Pushing start button 3 times to start
Discussion in 'Prius v Main Forum' started by Shaun H, Oct 21, 2025.
  1. Shaun H
    Shaun H New Member
    Gilbert, AZ
    2015 Prius v wagon
    Hey gang, bought a used 2015 Prius V a few days ago. Every time I start the car I have to hold the brake and press the start button three times before the ready light comes on. Is this some kind anti-theft device the previous owner installed? I thought it was because the 12v battery was low, but I installed a new Toyota battery and it's still the same.
  2. PriusCamper
    PriusCamper Senior Member
    13,006
    5,287
    Pacific Northwest, USA
    Have you charged up the 12 volt yet? A new 12volt doesn't necessarily show up off the shelf fully charged. Putting a fresh charge on a battery is the first step that too many people don't know about.
    Beyond that there should be a series a lights responding to each button push. Also what happens with lights without foot on brake pedal, as well when you touch the fob to the power button while powering up.
    Lastly, if you disconnect the 12volt battery for a few minutes it's equivalent of solving your problem by shutting off and turning back on your computer.
    #2 PriusCamper, Oct 22, 2025
  3. rjparker
    10,437
    6,545
    Depress and hold brake and one Power Button press should bring up Ready iin a second or two. The engine may not start. That is ok. You just need Ready to drive.
    Otherwise something is wrong. I would check with your second fob. If you don't have a second fob, get one right away.
    I would change the fob batteries as well. Page 459.
    IMG_0359.jpeg Check the owners manual page 172 on how to start the car. A dead fob can Ready the car by holding it on the Power button and then press the button with the brake on. No manual? Download from toyota,com.
    Brian1954 likes this.
  4. BiomedO1
    4,059
    2,136
    SacTown, Ca
    If you got some sort of warranty with that purchase, I'd make them fix it. Even if it is a cheap fob battery. It somehow passed their multi-point check out, like that????
  5. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I had a similar issue and it was a failing 12 volt battery. That's the first thing I'd check.
    iPhone ?
    Air_Boss and Brian1954 like this.
  6. Shaun H
    Shaun H New Member
    Gilbert, AZ
    2015 Prius v wagon
    So it was this Moovetrax device the previous owner had installed. Pulled this mess out and of course the factory wiring was a little hacked up, not much else I could do. Now it starts on the first press of the start button.
    frodoz737 and Brian1954 like this.
  7. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    Guess he wanted it back...
  8. Mendel Leisk
    41,850
    Might have been imposing a phantom load too; good riddance. (y)
    Air_Boss likes this.
