Why does non-synthetic oil still exist?
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Nov 13, 2025 at 12:20 PM.
Tags:
  1. Paul Gregory
    Paul Gregory Senior Member
    2,112
    552
    Alberta
    2024 Prius Prime
    XSE
    To my way of thinking, the margin between engine wear and no engine wear is the quality of lubrication. If a lubricant could prevent all metal-to-metal wear, it would be a perfect lubricant. Such a lubricant may not yet exist, but certainly some lubricants have been designed to reduce wear significantly. Synthetic lubricants have been over-priced in the past, but I have always found them to be quite cost-effective, regardless.
    Watchmakers and jewellers use synthetic lubricants that cost hundreds of dollars per milliliter. These are far superior performing lubricants, but they are used in such tiny amounts that the cost is not a major issue. If I can stretch my oil change interval even a little, I find that synthetics are the way to go. It's no surprise to me that The Toyota Prius uses the lightest synthetic oil available.
  2. hill
    8,779
    Simple. Regardless if oil is conventional or synthetic, if it meets SAE standards then the quality is the quality that it needs to be - & it's less expensive.
  3. Paul Gregory
    2,112
    552
    Alberta
    2024 Prius Prime
    XSE
    It should be outlawed at this point.
  4. Winston Smith
    Winston Smith Active Member
    350
    234
    OH
    2024 Prius
    LE AWD-e
    Even if it works?
    The perfect lubricant you describe, one that would prevent all metal to metal wear, still needs to be changed periodically. In addition to lubricating, engine oil accumulates acids and particulates from combustion. You don't want to leave all that in there.
    You could fill a toilet tank with Fiji water, but not flushing it would still be a bad choice.
  5. silvertounged devil
    silvertounged devil Junior Member
    47
    Yorktown Virginia
    2024 Prius
    On my 1937 Ford with original power train, I tried synthetic oil and it got on the points and the car died.
    Thats why you still need to have dino oil available. The rear main seal did not exist. Front seal was a piece of rope. Rear axle seals were leather. There was a channel (rear main seal) and disc that literally slung the oil into the channel and back to the oil pan. There was no positive crankcase ventilation system, just a tube sticking down to the ground. Had there been a pcy system the recirculating synthetic oil would have fouled out the plugs.
    Hope you understand those reasons.
  6. PriusCamper
    PriusCamper Senior Member
    12,641
    5,108
    Pacific Northwest, USA
    If we had consumer protection laws designed to maximize the lifespan of vehicles and keep quality cars on the road that would be true. But Capitalism run amok is the exact opposite of that.
  7. Gokhan
    Gokhan Senior Member
    6,098
    2,419
    Paramount CA
    These days, there is very little distinction between synthetic and conventional oil.
    Also, 0W-X oils practically always come in synthetic forms anyway; so, this is a moot issue.
    Last but not least, according to American Petroleum Institute (API), “synthetic” is a marketing term, not a technical term. In Germany, they only allow Group IV and Group V base oils to be marketed as synthetic, but that is not the case in the US and elsewhere, and those oils are very hard to find in Americas.
  8. bisco
    51,791
    you mean it isn't made in a lab from corn husks? (n)
  9. Paul Gregory
    2,112
    552
    Alberta
    2024 Prius Prime
    XSE
    We don't need consumer laws to ensure quality. We need more consumer awareness and intolerance of planned obsolescence.
  10. PriusCamper
    12,641
    5,108
    Not doing business with shops and dealerships who are overcharging and making up repairs that are not necessary does nothing to change their behavior. The threat of massive fines that could bankrupt their business will.
  11. fuzzy1
    10,387
    Restricting consumer choice just because something better exists, is the antithesis of American free market capitalism.
    Maybe in parts of Canada . . . but I wouldn't guess that it would start in Alberta.
  12. Gokhan
    6,098
    2,419
    Paramount CA
    As if there is such a thing as a conventional or semisynthetic 0W-16 or 0W-8. :rolleyes: Those SAE viscosity grades must be a full synthetic to meet the 15% API/ILSAC maximum spec for Noack volatility.
    #12 Gokhan, Nov 13, 2025 at 2:59 PM
  13. PriusCamper
    12,641
    5,108
    Funny how consumer choice only gets mentioned when its backed by well funded and obscene level of corrupt profiteering. In the US there's no such thing as free market capitalism with the amount of billionaire's ruling over their monopolies and getting out of anti-trust verdicts constantly. Instead we have a criminal racket that buries young people under a lifetime of debt just for them to get their basic health, housing and education needs met. The entire foundation of the United States was built on stolen land, genocide and indentured servitude and the same culture that celebrated that level of awful is alive and well today celebrating people losing Snap benefits and health care coverage they can no longer obtain/afford. It's a sick degenerate society masquerading in virtues that it doesn't actually have.
    #13 PriusCamper, Nov 13, 2025 at 3:07 PM
  14. hill
    8,779
    That sounds right out of the Karl Marx playbook. Speaking of genocide how many millions did the russian commie Socialists kill during the 1900s? All for a good cause. Admittedly the Chinese may have outdone them via comrade Chairman Mao.
    Prime minister Margaret Thatcher said it best; "The problem with socialism is eventually you run out of other people's money".
    At is base - it's envy, one of the original sins, wanting other people's stuff. Reminds me of that famous YouTube video. 2 monkeys adjoining cages. One gets cucumber for a task/reward & the other gets a grape. Freak out time.
    But of course, we digress. Seems the 1st recollection seeing multi viscosity oil was in the early 70s when I started driving (5w-30). So, multi viscosity doesn't necessarily have to be made synthetic (Natural Gas).
    #14 hill, Nov 13, 2025 at 3:19 PM
  15. silvertounged devil
    47
    Yorktown Virginia
    2024 Prius
    There are 4 billionaires in Virginia. 879 out of 350,000,000 in the country. In 1900 John D Rockefeller's net worth was greater that the whole Federal budget. Does the richest man on Earth have the resources to cover the Federal budget today. The current credit card NATIONAL debt per Capita is $105,000. The problem is not billionaires it's vote buying with other peoples money.
