>500 miles per tank
Discussion in 'Gen 2 Prius Fuel Economy' started by Has Raf, May 9, 2025.
  1. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    Managed to get >500 miles out of one tank in my gen 2 for the first time this year, thanks to the increase in temp. The mpg doesn’t reflect it truly though, for some reason.
    52,335
    how many gallons did you use?
  3. Has Raf
    Has Raf Member
    180
    43
    About 10.5 US gallons.
  4. bisco
    52,335
    congrats!
    the readout has always been optimistic, but that's a bigger discrepancy than usual.
    but often times, you have to average a number of tanks together to get a truer number.
    Has Raf likes this.
  5. ebikeman
    ebikeman Member
    116
    Northwest
    Nice!! most I can get is about 200 miles.
  6. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    There is something wrong with your car, then. 500 miles per tank should be easily achievable.
  7. Isaac Zachary
    Isaac Zachary Senior Member
    2,671
    1,380
    I used to get about 600 miles out of a tank on my 1985 VW Golf N/A Diesel, or about 10 gallons for 600 miles. Of course diesel holds more energy. Still, if it were gasoline, at the same efficiency, I'd still have gotten around 540 miles out of a tank.
  8. Hayslayer
    Hayslayer Active Member
    457
    264
    I'm not sure a Gen 2 can get 20mpg and not have a CEL for something, unless you have a fuel leak, which would be the suspect if you're showing decent mpg (40+) on the mfd, but having to refuel often at 8-10gal a pop. If you're getting 200 between fill-ups but only putting 4 or 5 gal in the tank, that's another issue.
    Isaac Zachary likes this.
  9. Mendel Leisk
    41,850
    I'd much rather track mpg (more succinctly, liters per 100 kms, being in Canada), than play chicken with a down-to-the-dregs tank.
  10. ebikeman
    ebikeman Member
    116
    Northwest
    Usually about 7gal. with one or two dots on the gauge.
