Another 12V failure
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by RX808, Oct 31, 2025 at 6:02 PM.
  1. RX808
    RX808 New Member
    26
    2025 Prius Plug-in
    XSE Premium
    Prii:
    I thought I would be the person to avoid 12V issues. Turns out? I'm not. 2025 XSE Premium. Sat in it for 20 minutes ACC on - listening to the radio. Got out, took a walk, came back to a 12VDC dead car. Called the local dealer (12 blocks away!!) and they told me to use Toyota roadside. "Just press the button". OK, I'll try it.
    Say...you know what the button needs to work? 12 volts, evidently. Called the dealer back, got Toyota Roadsides 800 number called them, had a tow truck sent. For a jump.
    Called the dealer back, asked if they could look at it, maybe loadtest the battery. They're booked up for the next 2 weeks, though I could drop it off and if they had time....
    Yeah. Thanks, Toyota!
    Anyway: Point of the post - Any recommendations for a jump pack? I don't think it needs much capacity - we're not cranking the engine - and I'd like it to live happily ignored somewhere for long periods of time. Under the seat, maybe? So it has gotta hold charge as well as be happy...OK, not happy...survive likely in-car summer temp AND winter temps (down to -40F)
    Should I just spin the wheel, buy something cheap and see what happens?
    Thanks!
  2. Hammersmith
    Hammersmith Senior Member
    2,271
    2,269
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Project Farm tested quite a few and found the Gooloo GP4000 to be good for the money(currently on clearance sale for $90). I'd tell most people to go with a smaller unit like the GP2000 to save some money, but you might need a more powerful unit because you need it to work in extreme cold. Pretty much all of the consumer-level units lose a huge chunk of their capacity at low temps.
    A top NoCo(GBX155) tested better, but was 4x the price($370).
    I've been using a NoCo GB40 for the last several years. It usually gets the job done, but it's failed me a couple times. Usually when very cold(-10F to -20F) and sitting unused for a couple months. If I was buying again, I'd probably consider one of their more powerful units, or at least a GBX45 instead of the regular series GB40.
    You can often find good deals on boost packs during Black Friday/Cyber Monday sales.
    #2 Hammersmith, Oct 31, 2025 at 7:05 PM
  3. BiomedO1
    3,375
    1,755
    SacTown, Ca
    FWIW; that jump pack isn't going to work if you pull it out from under your seat in -40F. You need to drag it inside with you, if you want it to work.
  4. Hammersmith
    2,271
    2,269
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Another option for extreme cold situations is a capacitor-based jump pack. They can harvest the low current from the "dead" battery, boost it up, and then deliver it back in a burst to get you going. They can also be more quickly charged using standard methods, but they don't hold their charge as well as Li-Ion, Li-Po, or LFP options do. Increased cost and larger size are some of the drawbacks. Depends on how critical a person's situation is.
  5. bisco
    51,735
    i got a deal on a noco gb 20 or 30. you don't need much to start a prius, but you want one with an override button in case the battery is too low. they need to detect a certain amount of voltage to work otherwise.
    the override bypasses the reverse polarity feature, so you have to be careful
  6. otatrant
    otatrant Active Member
    296
    184
    San Francisco
    2023 Prius Prime
    XSE Premium
    I haven't had any 12 V battery issues in quite a while but had plenty when I first got my Prius Prime XSE premium. The practices I have changed.
    1. Keeping the car in ON instead of Accessory mode if I am going to be in the car. This keeps the traction battery supplying power to the 12V auxiliary battery.
    2. If I am going to plug in and don't want to have to unplug when charging is complete I leave the car in room mode and lock the doors with the physical key. You need to turn off the headlights and climate control if you don't want to use excess electricity when you are away.
    In my experience most of the trouble I was having was due to leaving the EVSE attached to the car after the car had completed charging. Puts the auxiliary battery in a depleted state where little extra uses of it cause it to die. I credit those two changes to me not having any 12V battery issues in over a year.
    BiomedO1 likes this.
  7. ChapmanF
    17,943
    I think you probably mean keeping it in READY.
    Unless gen 5 has changed this, you can choose from OFF, ACCessory (one button push, no brake), ON (another button push, no brake), and READY (button push with brake).
    READY is the only choice that will keep the 12-volt battery charged. ACC will discharge the 12-volt battery, and ON will discharge it even faster (because more of the car's electrical loads are being powered).
    KMO likes this.
  8. otatrant
    296
    184
    San Francisco
    2023 Prius Prime
    XSE Premium
    You can see in this WebAuto youtube video that as soon as he powers on the Prius Prime current begins to flow into the auxiliary battery from the traction battery.
  9. RX808
    RX808 New Member
    26
    2025 Prius Plug-in
    XSE Premium
    Thanks! I didn't know they existed - now I have another rabbithole to go down :)
  10. VelvetFoot
    VelvetFoot Member
    367
    96
    New York State
    2026 Prius
    #10 VelvetFoot, Nov 1, 2025 at 9:09 AM
  11. ChapmanF
    17,943
    Backing that video up seven seconds before where you set it to start, you can see that he steps on the brake pedal first and then presses the power button. Reviewing the choices from #7 above, that puts the car in READY.
    • OFF
    • ACCessory (one button push, no brake)
    • ON (another button push, no brake)
    • READY (button push with brake)
    He said "on" but that's just a matter of misspeaking. He definitely put the car in READY, which is the only choice that will keep the 12-volt battery charged. ACC will discharge the 12-volt battery, and ON will discharge it even faster (because more of the car's electrical loads are being powered).
    KMO and Brian1954 like this.
  12. KMO
    KMO Senior Member
    1,913
    657
    Finland
    2023 Prius Prime
    They have actually changed this, optionally. There is an "ACC customise" option in the menus which removes the distinct ACC mode from the power button sequence, and instead has the ACC functions operate automatically while "OFF".
    So you can turn on the radio after entering without pressing the power button, and when you turn the car OFF, the audio + display will remain on until you get out.
    otatrant and VelvetFoot like this.
  13. bisco
    51,735
    so they're actually encouraging running down the 12 volt now?
  14. Mendel Leisk
    41,163
    Did you take composition lessons from Trump? ;)
    Anyway, what lead you to think a jump pack is what you need? That's basically a last-ditch rescue when you've toasted your battery, to get you somewhere where you can recharge or replace it. Not exactly a panacea.
    What's your parking situation? Do you have a garage with 120 volt AC outlets, similar but carport, underground parking lot, street parking?
    I would look into smart chargers, 5 amp rating at most.
    And never sit in the car listening to the radio in accessory mode: the battery just doesn't have the capacity.
    Last battery I put in our 2010 was in September of 2015, we're doing around 3000 kms a year, and it's still testing like new.
    otatrant likes this.
  15. ChapmanF
    17,943
    My battery isn't toasted and I have a jump pack anyway.
    It's like portable peace of mind, plus it allows putting smiles on other people's faces when you see them standing forlornly around a car in a parking lot.
