LiBSU - Redesigning the "Battery Support Unit" to Support Lithium
Discussion in 'Gen 3 Prius Technical Discussion' started by mudder, Jun 7, 2024.
  1. mudder
    mudder Active Member
    246
    324
    Chattanooga, TN
    It's crazy that TE makes "wire-to-board" connector housings (1473143-1) that they don't also sell mating headers for. In other words, a company that solely manufactures mechanical connector systems expects me to design my own header to mate with their connector housing. OK, seriously?
    Looks like I'll end up cutting off the OEM temp sensor terminals (1123343-1) and replacing them with another connector system. Another thought is to kludge a 0.100" 2p shrouded header to work with their 1473143-1 connector housing.
  2. mudder
    246
    324
    Chattanooga, TN
    Daily PCB layout update:
    Notes:
    -HVDC section 100% placed.
    -Connectors 100% placed.
    -Should have all remaining parts placed tomorrow.
    -Almost certainly a 2 layer board... almost every signal routes on bottom layer.
    -Planning to order PCB Monday.
    Mr. F and mjoo like this.
  3. ChapmanF
    18,010
    Woo hoo!
    How will the owner access diagnostic information on what condition at what cell has bricked the car?
    #63 ChapmanF, Nov 14, 2025 at 7:57 AM
  4. mudder
    246
    324
    Chattanooga, TN
    There are several ways to retrieve debug info from LiBSU:
    1: The most verbose output is via USB. Here's the existing method for my Honda Insight product. Note that while I'm using Arduino's IDE in the video, any standard serial putty terminal will work... LiBSU isn't running Arduino code, but that platform is the easiest for computer novices to use.
    2: LiBSU will report all OEM parameters to the hybrid computer, which are readable via OBDII. This will only narrow the failing cell down to QTY4 cell segments. You would need to use USB to narrow down to a single cell.
    3: The (optional) 4x20 LCD displays the following parameters:
    KEYON_SECONDS
    VPACK_ACTUAL
    VPACK_SPOOFED
    BMS_ERROR_FLAG
    CELL_VOLTAGE_HI
    CELL_VOLTAGE_LO
    CELL_DELTA
    POWER_kW
    CELL_MAX_SINCE_KEYON
    CELL_MIN_SINCE_KEYON
    SoC
    PACK_CURRENT
    TEMP_BATTERY
    FAN_STATUS
    CHARGER_STATUS
    HEATER_STATUS
    CELL_BALANCE_STATUS
    WATT_HOURS_SINCE_KEYON_ASSIST
    WATT_HOURS_SINCE_KEYON_REGEN
    As I mentioned previously, no wireless options are available. The FCC certification is expensive and annoying, and I just don't plan to do it. If someone wants wireless, they'll need to develop an expansion module that plugs into LiBSU. Some of my Honda Insight customers use an Android phone with USB OTG for wireless comms.
  5. ChapmanF
    18,010
    What USB vendor/product and device class IDs will it present? Will an OS-supplied USB-to-serial device driver attach it upon presentation and work, or will further driver loading or USB ID configuration be needed first?
