Transmission fluid
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by I hate cars, Nov 1, 2025.
  1. I hate cars
    I hate cars New Member
    Usa
    2024 Prius
    2024 Prius Le 2wd
    nothing on the manual nothing online or on Toyota!!! I keep seeing 2 different answers. How do I know which is right??
  2. Hammersmith
    Hammersmith Senior Member
    2,313
    2,334
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You want Toyota TE fluid.
    Priuses before 2023 used WS. Starting in 2023(gen5), they now use TE.
    You should be able to easily go 6y/60k miles between changes. When you do need to change it, you'll need a jug of this:
    E-Taf,Te
    The capacity of the transaxle is about 3.7L, so a single 4L jug should do you.
    You'll also need two of these(one for the fill and one for the drain):
    Gasket #9043018008 | Autoparts.toyota.com
    Always replace plug gaskets when changing fluids.
    Jack90210 likes this.
  3. Mendel Leisk
    41,375
    Except this on page 522 of the Owner's Manual:
    And if you're changing it yourself:
    douglasjre likes this.
  4. BiomedO1
    3,541
    1,835
    SacTown, Ca
    The simple answer is that both are correct, but for different reasons.
    1. Toyota's Lifetime fluid, I interpret it's as Toyota is no longer obligated to warranty the unit. Their "bean counters" has determined that fluid has a 95% chance of lasting the 150K miles warranty mandated by CARB states.
    2. Those of us that has done ATF changes can verify that fluid gets dirty around 15K-20K in service. It makes sense since there's break-in and initial gear wear. While the transaxle doesn't undergo the harsh environment of an engine; there is wear, contamination, and chemical break-down of that fluid over time. We believe that dumping out the ATF after break-in would be prudent. Cheap insurance....
    I've personally done two ATF changes in my old Prius C, before it got totaled out. The second change, around 90K miles, the ATF was much cleaner than the first original ATF change at 20K miles.
    Hope this helps.....
    FWIW; Subaru has the same approach. Strangely though, there's a footnote in the maintenance manual that states towing and 'under extreme conditions', the ATF should be changed at 25K mile intervals. Well my sister has 135K miles on hers and it started to intermittently slip for about 2 seconds randomly. I was out there on vacation and diagnosed it. All maintenance services was performed at the dealership. She's on really good terms with her service advisor; so I played 'bad cop' and nailed them down to 'going off pavement is considered extreme conditions.' Told him my sister's driveway is a mile long gravel road and do you ask any of your customers if they leave the pavement? Ahh; it a Subaru - why do people buy these cars? They did a 'complementary', customer satisfaction, brand new replacement and gave her a free loaner for the 3 weeks it took to get done. I think there's also a pending class action lawsuit on that issue, which made it easier to get that outcome.
    #4 BiomedO1, Nov 1, 2025
  5. Hammersmith
    2,313
    2,334
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I've been thinking about this for the last week or two. Why the initial fluid gets dark early but later changes don't in a low-wear unit like the eCVT. I'm starting to think it's just byproducts of the aluminum housing reacting with the fluid. Over time, a boundary layer forms over the metal and the new fluid stops being able to interact with it. Different mechanism but same effect as seasoning a cast iron pan with oil.
    The question is whether the byproducts affect the performance of the fluid at all. It's very possible it's only a cosmetic change and the performance of the fluid doesn't change. The only thing the fluid really does is lubricate the planetary gear set. It doesn't have to do anything near the same amount of work as in a regular CVT or automatic transmission.
    Unless someone can show me hard data that the fluid's performance actually changes significantly after the first 15k-20k miles in an eCVT, I'm going to stick with my plan for either 6y/60k or 7y/70k.
    Trollbait and BiomedO1 like this.
  6. BiomedO1
    3,541
    1,835
    SacTown, Ca
    The heating and cooling cycles of the fluid will eventually break-down, effect the performance characteristics of the fluid. I don't have any data on that, but it's a well known fact that heat plays a major role in a fluid's chemical structure. It would be helpful, if someone doing their first ATF change, say about or beyond 150K - would send their ATF out for analyst.
  7. Hammersmith
    2,313
    2,334
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, but an eCVT is a completely different animal than a standard automatic transmission. You can't use old wisdom gained from experience with them on a new system that uses completely different principles.
    An typical automatic transmission uses clutch packs that have dozens of individual friction discs that engage and disengage under load. It's that friction that creates the heat that necessitates transmission coolers and can breakdown ATF. The friction material on those discs can also break away and contaminate the fluid. (which eventually leads to the reason you never want to do a first fluid change on an automatic transmission with over 100k miles) In the case of an automatic transmission, an early fluid change is not a bad idea because you get rid of any loose friction material that got knocked off during the initial wear-in. You also get rid of any metallic debris from the metal parts mating together(same reason as doing your first engine oil change at 500-1000 miles)
    In a transfer case or differential, an early change is a good idea because of the mating of the metal parts. See the Car Care Nut's recent video on his Lexus GX460 where he changes the transfer case and diff fluids in his GX that's only 2.5 years old with 20k miles. That stuff was UGLY(but normal).
    But none of that applies to the eCVTs in most Toyota hybrids. There are no clutch packs or friction discs creating significant heat. The planetary gear set at the heart of the unit is small and doesn't create nearly the wear-in debris that a diff or transfer case does. Besides, the two motor-generators(MG1 & MG2) create far more powerful magnetic fields than any little magnet on a drain plug. I have to believe any metal debris gets pulled out of the fluid immediately and sticks to the MG housings. So if there's no metal debris in the fluid, no friction material in the fluid, and no significant heat from friction discs, is there any real need to do an early change just due to color(which might just be cosmetic)?
  8. ChapmanF
    18,111
    The gen 1 transaxle had a removable pan with a magnet in it. Mine had attracted a pretty thick coat of metal silt. For whatever reason, it doesn't all seem to stick to the MG rotors.
  9. VelvetFoot
    VelvetFoot Active Member
    576
    197
    New York State
    2026 Prius
    It seems the original poster had a FWD, but the rear trans on the AWD uses the same stuff.
  10. Hammersmith
    2,313
    2,334
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Correct. If you have an AWD, you get the joy of having to buy TWO jugs of TE and throwing out most of the second jug.
    I'm soooo looking forward to that. /s
  11. Mendel Leisk
    41,375
    Brings up a point: I did find a Toyota document regarding Toyota ATF-WS (transaxle fluid for gen 2~4), saying to only use fluid from newly opened bottles. Perhaps applicable to the new fluid as well?
    funny thing, it was some sorta white paper on ATF-WS, and this is NOT noted in repair manual. What IS noted, and the writers go to increasingly Byzantine lengths about it with each successive generation, is temporary reinstall of fill cap, I think mechanics would mostly ignore this, just do the job fast.
    and likely goes without saying, but presumably “throwing out” involves recycling.
    Which brings up another point: sometimes engine oil recyclers balk at accepting the more exotic fluids, good to check. The last thing you want is to bring something to them, and it ends up poured out round back. :(
    #11 Mendel Leisk, Nov 2, 2025
  12. priusasa
    priusasa Junior Member
    73
    28
    2023 Prius
    I changed mine and the old fluid that was already there was low. Can you tell me how much old liquid you will drain? So you need to fill it untill it starts to comes from filler hole. But before I drain my old fluid, I looked the inside with a snake camera and it was way less. I think I drain around 3 LT but filled 3.7 LT back. The car was pretty much on the level to the surface by the way.
  13. ColoradoBoo
    ColoradoBoo Senior Member
    1,239
    825
    Monument, Colorado USA
    .7 LT difference isn't too much to worry about....be glad you got her topped off with the full amount! You saved a lot of money doing it yourself, for sure!
    BiomedO1 likes this.
  14. BiomedO1
    3,541
    1,835
    SacTown, Ca
    almost all of it will drain out, except for what's left in the oil passages. The 0.7 differential could've been slightly out of level. The fill plug on my gen4 is back, next to the output shaft. So if the car is slightly nose down, I could probably get a little bit more ATF into it. Bottom-line, it isn't going to make a difference - as long as to put in at least as much as you took out, you should be fine. It's the people that keep adding more ATF (4+ quarts) that don't realize they're filling the wrong port. The gen2 & gen3 transaxles I've done always took at least 3.5qt give or take a few ounces and always drained at least ~3.2qt+.
    PS: I'm assuming you meant quarts not liters. 3.7L is just shy of 4 quarts. I usually have a few ounces left, after the ATF starts dribbling out. I believe your suppose to use the more expensive ATF-TE for gen5, NOT the ATF-WS for gen4 and previous iterations.
    #14 BiomedO1, Nov 13, 2025
  15. Mendel Leisk
    41,375
    And that surface was level?
    With the car level, this is how to check the level:
    Yes, with the car level. Instruction says to run the car in maintenance mode, then check level again. In practice that last check seems very onerous. I did it first time, absolutely no change. I'd just check for leaks, but if you installed both bolts correctly, with the washers, you'll be good.
    Note, the attached 5th gen Repair Manual instruction drones on excessively, I would edit thus:
    And ignore everything thereafter. I can't even make head-nor-tail of it...
    #15 Mendel Leisk, Nov 13, 2025
  16. plainv70
    plainv70 Junior Member
    Naperville
    2024 Prius
    High oil temperatures do result in faster lubricating oil degradation. Heating/cooling cycles, such as those encountered in normal driving are probably not an issue. Operating conditions that put a higher load on a transmission (towing, very high speeds, long term high ambient temperatures) will accelerate the lubricating oil oxidation and breakdown. However, current transmission fluids have increased additive packages that stabilize the oils and allow for significantly extended change intervals.
    Transmission fluids are not exposed to exhaust gases that diminish an oil's efficacy and limit it's working life.
    Notably, color is not a good indicator of oil, motor or transmission fluid, condition. The breakdown products of the oil stabilizers are intensely colored compounds, you could call them dyes. A little bit can darken an oil a lot--without affecting the lubricating properties of the oil. A brief period of higher temps/load could produce enough of the "dye" to darken the oil in a recently flushed or new transmission. Extended change interval oils are more likely to darken significantly compared to their predecessor products.
    As you state, the best measure of an oil is a physical (i.e. viscosity) and chemical analysis.
    Toyota's long
