Why does non-synthetic oil still exist?
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Nov 13, 2025.
Tags:
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    To my way of thinking, the margin between engine wear and no engine wear is the quality of lubrication. If a lubricant could prevent all metal-to-metal wear, it would be a perfect lubricant. Such a lubricant may not yet exist, but certainly some lubricants have been designed to reduce wear significantly. Synthetic lubricants have been over-priced in the past, but I have always found them to be quite cost-effective, regardless.
    Watchmakers and jewellers use synthetic lubricants that cost hundreds of dollars per milliliter. These are far superior performing lubricants, but they are used in such tiny amounts that the cost is not a major issue. If I can stretch my oil change interval even a little, I find that synthetics are the way to go. It's no surprise to me that The Toyota Prius uses the lightest synthetic oil available.
  2. hill
    9,027
    Simple. Regardless if oil is conventional or synthetic, if it meets SAE standards then the quality is the quality that it needs to be - & it's less expensive.
    Oh, I see. So you had your preconceived understanding already. That's not a fault. And I'm not a stickler one way or the other, so perhaps that's more of a neutral point.
    Maybe it's like diesel. A lot of diesel is now cleaner than ice. Yet you still find people that have all kinds of hair on fire / drama emotions towards the thought of burning oil in a car instead of a more flammable fuel. That's okay too, because we all come with our biases.
    #2 hill, Nov 13, 2025
  3. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It should be outlawed at this point.
  4. Winston Smith
    Winston Smith Active Member
    471
    338
    OH
    2024 Prius
    LE AWD-e
    Even if it works?
    The perfect lubricant you describe, one that would prevent all metal to metal wear, still needs to be changed periodically. In addition to lubricating, engine oil accumulates acids and particulates from combustion. You don't want to leave all that in there.
    You could fill a toilet tank with Fiji water, but not flushing it would still be a bad choice.
  5. silvertounged devil
    silvertounged devil Junior Member
    48
    Yorktown Virginia
    2024 Prius
    On my 1937 Ford with original power train, I tried synthetic oil and it got on the points and the car died.
    Thats why you still need to have dino oil available. The rear main seal did not exist. Front seal was a piece of rope. Rear axle seals were leather. There was a channel (rear main seal) and disc that literally slung the oil into the channel and back to the oil pan. There was no positive crankcase ventilation system, just a tube sticking down to the ground. Had there been a pcy system the recirculating synthetic oil would have fouled out the plugs.
    Hope you understand those reasons.
    Isaac Zachary and bisco like this.
  6. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    If we had consumer protection laws designed to maximize the lifespan of vehicles and keep quality cars on the road that would be true. But Capitalism run amok is the exact opposite of that.
  7. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    These days, there is very little distinction between synthetic and conventional oil.
    Also, 0W-X oils practically always come in synthetic forms anyway; so, this is a moot issue.
    Last but not least, according to American Petroleum Institute (API), “synthetic” is a marketing term, not a technical term. In Germany, they only allow Group IV and Group V base oils to be marketed as synthetic, but that is not the case in the US and elsewhere, and those oils are very hard to find in Americas.
    Isaac Zachary likes this.
  8. bisco
    52,829
    you mean it isn't made in a lab from corn husks? (n)
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    We don't need consumer laws to ensure quality. We need more consumer awareness and intolerance of planned obsolescence.
  10. PriusCamper
    13,451
    5,430
    Not doing business with shops and dealerships who are overcharging and making up repairs that are not necessary does nothing to change their behavior. The threat of massive fines that could bankrupt their business will.
  11. fuzzy1
    10,705
    Restricting consumer choice just because something better exists, is the antithesis of American free market capitalism.
    Maybe in parts of Canada . . . but I wouldn't guess that it would start in Alberta.
  12. Gokhan
    6,714
    2,661
    Paramount CA
    As if there is such a thing as a conventional or semisynthetic 0W-16 or 0W-8. :rolleyes: Those SAE viscosity grades must be a full synthetic to meet the 15% API/ILSAC maximum spec for Noack volatility.
    #12 Gokhan, Nov 13, 2025
  13. PriusCamper
    13,451
    5,430
    Funny how consumer choice only gets mentioned when its backed by well funded and obscene level of corrupt profiteering. In the US there's no such thing as free market capitalism with the amount of billionaire's ruling over their monopolies and getting out of anti-trust verdicts constantly. Instead we have a criminal racket that buries young people under a lifetime of debt just for them to get their basic health, housing and education needs met. The entire foundation of the United States was built on stolen land, genocide and indentured servitude and the same culture that celebrated that level of awful is alive and well today celebrating people losing Snap benefits and health care coverage they can no longer obtain/afford. It's a sick degenerate society masquerading in virtues that it doesn't actually have.
    #13 PriusCamper, Nov 13, 2025
  14. hill
    9,027
    That sounds right out of the Karl Marx playbook. Speaking of genocide how many millions did the russian commie Socialists kill during the 1900s? All for a good cause. Admittedly the Chinese may have outdone them via comrade Chairman Mao.
    Prime minister Margaret Thatcher said it best; "The problem with socialism is eventually you run out of other people's money".
    At its base emotion - is envy, one of the original sins, wanting other people's stuff. Reminds me of that famous YouTube video. 2 monkeys adjoining cages. One gets cucumber for a task/reward & the other gets a grape. Freak out time.
    But of course, we digress. Seems the 1st recollection seeing multi viscosity oil was in the early 70s when I started driving (5w-30). So, multi viscosity doesn't necessarily have to be made synthetic (Natural Gas).
    #14 hill, Nov 13, 2025
    Winston Smith likes this.
  15. silvertounged devil
    48
    Yorktown Virginia
    2024 Prius
    There are 4 billionaires in Virginia. 879 out of 350,000,000 in the country. In 1900 John D Rockefeller's net worth was greater that the whole Federal budget. Does the richest man on Earth have the resources to cover the Federal budget today. The current credit card NATIONAL debt per Capita is $105,000. The problem is not billionaires it's vote buying with other peoples money.
  16. Winston Smith
    471
    338
    OH
    2024 Prius
    LE AWD-e
    I don't know fuzzy1, but I doubt that he is backed by well funded and obscene level of corrupt profiteering.
    If anyone has something against conventional oil, he shouldn't buy it. Problem solved.
    #16 Winston Smith, Nov 13, 2025
  17. hill
    9,027
    And that - I suppose deals with synthesized oil because oil people are often well to do? I think my prior tie-in to the OP was more closely rated to the OP
  18. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    A case could be made for it causing premature engine wear.
    Don't be a political idiot, please.
    mountaineer likes this.
  19. hill
    9,027
    Now now - we can all play nice, right?
    Because It's not as cutting edge? Not as cool? or what. You know, processing natural gas into synthetic oil is in and of itself a more c02 intensive process, right?
    (Disclaimer) not that I give a hoot about the hoopla over CO2 (any longer) or ICE wear much. Some people suffer just to change their oil at all, much less buy something more expensive. What's wrong with giving people a break.
    #19 hill, Nov 13, 2025
  20. PriusCamper
    13,451
    5,430
    Doesn't matter if you don't buy it when the fossil fool industry has taken over all the major governments of the world and are enjoying trillions of dollars in annual government subsidies while ensuring that the very real reality of climate change is denied.
