Toyota safety sense
Discussion in 'Gen 5 Prius Technical Discussion' started by HamiltonPrius, Oct 11, 2025.
  1. otatrant
    otatrant Active Member
    276
    180
    San Francisco
    2023 Prius Prime
    XSE Premium
    Partially. Probably more accurate to say that the car works very smoothly with Toyota Connect.
    The car needs an internet connection to get a route. This can be through a home wifi connection before you leave home or if using Wireless CarPlay it will then use the cell phones data connection. You can also use bluetooth tethering but you don't get the iOS apps to display on the head unit. For example Waze on the head unit is much better than Waze on the iPhone.
    The internet connection is not important to the built in navigation as you drive unless you need to reroute. I haven't tested this very thoroughly but based on my observations when driving this is the case. For example I park in a garage and Starlink does not work when it can not see the sky. For a couple of minutes before Starlink orients itself I have found I can not send a destination to the navigation nor can I use the voice assistant to search for a destination nor type in a destination with the onscreen keyboard.
    In the case of losing the internet while driving (eg driving through a tunnel) I haven't seen the built in navigation stop functioning.
    The head unit can also connect to a mobile wifi hotspot. The downside of connecting to a mobile wifi hotspot is that wireless Android and wireless Apple CarPlay use both bluetooth and Wifi at the same time and the car head unit can only have one wifi connection at a time. I keep my car connected to my Starlink Mini and used wired Apple CarPlay. This enables me to use the voice assistant, built in navigation, and Apple CarPlay.
    VelvetFoot and Gokhan like this.
  2. Gokhan
    Gokhan Senior Member
    6,026
    2,393
    Paramount CA
    So, it turns out that on my Gen 4 Prius Prime with the large multimedia headunit, the traffic info on navigation is most likely coming from the HD radio. You can apparently also receive it from Sirius XM, but I think that requires subscription to that particular service.
    VelvetFoot and otatrant like this.
  3. VelvetFoot
    VelvetFoot Member
    339
    84
    New York State
    2026 Prius
    (Getting closer to getting the car now-maybe a week or two.)
    Do you think it's possible to use the built-in navigation without ever signing up for Toyota Connect? I currently plan to deny the TC signup at delivery and use CarPlay. Could the built-in nav somehow use the phone's connection, rather than the car's?
  4. Trollbait
    12,461
    From the Traffic Jam Assist needing the subscription in the US, it appears the connection is needed by the nav system to access map data.
  5. Hammersmith
    Hammersmith Senior Member
    2,236
    2,245
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    no
    Also, if you deny all services at delivery, you won't be able to use the keyfob to start the car. Might not be a big thing for you, but you should be aware.
    VelvetFoot likes this.
