Oil drain plug gasket (washer) question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rudiger, Nov 3, 2007.
  1. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    I went to two different Toyota dealers to pick up an oil drain plug gasket and got two different parts:
    90430-12031 - Made of aluminum - ('crush') washer.
    90430-12028 - Made of lighter, non-metal, compressed material, half the price of the aluminum 'crush' washer.
    While I suspect that the first aluminum 'crush' washer is the actual, correct part, would there be any problem (maybe even a benefit) to using the second, cheaper washer?
    Could it even be possible that, unlike the more expensive aluminum 'crush' washer that permanently 'forms' to the plug and hole, the second washer does not form as permanently and can be reused for many more oil changes?
  2. stukid
    stukid New Member
    30
    <div class='quotetop'>QUOTE(rudiger @ Nov 3 2007, 07:46 AM) [snapback]534264[/snapback]</div>
    The 12031 is the factory gasket, and can be reused numerous times, while the 12028 is the usual replacement, to be replaced at every drain interval.
    The 12028 can be purchased in bag sets of 10 per bag.
    Consult your service manual for proper drain plug torque spes. The 12028 can and will crack if overtightened. (which is better than stripping the threads!!)
  3. rudiger
    696
    45
    Cincinnati, OH
    Thanks. I guess that makes sense.
    If you want to change the gasket at every oil change, use the cheaper 12028.
    If you want to reuse the gasket and make it last for a few more changes, it's better to use the more expensive 12031.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I have only ever used the fibre gaskets and they can be reused may times over. My RAV4 is still using the original gasket at 177,000km I haven't seen an aluminium washer on a Toyota except on vehicles with a big drain like early Crowns and Coronas.
    Good advice stukid, There is no need to over tighten the sump plug, I use a short combination spanner and the oil filter is tight enough if hand tightened as tight as you can without tools.
  5. rudiger
    696
    45
    Cincinnati, OH
    Would the torque recommendation for the oil drain plug (28 ft-lbs was what I was using with the OEM aluminum washer) differ depending on the type of gasket used?
  6. shiyi
    shiyi Junior Member
    if people are reading this in 2025 like me.
    They dont sell the 90430-12028 washer anymore
    blue one are the way to good
