2016 Brake Fluid Flush w/o Techstream?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by pnw_jk, Feb 23, 2022.
  1. pnw_jk
    pnw_jk New Member
    Seattle, WA
    I drove the car home, parked, and lifted the hood to check and it was filled nearly to the brim of the cap. So I took it back and argued with them back and forth until they took the amount out to the max line. They were huffing and puffing about how it's okay, and then I asked them to show me how this is okay, the service advisor couldn't even find the reservoir. They admitted some junior technician worked on it. Rectified the issue by drawing out the fluid and replacing the ripped cowl gasket. I would've done it myself if I had a turkey baster lying around.
    Also, I think Car Care Nut was correct in that some dealers may not bother with techstream when it comes to bleeding brakes. I spoke to one of the junior techs on their lunch break for advice on future brake bleeds, and he told me that he never uses the computer to bleed the brakes on hybrids unless a component was replaced. Just uses a vacuum pump. I was a little shocked to hear this. *sigh*
    Before I dropped off the car, the brake fluid was in between min and max. Like right where the seam of the reservoir is. Why should I return it to that level by the way?
  2. Mendel Leisk
    41,218
    Ideally you want to leave the level as you found it.
    The car rolled off the factory floor with new brake pads, and the level at the full line. As the pads wear the pistons move out, and level drops. It tends to be near the low line when the pads are near the service limit (1mm).
    There's no harm in topping it up to full line, but down the road if putting new pads in, when you push the pistons back (to clear new pads), you'll need to keep an eye on the reservoir, it might overflow.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,222
    818
    Monument, Colorado USA
    Dang, sorry to hear about the brake and dealer problems....I'd be mad, too!
    I got involved in my own brakes around 2002 when I took a hand-me-down car my Father-in-law gave to us (92 Subaru) to a local Brakes Plus to fix the squeaky brakes. Idiots charged me, probably, 3 times too much and I had to take it back a number of times because they left air in the brakes and it would pull hard when using them. I worked with a guy who did his own and he taught me when he did my Tacoma...it's really not that difficult and, now, there are tons of folks on YouTube who teach so many car repairs. The hardest part about car repair is when things go wonky and you encounter problems you've never seen before. (Like a bolt that breaks or something so rusty you can't get it out, etc.) It's good have friends you can call when you get in a pinch!
    Doug McC and Mendel Leisk like this.
  4. ken2116
    ken2116 Junior Member
    40
    17
    Northern CA
    2019 Prius
    I tried this today with our 2019 Prius (standard model, Gen 4). Followed the non-techstream procedure to the letter, or believe I did. Within one minute turned on power while p.brake was on, shifted to N (which requires depressing brake), pumped over >8 times in under 5 sec., pushed the park button and pumped brake >8 times rapidly (usually 9-10), back to N and >8 pumps again, returned to P. Repeated a number of times, including from the car off, the yellow brake (!) light never flashed, though it does illuminate briefly when the car is first turned on. When the car first turns on it tells me service is due (the usual 5Kmi. notice), sometimes I canceled this with the return button before all the pumping. My wife double checked as i was doing it, wondered whether I was pumping too fast. Any ideas?
  5. a2058
    a2058 Junior Member
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I have a 2019 and the procedure you write seemed to work for mine, the brake light keeps flashing after that. You are in ignition on and not ready mode, correct? Hit the start button twice without foot on the brake pedal initially to be in the ignition on…
  6. ken2116
    40
    17
    Northern CA
    2019 Prius
    Am trying to remove my recent entry (of minutes ago) using edit but it won't allow a blank message. Is there another way?
    #26 ken2116, Apr 28, 2023
  7. Mendel Leisk
    41,218
    You have to put something, once you’ve posted, so maybe just the word “deleted”?
    then if you really want it gone use the report button, ask moderator to delete it, but it doesn’t hurt to just leave it, saves him work.
  8. Customm
    Customm Junior Member
    quebec
    2022 Prius
    Technology
    2022 Prius owner… I will replace a rear Caliper after trying to retract it using C-clamp instead of the “rotate-n-Push” tool. (Heard a loud click and now I think it’s not as safe as new).. Problem is I never been able to get in the Invisible Mode… Doing Mendel’s procedure (Same as the one found on AllData.com…. The yellow brake light never flashed… all the brakes pedals under 5 secondes, all the little dance moves… Is Invisible Mode for 2022 still doable?
  9. Mendel Leisk
    41,218
    It’s not “invisible” mode, it’s something else, and for the life of me I can’t remember what, lol. Google search to the rescue: “Invalid Mode”. Whew!
    anyway: did you first set the parking brake? It’s a requirement, won’t go into the mode otherwise.
