Replacing coolant parts as a safe measure
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Inspector Gasket, Nov 7, 2025.
  1. Inspector Gasket
    Inspector Gasket New Member
    Mississippi
    I have a 2016 that I’ve never done any maintenance to other than oil change and changing the converter and engine coolant once and replaced front break pads recently. It’s got 171k miles on it. I’d like to change coolant again and due to mileage should I have them go ahead and replace the converter water pump even though it’s currently working ok? And is there anything else I should go ahead and replace while I’m at it concerning the coolant systems? Economy being what it is I want to drive it long as I can before having to buy another. With its age I’m going to need to do a lot of upcoming maintenance, shocks, struts, rear brakes. But for now I’m concerned about the coolant systems as it can ruin the hybrid battery if the water pump goes out. I’m elderly and don’t want to get stranded. Sometimes I hear a wamp wamp noise like a bad tire which can be the water pump noise but hubby keeps telling me it’s different road pavements. Also what about caring for the generator? Also my dealership has never had anyone trained to check the viscosity of my brake fluid and they aren’t equipped to change that either. It’s terrible but I have to use independent mechanics as very few Toyota dealers are trained on the Priuses. I don’t u derstand this because there are lots of them on the road but no one seems to want to work on them. The dealer told me to leave my brake fluid alone that if it’s not leaking to not touch it. They don’t have the pressure equipment to change it. I realize this is a lot of questions in one post. But my car has been neglected. I plant to do the converter and engine fluid first. Then rear brakes, then shocks then maybe see about this brake fluid issue and then whatever else y’all suggest. My husband is elderly in bad health so we won’t be doing out own repairs. Not unless a cave man could do it.
  2. Get your heat exchanger bypassed, change water pump, plugs, pcv valve, CVT flush and just drive it. We have the most economical and reliable version of the Prius ever..don't over think it and worry.
    Paul Gregory likes this.
  3. bisco
    52,544
    when you say it has been neglected, are you the first owner and have neglected it, or was it a previous owner?
    if you purchased it used, how many years have you owned it, and how many miles?
    do you know the full maintenance history, and do you have the maintenance schedule that came with the car?
  4. BiomedO1
    4,361
    2,288
    Left Coast
    Welcome and sorry to hear that.
    My sister lives in northwestern Mississippi and gas prices are so cheap - return on investment is questionable at best for paying the extra money for a hybrid - relatively speaking.
    There's a litmus and glycol test, that can be done to check the condition of your coolant. Changing them both at the same time, just makes it easier to keep track of what's been done.
    IMHO; Shocks and rear brakes needs inspection - Unless they can prove that there's a problem, they don't need to get done. That's a want, not a need.
    You should install one of these P10 HUD unit:
    It plugs into your OBD2 port and monitors your engine temperature. Alarm limits are programmable and will beep at you. Your onboard warning lamp is set for 248F+ before it lights up, I'm pretty sure without an alarm. Normal operating range is 185F-210F, so early warning system when your electric water pump is beginning to fail. If you don't notice that coolant lamp flashing at you, you could pop the head gasket or worse.
    The transmission ATF should probably be changed, It's probably black as tar with 171K on it. Simple drain & fill around $150-$200. That fluid should be ruby red.
    Spark plug replacement is overdue; if that's never been done. I believe that interval is around 120K miles per OEM.
    The 2016-2018 had issues with the exhaust gas heat exchanger leaking, so you should check the coolant levels in BOTH coolant tanks every once in a while - make sure it isn't getting low. Someone above mentioned by-passing it, to keep repair cost down. Doesn't need to be done unless you keep losing coolant out of the passenger side coolant tank.
    Good Luck...
    FWIW: I actually talked my sister out of buying one, because of the lack of qualified mechanics along with the cheap gas prices over there. The economics coupled with neither of them being able to 'wrench', left them vulnerable to dishonest mechanics. At least with a regular car; you can take it down the street, to a more honorable mechanic.
    #4 BiomedO1, Nov 8, 2025
  5. Doug McC
    Doug McC Senior Member
    1,084
    426
    Midwest
    2022 Prius
    Assuming you had the coolant changed the first time about when the maintenance schedule called for you are right on target for the second coolant change. If so, while you COULD have the pump changed out, there’s no reason too (other than your own concern about it). So if it’s for your peace of mind, go ahead and waste the money.
    Concerning the brake fluid change: your dealership does have anyone trained?! Find a Toyota dealer, or at least a different one! If they are a Toyota Dealership, that doesn’t make any sense! Find a different dealership.
    What “generator are you worried about? Do your mean MG 1 or MG 2? If you’re not having any issues with them DON’T let anyone touch them (especially a dealership that can’t even change your brake fluid).
    If you have that many miles on it and have had no trouble with the heat exchanger, for heaven’s sake don’t bypass it!
    No offense, but your concerns are leading you to fix things that aren’t broken, which will most likely lead to more problems.
    TresK3 likes this.
  6. Mendel Leisk
    42,055
    First off, just editorial, when you say "converter" it's likely you mean "inverter".
    Gen 3 engine water pumps have been prone to failure, around 150k miles. Could be the inverter water pumps are similar, though maybe last longer, due to less taxing requirements? I believe gen 4's are similar style pumps.
    I'm thinking to change the engine water pump on our gen 3 around 100k miles, if it ever gets there (currently around 105k kms...).
    The inverter water pump I'll "maybe" change not long thereafter, but, at least for gen 3, it is a ROYAL pain, apparently requires removal of the inverter, no way around it. Doubly frustrating because the inverter water pump, which is below the inverter, is quite reachable from underneath the car, but it's fasteners require access from above, and the dang inverter's in the way.
    How much are they asking for this service?
    #6 Mendel Leisk, Nov 9, 2025
  7. Inspector Gasket
    Mississippi
    I haven’t asked how much to replace the inverter pump yet. But I googled how to do it and YouTube says on my 2016 that you just take the front bumper off and it’s right behind the headlight. So it shouldn’t be too bad. That’s why I was thinking about doing it. So I should probably replace the engine coolant pump and the inverter pump both as I have 171,000 miles.
    I did change the plugs. I worry because I’m elderly and drive 4 hours round trip to my doctors. I live in very rural area with no family and most friends have died off. I worry about breakdowns between cell towers. Then again ai sti ex replacement parts aren’t as good as original parts and messing with stuff could be asking for trouble. I’d rather head something off rather than get stranded. But then I might be better off keeping my money and just saving up for a new Prius. Just trying to make the wisest safety and also economic choices. Iused an independent mechanic to change my inverter and engine coolant before since the dealership doesn’t do any of this stuff. I live in a very backwards southern state area and it’s had to find dealerships that keep reliable mechanic staff. This independent shop has been good but I’ve only had the coolant changed they and nothing else. They are mainly Honda and Acura specialists. The work on Prius some but not a lot.
    I’m the original owner, only have done front brakes, changed oil, changed spark plugs, changed inverter coolant and engine coolant once at 75k miles I think. I accidently changed the coolant early I think. Other than that nothing ever has been done to it. Runs like a charm. Still getting great gas mileage at 171k. I live my old car. Wish it could last forever. Hate what they’ve done to chop down the body of the new models, removing spare and all that, blind spots etc.
    I read somewhere that the braking generator that generates hybrid battery electricity is extremely expensive to replace and was wondering if there was any maintenance requirement to that specifically.
    I live in mid to NW Mississippi so you understand. Jackson might have a decent dealer repair shop but I haven’t tried them. For coolant change I used Ridgeland shop called Car Shop. They are honest and don’t try to sell me a lot of stuff. They are bad about not wanting to use OEM coolant fluid and parts. But then my own dealership doesn’t use oem parts either. The dealer refuses to replace just the shocks and gets the whole Monroe strut and shock system! It’s labor intensive to replace only the shocks as it needs a special compression tool. But in spite of lack of mechanics I love my car and have avoided repair shops so far. Mississippi sucks for labor, untrained or no mechanics at all and twice the repair costs as other states. Mostly they have high mechanic turnover at dealerships. They don’t invest in a lot of basic maintenance equipment. No one seems to specialize in Prius. I guess because most people trade them before they need anything. I love mine to death and can’t imagine driving anything else. I just hate U.S.A. cars have not caught up to this good of technology.
    #7 Inspector Gasket, Nov 9, 2025
  8. Inspector Gasket
    Mississippi
    I also read that brake fluid should be tested for moisture content every 20,000 miles and flush the brake lines if they get moisture in hem. My dealership doesn’t perform this test. They don’t have the equipment to do a brake line flush. They said with 171k miles now that if I had someone flush it that it would probably cause brake line leaks.
  9. Doug McC
    1,084
    426
    Midwest
    2022 Prius
    I may be mistaken: I seem to remember that the water pumps on the 4th Gens were of a different design than the 3rd Gens. The inverter/converter assembly is significantly different that’s for sure.
  10. Agree with everything but this...I've seen higher mileage G4's have it fail on them. Better safe than sorry, especially for her situtation.
  11. Inspector Gasket
    Mississippi
    I don’t bother with the litmus test. That is not the issue with a Prius. With Prius the scheduled coolant replacement has to be done because one the first one is done it can loosen debris. This debris causes blockage issues later so the first one must be done at 150k mikes I think. I did mine at 190k. The second one and from then on must be done every 50k to help keep some of that debris out. Otherwise the whole system will clog up and there will be multiple components clogged which will cause all kinds of gaskets to blow and will be way expensive. If the water pump blows without enough warning, and sometimes the gauge doesn’t warn then it will ruin the hybrid battery. So that’s why I’m asking all these questions with a car with age and a whole lot of wear. At the time ai bought it I wasn’t aware of lack of mechanics. There seemed to be more mechanics at the time. But in Mississippi I’ve been scammed at dealerships on was powered cars too. Chrysler on my jeep told me they replaced gaskets and truth is they couldn’t get one parts and they Cali ed they did t use after market so they did something worse. They kept it for weeks on end claiming g they were waiting for oem part and then just squirted silicone where it needed the gasket on the engine leak. many U.S.A. cars need multiple repairs way before a Prius does. I’ve been very happy to have 171k so far and not turn a single wrench yet. That being said our economy is so upside down right now that even maintenance is extremely expensive shock and strut replacement is $2,500 for example. Just doing maintenance and binging everything up to top notch could cost me half the price of a new car. These repair prices are for any car. Labor is insanely stupid. The original struts are very heavy duty. After market struts are weaker. But no one wants to preserve the original struts because it’s labor intensive to only replace the shocks and requires a special tool. I may read the Google reviews and check with a dealership in Jackson. Perhaps they are keeping trained mechanics, There are at least two. One has bad Google reviews and I think the other didn’t. I don’t trust dealerships most of all in Mississippi. They could care less about care after the sale and are only all about the sale it seems.
    #11 Inspector Gasket, Nov 10, 2025
  12. Inspector Gasket
    Mississippi
    My big fear about the water pumps blowing is damage to the hybrid battery or other extensive repairs should that happen. I’m having anxiety about that. But then also understand causing more problems by having people jack with something that is still working, coarse of replacing all the coolant is $400. Not sure how much coolant is lost either when one blows. It one jug not a big deal. I’m kind of trying to not get into retirement and save that for saving toward my next new Prius with tariffs etc. and trying to budget repairs with social security fixed income. We don’t have uber or any public transportation. We don’t even have taxi service. So if I take my car two hours away for repairs and they have to keep it I’ll need to rent a car.
    BiomedO1 likes this.
  13. Inspector Gasket
    Mississippi
    I’m going to run all this by the head hybrid specialist at Car Shop in writing in Jackson and just express my concerns. They don’t push additional work and seem to strive helping me save money by always saying this a like this can wait and that can wait. While they don’t specialize in Prius they do work on another Asian model hybrids with some similar technologies. If they aren’t comfortable doing a particular repair they will tell me and I’m going to ask which dealership in Jackson it the trustworthy one if any of them are or if they have other recommendations of where to take my model. It’s terrible that things are this bad in my state but they are. Worst scenario is my Prius dies a hard death and I have to buy a recent but used car. I haven’t owned a car with this many miles in a very long time. When I worked I traded every 3 to 5 years simply because I was single without family close and didn’t want fears of dishonest mechanics or dangers of breakdowns. Now I’m in my senior years with the same anxieties but without my working income, healthcare what that is etc etc. But I appreciate all yalls input and welcome anymore ideas and I’ll run that by Car Shop and maybe one other dealership in Jackson. My dealership here does have a Toyota specialist, but not one trained on Prius. So they won’t touch it without their mechanic getting all his scheduled training. Would y’all trust this local dealership if the person did eventually get the training knowing ai might be his first Prius to work on. I don’t understand this because I see tons of Prius’ on the road daily in my area. Where the heck do they take their car? Far as I know they simply aren’t breaking down. A lady at a grocery store near me drives one and I know she’s not doing anything to hers. She did have to have someone drain her fuel system from getting bad gas once though. I knew one guy that used a local shade tree guy but now he won’t talk to me about how that’s going. Ha!
  14. Inspector Gasket
    Mississippi
    One thing I like about Car Shop, an independent mechanic is they are great about answering questions. When I go into Toyota they refuse to let me speak to the mechanic. They no Ionger allow that and the girl taking repair request is not knowledgeable about mechanics and can’t answer anything. Sometimes I can get her to relay back and forth but things get lost in translation and they try to refuse to ask too much. There is no need for us to suffer as Prius owners because if you watch YouTube videos in repairs they seem to be very simple to work on. If they are so simply and wonderfully designed why in heck doesn’t anyone work on them? I didn’t realize how bad things were until ai asked about testing the brake fluid and found out they don’t actually do routine maintenance. That was a huge shocker! Routine maintenance? They didn’t say they don’t do routine maintenance they just said they don’t test the brake fluid. Well my manual says that’s an every 20k test. Some people tell me a lot of those manual recommendations aren’t needed. This confuses me.
  15. Doug McC
    1,084
    426
    Midwest
    2022 Prius
    Well we have people advising her to replace a water pump and now bypass a heat exchanger because they may fail at some point in the future, but at this time appear to be performing as designed. If we keep traveling down this route we might as well tell her to either have the car completely rebuilt with all new parts or just scrap it and buy a new one. Heck, she might as well be asking a stealership for advice. :cautious:
    syncro87 likes this.
  16. Mendel Leisk
    42,055
    Yeah the exhaust hear recovery components either leak, or don't. And if it hasn't leaked by now...
    It is the early 4th gen years that are prone for this, but who knows, maybe OP's build-date is before the problem.
  17. BiomedO1
    4,361
    2,288
    Left Coast
    $400 seems a bit steep for coolant replacement. It's a simple drain and fill, don't let them talk you into a system flush. That's what the OEM recommends, and why you have to do 50K coolant changes - after the initial 150K mile change. You don't get ALL the coolant out on a drain-n-fill, so the engineers shortened the coolant change period.
    There shouldn't be any debris in your coolant system, since it's a closed loop system. The only way debris can get in there is if there's a leak or somebody put something into it. You can get calcium buildup, if you don't change your coolant as prescribed or put tap water into your coolant reservoir - again, that's something being physically introduced into your cooling system..
    If your dead set on replacing those shocks/struts; either replace them with OEM or KYB shocks/struts. KYB manufactures them for both Honda and Toyota. That's about as close to OEM as you can get without the Toyota stamp on it.
  18. BiomedO1
    4,361
    2,288
    Left Coast
    That's garbage; I wouldn't allow an idiot like that to work on my car.
    An electronic brake fluid moisture meter is less than $20 on Amazon and the traditional way is with a chemical strip. I've moved to an electronic tester, though the accuracy is more questionable. Mostly due to the battery dying or getting weak. The test strips expire and needs to be stored under controlled conditions to maintain accuracy.
    That 'mechanic' that stated 'a brake flush @ 171K would cause leaks' is a lazy idiot. The rubber portions of the brake lines can withstand hundreds to thousands of psi as you apply your brakes. If there's actually a problem, they would see it as they're flushing the system.
    I replaced the rubber flex lines on my nieces car, just because the external portion of the hose was cracking (dry rotting) - wasn't wet, but why take the chance. The hoses was only $15 a piece, as I recall.
  19. Doug McC
    1,084
    426
    Midwest
    2022 Prius
    That is not true! Not changing the fluid can, and most likely will, eventually cause parts of the brake system to cease up. A Toyota Dealership that can’t perform a brake fluid change is extremely unlikely. Find another dealership. The coolant system doesn’t cool the hybrid battery (that is air cooled). One side of it cools the engine and transmission; the other cools the inverter/converter.
    Not changing the coolant as needed leads to corrosion in the system and results in parts of the system failing.
    Find a different dealership have them do the required maintenance (even if someone tells you it isn’t necessary) and relax. I am retired and in the same financial situation as you are, and I definitely wouldn’t be wasting money on replacing parts that aren’t broken. I prefer to spend my money on preventing problems by performing preventative maintenance. An ounce of prevention is worth a pound of cure.
  20. Mendel Leisk
    42,055
    Toyota USA says nothing about changing brake fluid. Toyota Canada (as of model year 2014 at least, when I first noted the addition) says to change brake fluid every 3 years or 48k kms, whichever comes first. I did our 2010's recently, second time I'd done it (dealership also did it once, during a brake recall), and belatedly realized I'd left it for 6 years.
    In other news: Toyota USA says to check driver's floor mat, and Toyota Canada, always the contrarian, says nothing about floor mats.
    I changed both the engine and inverter coolant a few weeks back. For both, $400 USD is a little steep, but not by much. It's a little more involved than drain-and-fill. Not onerous, but it does takes some time, protracted running in maintenance mode for the engine coolant, and some momentary runtimes for the inverter coolant.
    #20 Mendel Leisk, Nov 11, 2025
