Where to get a rear axle bushing tool?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius DIY nut, Nov 1, 2025.
  1. Prius DIY nut
    Prius DIY nut Member
    92
    43
    Ontario, Canada
    I recently got 300k km on my 2012 Prius. I checked rear suspension trailing arm bushings and they may need to be replaced. I could not find a tool online to remove and install them.
    The part I want to replace is called
    BUSH, REAR AXLE CARRIER Genuine Toyota (4872547030)
    Thanks in advance.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,497
    Taylors, SC
    I would go to Advance, Auto Zone or O'Reilly and rent a ball joint removal and install press tool.
  3. Prius DIY nut
    92
    43
    Ontario, Canada
    Thanks. I'll check if Canadian Tire, Carquest or Napa have that tool for rent. We don't have the above parts chains in Canada. I'll try freezing the bush and then hammer it in place if no tool can be sourced like some people did for other Toyota bushings.
  4. fredp123
    fredp123 Junior Member
    TN
    Were you able to find the appropriate tool? I’m not finding any tools that explicitly are for the Gen 3 Prius.
