08 prius keep dying
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Oct 16, 2025.
  1. richard203
    richard203 Member
    276
    60
    SF
    just an update. I replaced the inverter pump today and drive the car and died again checked the code and it gives a P3102 Transmission Control ECU Code
    #21 richard203, Nov 14, 2025
  2. dolj
    dolj Senior Member
    8,494
    4,313
    Wellington, New Zealand
    There are seven INF codes for that DTC: 524, 525, 581, 582, 597, 598, and 599.
    Clicking on the snowflake icon right there on the left of your screen will tell you which INF code you have. Knowing the code helps to follow the correct diagnostic procedure.
    With two of the INF codes, the car is impossible to drive. The other five talk about the shift position being fixed or not, and the car being impossible to drive or not is dependent on that position being fixed or not.
    There is also mention of communication problems between the BEAN and the transmission control ECU assembly.
    In short there are too many possibilities without the INF code.
    It is not clear from the context whether the meaning of the word fixed means corrected/repaired or stuck in place.
  3. richard203
    richard203 Member
    276
    60
    SF
    here’s the INF Code - 3102-525
  4. dolj
    dolj Senior Member
    8,494
    4,313
    DTC P3102/525 indicates a malfunction in the transmission control ECU. This code is often associated with issues in the park lock system or the park lock actuator motor. It can lead to problems with shifting gears or engaging the park position.
    For detailed repair procedures, refer to the official Toyota repair manual for the 2008 Prius. This manual will provide specific instructions, wiring diagrams, and troubleshooting steps tailored to your vehicle.
    Toyota Service Information and Where To Find It.
  5. richard203
    richard203 Member
    276
    60
    SF
    what if the cars goes into gears and can put in park. do that mean the park lock system is good?
    I looked the code up it shows that it's either wiring or ecu issue
    - Wire Harness /Connector
    - Transmission Control ECU Assembly
    - HV control ECU
    - Power Source Control ECU
    #25 richard203, Nov 14, 2025
  6. dolj
    dolj Senior Member
    8,494
    4,313
    The detection condition is: Transmission control ECU IG OFF command malfunction, so it is reasonable to be looking at the wiring.
    In another place in the manual, for the detection condition, it states: Transmission control ECU IG OFF command malfunction and names these trouble areas:
    - Wire harness or connector
    - Transmission control ECU assembly
    - Hybrid Vehicle control ECU
    - Power source control ECU
    Given the broad scope, I would think following the diagnostic steps for P3102-525.
  7. richard203
    richard203 Member
    276
    60
    SF
    is there a link to follow the step?
  8. Brian1954
    Brian1954 Senior Member
    2,351
    947
    South Central PA, USA
    The link to obtain access to the Toyota repair manual is in post #24.
  9. Tombukt2
    13,221
    2,390
    I could copy and send direct only it's long I think . Are you in a mouse area where they mite be in car ? Other than that look into spare computer modules mentioned . And they're a pain to swap. Take the two or three computers from a known good car say w dead batteries or brake actuator down . I have several sets here .
  10. richard203
    richard203 Member
    276
    60
    SF
    Isn’t that show the link to Toyota website u need to pay for it right?
  11. richard203
    richard203 Member
    276
    60
    SF
    um the mouse part might be hard to say. Lol where can you sent me directly and how much you selling the computer?
  12. Tombukt2
    13,221
    2,390
    I don't know man you pay the postage you can have them whatever. They not that heavy but they odd shaped I think
  13. Tombukt2
    13,221
    2,390
    I'm in Central North Carolina.. I would just send the copies from the manual to like your email or your phone if it can take that kind of hit
  14. Tombukt2
    13,221
    2,390
    Yes they do that here they're are folks with the whole manual 9nline too. I would hate to think anybody would invoke copyright infringement policies on folks reading about a 20 yr old no classic car etc . Wouldn't be any real money in that
  15. Brian1954
    2,351
    947
    Correct. You create an account and pay for two day access to get the repair manual section for the trouble code that you have. Then, follow the steps in the manual.
  16. Hayslayer
    Hayslayer Active Member
    434
    252
    The good thing is if you decide to just change that ecu, it can be had for 10-20 bucks at most salvage yards, is mounted under the glovebox and takes about 5 minutes to replace. Pop off the plastic trim cover, remove 2 bolts and one plug, if I remember right.
  17. richard203
    richard203 Member
    276
    60
    SF
    Ya I’m planning to change the transmission control ecu and see. If that don’t work I might follow this step.
    #37 richard203, Nov 15, 2025
  18. Tombukt2
    13,221
    2,390
  19. richard203
    richard203 Member
    276
    60
    SF
    ops I guess link don’t work I attached the pdf check if this the one to follow on fixing?
  20. richard203
    richard203 Member
    276
    60
    SF
    I’ll let u know since my friend have a transmission control ecu from his old Prius so ima give it a try and see if it will fix. If not I’ll hit you up thanks
