2016 Brake Fluid Flush w/o Techstream?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by pnw_jk, Feb 23, 2022.
  1. pnw_jk
    pnw_jk New Member
    Seattle, WA
    I drove the car home, parked, and lifted the hood to check and it was filled nearly to the brim of the cap. So I took it back and argued with them back and forth until they took the amount out to the max line. They were huffing and puffing about how it's okay, and then I asked them to show me how this is okay, the service advisor couldn't even find the reservoir. They admitted some junior technician worked on it. Rectified the issue by drawing out the fluid and replacing the ripped cowl gasket. I would've done it myself if I had a turkey baster lying around.
    Also, I think Car Care Nut was correct in that some dealers may not bother with techstream when it comes to bleeding brakes. I spoke to one of the junior techs on their lunch break for advice on future brake bleeds, and he told me that he never uses the computer to bleed the brakes on hybrids unless a component was replaced. Just uses a vacuum pump. I was a little shocked to hear this. *sigh*
    Before I dropped off the car, the brake fluid was in between min and max. Like right where the seam of the reservoir is. Why should I return it to that level by the way?
  2. Mendel Leisk
    42,368
    Ideally you want to leave the level as you found it.
    The car rolled off the factory floor with new brake pads, and the level at the full line. As the pads wear the pistons move out, and level drops. It tends to be near the low line when the pads are near the service limit (1mm).
    There's no harm in topping it up to full line, but down the road if putting new pads in, when you push the pistons back (to clear new pads), you'll need to keep an eye on the reservoir, it might overflow.
    syncro87 and Chuck Pearson like this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    983
    Monument, Colorado USA
    Dang, sorry to hear about the brake and dealer problems....I'd be mad, too!
    I got involved in my own brakes around 2002 when I took a hand-me-down car my Father-in-law gave to us (92 Subaru) to a local Brakes Plus to fix the squeaky brakes. Idiots charged me, probably, 3 times too much and I had to take it back a number of times because they left air in the brakes and it would pull hard when using them. I worked with a guy who did his own and he taught me when he did my Tacoma...it's really not that difficult and, now, there are tons of folks on YouTube who teach so many car repairs. The hardest part about car repair is when things go wonky and you encounter problems you've never seen before. (Like a bolt that breaks or something so rusty you can't get it out, etc.) It's good have friends you can call when you get in a pinch!
    Doug McC and Mendel Leisk like this.
  4. ken2116
    ken2116 Junior Member
    40
    17
    Northern CA
    2019 Prius
    I tried this today with our 2019 Prius (standard model, Gen 4). Followed the non-techstream procedure to the letter, or believe I did. Within one minute turned on power while p.brake was on, shifted to N (which requires depressing brake), pumped over >8 times in under 5 sec., pushed the park button and pumped brake >8 times rapidly (usually 9-10), back to N and >8 pumps again, returned to P. Repeated a number of times, including from the car off, the yellow brake (!) light never flashed, though it does illuminate briefly when the car is first turned on. When the car first turns on it tells me service is due (the usual 5Kmi. notice), sometimes I canceled this with the return button before all the pumping. My wife double checked as i was doing it, wondered whether I was pumping too fast. Any ideas?
  5. a2058
    a2058 Junior Member
    59
    24
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I have a 2019 and the procedure you write seemed to work for mine, the brake light keeps flashing after that. You are in ignition on and not ready mode, correct? Hit the start button twice without foot on the brake pedal initially to be in the ignition on…
  6. ken2116
    40
    17
    Northern CA
    2019 Prius
    Am trying to remove my recent entry (of minutes ago) using edit but it won't allow a blank message. Is there another way?
    #26 ken2116, Apr 28, 2023
  7. Mendel Leisk
    42,368
    You have to put something, once you’ve posted, so maybe just the word “deleted”?
    then if you really want it gone use the report button, ask moderator to delete it, but it doesn’t hurt to just leave it, saves him work.
  8. Customm
    Customm Junior Member
    quebec
    2022 Prius
    Technology
    2022 Prius owner… I will replace a rear Caliper after trying to retract it using C-clamp instead of the “rotate-n-Push” tool. (Heard a loud click and now I think it’s not as safe as new).. Problem is I never been able to get in the Invisible Mode… Doing Mendel’s procedure (Same as the one found on AllData.com…. The yellow brake light never flashed… all the brakes pedals under 5 secondes, all the little dance moves… Is Invisible Mode for 2022 still doable?
  9. Mendel Leisk
    42,368
    It’s not “invisible” mode, it’s something else, and for the life of me I can’t remember what, lol. Google search to the rescue: “Invalid Mode”. Whew!
    anyway: did you first set the parking brake? It’s a requirement, won’t go into the mode otherwise.
    Customm likes this.
  10. Customm
    quebec
    2022 Prius
    Technology
    First Thank you Mendel for reaching out. 1- yes, my “Foot operated Parking brake pedal” was applied. 2- i tried the official TIS sequence (that sequence doesn’t talk about applying brake pedal dbefore going into neutral, nor hitting the Start button twice . 2- Then I tied your nice sequence 3- tried NutAboutBolts Video 4- tried this one very different (different in the foot work) :
    … Spent near 2 hours (with a trickle charger to make sur i don’t go under 12.4v…. Result : IFailed miserably 4th gen 2022 Prius . Thanks
  11. Mendel Leisk
    42,368
    Finally got around to digging up 4th gen Invalid Mode. Believe it's the same. Again, a gotcha for me was not having parking brake set. Also, shifting from Park to Neutral requires brake pedal to be depressed, don't think that's mentioned.
  12. Mendel Leisk
    42,368
    The meat of the above attachment:
    Enter ECB (Electronically Controlled Brake system) Invalid Mode.
    (1) Perform the procedure listed below within 1 minute.
    1. Turn the power switch on (IG) with park (P) selected and the parking brake applied.
    2. Select neutral (N) and then depress the brake pedal more than 8 times within 5 seconds.
    3. Push the P position switch and then depress the brake pedal more than 8 times within 5 seconds.
    4. Select neutral (N) and then depress the brake pedal more than 8 times within 5 seconds.
    5. Push the P position switch.
    Thoughts:
    1. First just a quibble: Toyota-speak is always, well, kinda stupid. By "Turn the power switch on (IG)", I think that means "push power button twice with foot off the brake pedal".
    2. At the intro, it says "Perform the procedure listed below within 1 minute". Could that be the problem? Or the 5 second limits in steps in 2 through 4.
    I just tried it a few times (on our gen 3); it does get a little hectic. Are you sure you made it into Neutral? You've got to depress-and-hold brake, push the shifter towards 9 o'clock, and hold it thus for about a second. I'll attempt to upload a YouTube Short. I'm seeing it on my phone, but inexplicable not on my pc. Bear with me:
    https://youtube.com/shorts/S7fIlwcxPrs?si=f4qXjweiQC91lLje
    Customm likes this.
  13. Customm
    quebec
    2022 Prius
    Technology
    I tried for near 2 hours…will try again with your video! I’ll make a short YT video and upload it ….Do we have to hold the brake also when pushing the P button? BTW is there a sub 500$ Scan tool that can reliably Put the Prius in invalide mode? Your help is really appreciated ….
  14. Customm
    quebec
    2022 Prius
    Technology
    BIngo! I was doing it way too fast… Slowing it down allowed to enter the N and P more consistently before tap dancing ! thank you again Mendel !!
  15. Mendel Leisk
    42,368
    @NutzAboutBolts has an infintedly better video. I've linked it to start at the invalid mode procedure:
    The only "extra" brake pedal push needed is when going from Park to Neutral; otherwise it just won't make the shift.
    And again, gotta have parking brake applied/set/on.
    The big difference with yours, it's Gen 4. Supposedly the same, according to Repair Manual, but who knows.
    All his Prius videos are linked here too, #18 is the brake fluid replacement (linked above).
  16. Mendel Leisk
    42,368
    Oh, I spotted something, from the 4th Gen instruction:
    So maybe needs nine pushes???
    Addendum:
    Gen 3's saying "more than" as well:
    So maybe a red herring. Maybe the repair manual proof-readers just missed that? But do try 9 pushes, who knows.
    #36 Mendel Leisk, Nov 13, 2025
  17. ChapmanF
    19,047
    Yes, but you may get a different invalid mode that way. At least in gen 3 anyway (where my experience is), if you set invalid mode with a scan tool, the brake system will give you the evil C1451 code that you can only clear by completing a scan-tool brake bleed procedure afterward, and not any other way.
    Of course they changed the brake system somewhat for gen 4, so maybe with that design they didn't feel they'd need that evil code.
  18. Mendel Leisk
    42,368
    Not sure how I missed this, good to hear.
    Again, there appears to be a typo in the Repair Manual, which says "...more than eight...". @NutzAboutBolts says eight, various other third-party retellings call it eight, I've always managed with eight.
