After 10 years, Phillips coffee machine, bean grinder
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Nov 11, 2025.
  1. bwilson4web
    16,204
    My 10 year old Phillips coffee machine, set for a double espresso, stopped grinding beans. It would "whirl" but only emit hot water into the cup, So I had to fix it.
    There are four T10, sheet metal type screws holding the top on. After clearing the debris inside the screw head, the T10 bit could turn the screw. Three shorties and a long one, ~2 cm, held the grinder feed cover.
    Inside the grinder export tube was blocked by coffee powder which backed up and prevented beans entering the grinder volume. There is a loosely held suspension spring under the grinder assembly but otherwise nothing extraordinary to deal with. Clear the jammed coffee powder, reassemble (careful returning the T10 screws into the plastic assembly,) and test.
    This short video shows how the ground coffee powder falls into the brew head:
    It had completely filled with coffee powder which explains why it became just a hot water dispenser.
    Happy caffeine every day!
    #1 bwilson4web, Nov 11, 2025
    futurist and bisco like this.
  2. ChapmanF
    18,151
    There's a day?
    futurist and bwilson4web like this.
  3. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    Nobody cares about your clogged coffee machine... Please be a little more conservative about what you think you need to share. Oversharing can lead to being easily ignored. It happens to me all the time!
  4. bisco
    51,897
    i find home repairs fascinating. i used to try it in my youth. sometimes you win, sometimes you're the bug
    futurist likes this.
  5. PriusCamper
    12,736
    5,152
    Yep... Taking stuff in the house apart after school and hoping I could get it put back together before mom got home from work was essential to my childhood as a latch key kid starting at around 2nd grade.
  6. bwilson4web
    16,204
    Use it and we’ll all be happier.
  7. Mendel Leisk
    41,407
    Maybe break the process into different components. Our process:
  8. futurist
    futurist Member
    40
    55
    United States
    2024 Prius
    Saw this a tonne as a mechanic :whistle:
    Engines running the same oil tens of thousands of miles, & dying. Batteries never topped off w/ new water (or proper level when they are). Tires on the cords. Air filter housing = pink-insulation-plus-droppings mouse house.
    Some things just get away from you, and drop off your radar. All machines have a line in the sand they'll stop working, if you ignore the signs -- and tbh the best-engineered machines will maintain standard as high as possible, until that showstopper line (in the military it's called graceful degradation -- the ability take combat damage, and still complete the mission :p).
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,053
    537
    Tucson, AZ
    2021 Prius
    I've always been a DIY fixit guy. Fits in nicely with my maker ethic. Strong supporter of Right to Repair. I do know when to refer maintenance to a higher authority. When something needs fixing I always work out the cost-benefit analysis first. Upgrades these days usually are not. The face of durable goods has changed markedly over the years. Our present throw-away culture isn't sustainable. I'll keep doing my part.
  10. ChapmanF
    18,151
    I replaced a relay in my Instant Pot, but if you wanted to pay me for the time it took, a pallet of Instant Pots might be cheaper.
    It's just hard for me to want it in the landfill.
  11. hill
    8,802
    (sigh) thanks for the intolerant impatient POV
    aren't the Lefties supposed to be the party of patience, love dovie, & compassion?
    futurist and cyberpriusII like this.
  12. cyberpriusII
    1,155
    1,768
    Mars Hotel
    I try to fix things, but my husband is much better at it than I.
    He has this noble trait called patience, which I seem to have little.
    I also get frustrated when a repair requires some odd special tool that I would never use again.
  13. futurist
    futurist Member
    40
    55
    United States
    2024 Prius
    Same. Isn't hard to find an exp in a shop, where you're cheesed off enough to want to DIY. And the great thing is w/ comm'ys online, you can fix stuff normally beyond your ability alone.
    Used to belong to a moto forum for my model. It started out carbureted (my model), then switched to EFI at a major update 4 MY later. New one is waaay easier to track-prep, but older one's physically-smaller (better for women and short-of-inseam), prettier, and just as reliable -- if you know how to wrench a bit, and what mods to make. Since I were a factory tech for the brand, knew all the tricks to making a showroom decent beginner bike, in a GSX-R600-baiting infield terrorist. Not surprisingly, one of the mods were F/R GSX-R suspension / brakes :D
    Hey -- you're from Tucson? Awesome, paid my dues in Phoenix; lived in Peoria up there. Used to drive my Scottsdale Coffee Roasters truck down to Tucson to service espresso machines (and up to the Rim and Flag, for same :coffee:).
    Can understand. Alton Brown railed against the onslaught of single-use kitchen items, and I tend to agree... in the kitchen.
    However, spent 16 yrs pro-wrenching... and special tools are what can make kludging a job w/ improvised tools (which you hope the customer doesn't notice), into 10 mins OEM-sano & out the door, paid. As in life, everything's conditional :p
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,053
    537
    Tucson, AZ
    2021 Prius
    I'm not really from anywhere (military brat, born in Japan) but total time-on-station in Tucson is about 36 years. My immediate family resides here as well. Lived in Glendale, Luke AFB, 1982-1987 so I know about heat upon heat.
