Has anyone successfully disabled the tpms system on a Prius v?
Discussion in 'Prius v Accessories and Modifications' started by Georgina Rudkus, Nov 10, 2025.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    Title says it all.
  2. Tombukt2
    13,336
    2,401
    I'd think you'd be writing code to slip into some firmware somewhere. So not likely. You have to fool the body module or such . Just messing w immobilizer for keys is enough trouble . Disabling features would be something . The computer aren't that interested or tis alot of work not even heavy modders talk about it . So must not be a thing?
  3. Mendel Leisk
    41,850
    Sure, every winter with our sensor-less snow tires.
    Appreciate you mean “make the light in the dash go out”, but for me at least, that’s surplus to requirements.
  4. ETC(SS)
    7,330
    Otherwise?
    If you're a talented auto tech you can take the dash apart and remove the LED.....
    You can also remove the sensors and use the PVC hack (ask the Googles....)
    Air_Boss likes this.
  5. rjparker
    10,437
    6,544
    Personally I would not disable a tpms system since it could save someone's life - perhaps an innocent traveling with you or in another car.
    If winter tires are the issue, installing Autel Mx sensors that are cloned with your summer tire's sensor ids makes sense.
    However various forums include these disable instructions which apparently work for gen3 and other Toyota models:
  6. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    #6 Georgina Rudkus, Nov 15, 2025
  7. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    It would be easy for you to do. On any Gen 3 Prius, it's the same jumper between pins 5 and 6.
    That's the two wires on the left bottom.
    It took me three days and about nine hours and many removals of the connector block to figure it out.
    I used a short piece of wire from a Cat5 cable, but any piece of 24 ir 22 gauge solid copper wire will do.
    Now that I know, anyone can do it in 20 to 30 minutes with no tools.
    All that's needs to be done is to squeeze the sides of the glove compartment and to hinge it down.
    That provides full access to the TPMS. computer..
    The connector's block doesn't even have to be removed.
    Just insert the ends of the jumper into the back of positions 5 and 6 on the two vertical positions on the lower right.
    If you replace the tires without TPMS sensors with those that have them, just remove the jumper.
    No wire cutting or splicing is necessary.
    With the jumper removed, there is no trace of this modification.
    This would be great for states that would fail a vehicle inspection for a TPMS fault.
    Mendel Leisk and Brian1954 like this.
  8. Mendel Leisk
    41,850
    Good to know, but my motivation would be purely OCD: no inspections here, and Canada doesn’t require TPMS. Plus, the tpms sensors on the stock rims are still functional, so 7-8 months out of the year I’d prefer to use them, without hassle of removing jumper. The tpms light is akin to other lights in dash, say passenger air bag status.
  9. Tombukt2
    13,336
    2,401
    So you figured this out by looking at the wiring diagram for a good bit first I imagine ? probably similar on gen 2 . Wires 5 6 are comm wiring or? I don't have gen3 wiring but 2 I've plenty.
  10. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    I just started to jumper as many combinations as possible and started the car. None damaged anything. Just worked or didn't work at turning off the light.
    Eventually, I found that the pink wire or pink with stripe wire on almost all Toyota and Lexus cancels the TPMS light on the dash.
    Just try jumpering to most likely the blue wire. If that doesn't work, just try con̈necting others until it works to turn off the light.
