Virginia
  2. BiomedO1
    3,508
    1,822
    SacTown, Ca
    Out here in the states, distilled water is cheap and readily available - especially at refueling stations for that specific purpose.
  3. qmanqman
    qmanqman Active Member
    428
    146
    CO
    In Colorado Springs where I live tap water is basically distilled water.
  4. priumium
    priumium Member
    104
    26
    Sweden
    Wow. Can I have a source on that? Normally water pumped to consumers thru pipes are chlorined in the EU to avoid germ growth - also with a lowered ph to avoid deposits. And for coolants glycol is naturally added only to avoid freezing since we can have -20° winter days up here in the nordics.
    Dealer and interweb told me G13 is recommended for any Prius since gen2..
    #24 priumium, Oct 23, 2025
  5. qmanqman
    428
    146
    CO
    Source is my neighbor via me. He is a retired chemistry prof who told me years ago that our tap water is so soft they use it as distilled water in their lab. It does have chlorine as you can sometimes smell it. But the beauty of chlorine is you just set the water out for a time and it evaporates away. We do have naturally occurring flouride so it isn't perfect.
  6. priumium
    priumium Member
    104
    26
    Sweden
    Distilled water is defined as pure water molecules. It’s not up to your neighbor to redefine ;)
    Any contaminants including chlorine or fluoride makes it by defintion not distilled. These are the other molecules or elements that will get stuck in filters or in the case of coolants, the block. It’s the boring truth of chemistry.
    Distilled water - Wikipedia
  7. qmanqman
    428
    146
    CO
    My neighbor is "Defining Man" and if he says it I believe it. He's more reliable than Google AI when it comes to chemistry. should have been there for our talks on alcohol . . . Wild!
    Ya, I'm sure there's some fluoride molecules here and there but coolant passages are huge.
    priumium likes this.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,590
    768
    Southern California
    That tap water might be very close to distilled water when it arrives at the city's water system, but it will be significantly chlorinated when it goes out in the pipes. Note that neither of the two MSDS links which were posted earlier list any chlorine or chlorinated compounds. The Prestone did have some sodium in it.
    The Toyota coolant is essentially just ethylene glycol, a little water, something to make it taste terrible, some pink dye, and a small amount of mystery ingredients. The Prestone looks pretty similar to Toyota's brew, but with the glycol component(s) diluted by 1/2 or so.
  9. pasadena_commut
    2,590
    768
    Southern California
    High voltage, non-conductive?
    At first I thought that this might be an AI hallucination but apparently it really is a thing for EV coolants. Seems unlikely that anybody is actually running coolant over charged HV conductors but as a safety measure, in case of a leak, it makes sense.
    Electrical Conductivity in Vehicle Coolants
    In short, the manufacturer tries to eliminate ions from the coolant so that it has a much higher resistance than typical coolants. (Because fewer charge carriers. Pure water has a very high resistance but conducts well once it picks up some ions.) That is out of the bottle. After it has been in the car long enough it might pick up enough metals and such to achieve a conductance considered too high for safety in an EV. Which suggests another factor determining "when to change the coolant" in an EV. Pretty sure none of the existing test strips have a measurement for "conductance" though. And the limits discussed in the link above are so low it doesn't seem likely that just sticking the tips of both ohmmeter probes into the coolant would be able to get an accurate measurement. Which is not the same thing as the corrosion test using a DC measurement between the coolant and ground:
  10. qmanqman
    428
    146
    CO
    Contacted Zerex through their website yesterday. Just got off the phone with a guy who explained it to me. He was able to find the Toyota SLLC Spec sheet, which I can't find (if someone can please post it.) He may have also found this on the back of the SLLC bottle. The SLLC meets coolant standards ASTM D3306, ASTM D4985 (which are American Standards) and the key is the JIS K2234 standard which is the Japanese Industrial Standard.
    If you look at the back of the Walmart bottle it meets the two ASTM standards but there is no mention of the JIS standard. Ditto the Prestone Aisan coolant. However, the Peak Asian Red/Pink (https://www.gradealube.com/wp-content/uploads/2023/10/PEAK_Asian_Red_-_PDS.pdf) does meet the JIS standard. I would take this to mean the Peak Aisan coolant is compatible with the SLLC. I'm still trying to find the spec sheets for Prestone and Walmart.
    EDIT - I just looked at the online picture of the back of the bottle of the Peak coolant. It says JIS K2234-1994. Apparently this standard was updated in 2006 (JIS K2234-2006) and again with JIS K-2018. I'd be good with the 2006 version but not the 1994 version.
    #30 qmanqman, Oct 24, 2025
    xw20_driver likes this.
  11. qmanqman
    428
    146
    CO
  12. qmanqman
    428
    146
    CO
    Just got off the phone with a nice woman with the manufacturer (in Canada) of the Walmart coolant. If you look at the bottom corner of the Walmart coolant there is a part number )7013. She sent the spec sheet that says this?
    Recochem Coolant P7013 - Specification Sheet
    Product Name: Recochem Coolant P7013
    Application: Hybrid engines including Toyota Prius
    Formulation: Phosphate-based Organic Acid Technology (OAT); Silicate, borate, nitrite, and amine free; 2-EHA free
    Color: Red or Pink (Toyota-compatible variants)
    Compatibility: Toyota Super Long Life Coolant (SLLC); Suitable for engine and inverter cooling systems
    Standards Met: ASTM D3306, JIS K2234
    Service Life: Up to 5 years or 150,000 miles (240,000 km)
    Safety Notes: Do not mix with conventional green or universal coolants; Ensure proper bleeding of inverter loop to Recommended Item Numbers: 86-384ROEMT (50/50 premix), 86-374ROEM (concentrate)
    The problem there is it says "don't mix" with other coolants in the inverter. Probably still best to stick with SLLC for the inverter.
    #32 qmanqman, Oct 24, 2025
    Aegean likes this.
  13. qmanqman
    428
    146
    CO
    My Summary (opinion):
    Walmart (made by Recochem) - OK for engine (which I will do) but use SLLC for the inverter unless you wanna flush it and keep track of what's what.
    Prestone - Also made by Recochem so ditto above
    PEAK - Ditto Walmart.
    Zerex - JIS K2234-1994 may be sub-standard so don't use period
    BiomedO1 likes this.
  14. BiomedO1
    3,508
    1,822
    SacTown, Ca
    IMHO; difficult to get the right balance if you flush the system and can only get premix. You'll need concentrate to correctly balance glycol levels in harsh winter conditions. No big deal if you live near the coast or southern states, where the weather is much milder.
    Seems like a lot of 'shoe leather' to save a few bucks; but thanks for the verification and insights.
  15. qmanqman
    428
    146
    CO
    Ya my bad. Didn't mean flush.
  16. Mendel Leisk
    41,334
    Well, 50% water. Except up here on the balmy west coast of the Great White North, where it's 45% water, courtesy of Toyota Canada. Curious if Alaska gets the 55/45 mix too. Or North Dakota for that matter.
    I'd concur regarding coolant "flush", and yeah, it's mostly just a misnomer. If not, it's bad news, both for trying to subsequently achieve a 50/50 balance (basically impossible without resorting to a full-strength alternative, say Long Life Coolant, without the adjective "Super"), AND: what the heck to do with the flushed water/glycol mix, run it down the street, to the storm drain and streams?
    I just did both coolant circuits, will take the old stuff to our dealership for responsible disposal (I hope). Ditto for some drained brake fluid.
    #36 Mendel Leisk, Oct 24, 2025
  17. pasadena_commut
    2,590
    768
    Southern California
    Legally it probably depends on the locale. In California we are supposed to place it in containers and take it to a toxic waste pickup site.
    I can't think of a simple and cheap way to separate glycol from water, which would at least reduce the volume greatly for fluids from a flush after a drain. Distillation would work, and while it is simple, it is anything but cheap. For the original glycol/water mix it wouldn't make much sense to try to separate it since it would only change the volume by about a factor of 2.
  18. Mendel Leisk
    41,334
    Exactly, and with a simple drain there’s not much to deal with, just the original volume. But when some jokers hooked up a garden hose…
    #38 Mendel Leisk, Oct 24, 2025
  19. Hayslayer
    Hayslayer Active Member
    390
    219
    Pretty sure the coolant in Post 12 and also Pentofrost A4 are 100% direct replacements for the Toyota Super Long Life Coolant (pink coolant)
    Also pretty sure this thread needs to get some type of award for making one of the most simple things about a Prius into Super Long overcomplicated.............
    CR94 likes this.
  20. priumium
    priumium Member
    104
    26
    Sweden
    Just to validate, G12 and G13 is not something mentioned on US coolants?
