2017 Prime not charging anymore.
Discussion in 'Prime Plug-in Charging' started by Gianni I, Nov 17, 2025.
  1. Gianni I
    Gianni I Member
    71
    40
    Long Island
    I am the original owner of a 2017 Prius Prime advanced. Been charging pretty much since day 1 and have NEVER had a problem.
    All of a sudden, it's not charging anymore. I plug in the charger, the little light near the charger turns green for about 5 seconds or so, then it starts flashing for about 10 seconds and then shuts off. No charger ever starts on the car. The 3 blue dots never start blinking. When I open the door the Display reads "Charging Port Lid Open". Usually it would show the battery with how much time left for a full charge. When I unplug the charger and then start the car the display reads "Charging Stopped" as if the car was actually charging and I unplugged it prior to finishing. But no charging actually took place.
    I searched all over the internet for options. I tried disconnecting the 12v battery. I tried locating the ECU fuses, but there seem to be tons of them labeled as such, so not sure which one could be the culprit (if any). I've also tried 4 different chargers, so it's not my charger as none have worked, and yet all work on other EVs. So it is 100% the car having the issue.
    I took it in to Toyota and they charged up the 12v to ensure that wasn't it, checked my charging schedules (which I know it wasn't as i've had the car for 8 years know how that works). They said next step is to send it in for diagnostics at $225 an hour in "hopes" to find something. No idea what the part could be and will most likely be thousands of dollars.
    Any other tips, tricks I can do on my own. I am not giving it back to Toyota and spending that money. I'll just not plug it in anymore, but it sucks because I have solar at home, my own charging stations and I typically only need to fill my tank 3/4 times a year b/c most of my driving is done on EV.
    Anyone have any other ideas???
    #1 Gianni I, Nov 17, 2025
    52,066
    no trouble lights? have you tried L1 and L2? look closely at the pins in the charge port for corrosion, looseness or a bent one. i would try another dealer
  3. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Yes to all of that. No trouble lights at all and nothing came up at the dealer when they tried to read any error codes.
    Funny you mention about another dealer, before I went to the one that I bought my car from, I stopped in another one to ask some questions and they said they would have to diagnose as well. Don't feel like spending $600 only to find out I need to replace a $2000 part. It is such a strange problem, but no one else seems to have had this exact issue. I'm sure it's something so stupid but can't get it solved and it's so frustrating
  4. BiomedO1
    3,774
    1,961
    SacTown, Ca
    Your car may still be covered under the 10 year 100K mile EV warranty; not sure if Long Island is covered under CARB warranty.
    READ your warranty manual; know what's covered!! The dealership will charge you; if you don't know your rights.
    Have you tried a public charger? It sounds to me like the charge cable safety system is turning everything OFF because it senses a dangerous issue - most likely bad ground. You need to figure out if the problem is on the car side or your charging cable side. If the issue is on your charging cable side; you'll waste the diagnostic fee because the dealership won't be able to find anything wrong. Again, READ your operations manual - the lamps flashing before it cuts-off is signaling the problem it sees - through a blink code.
    Good Luck.....
    PrimeDan likes this.
  5. Gianni I
    Gianni I Member
    71
    40
    Long Island
    My hybrid battery at time of purchase was 8yr 100k. Which I’m 1 month away from
    I’ve tried multiple level 1 and level 2 chargers and same thing applies so that makes me believe it’s not the charger and has to be the car.
    I was at Toyota speaking with them for over an hour and the warranty doesn’t cover as much as you think. They even called in potential parts that could have failed and those only had 5yr warranty.
    My only hope is finding a solution bc someone had the same exact problem and found a legitimate diagnosis and fix.
    So far no luck there.
  6. BiomedO1
    3,774
    1,961
    SacTown, Ca
    You need to have the dealership service writer show you that in WRITING. The electric socket, traction pack, transmission/transaxle, and inverter are all part of the EV drive system. I'm guessing you have a failed plug socket or board in the traction pack. There's been a couple of failed plug-in socket failures in the past, that has always been covered under warranty.
    I would get the work done, then haggle with the dealership and Toyota corporate afterwards, since your a month from being out of warranty. Involve your states' consumer protection agencies - even though they are under fire by the current administration.
    Good Luck...
  7. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Can you still charge the traction battery by putting the car into 'charge' mode by holding the HV/EV switch until the 'CHG MODE' indicator appears on the main display? Remember that if the traction battery charge gets too low, the car won't start. Note that this is seperate from the 12V battery. Both batteries must have enough charge for the car to start.
    Are the lights on the charging cable brick doing anything weird - such as flashing?
    You could try removing internal panels and inspect the charging socket and cabling for frayed wires, loose or corroded connectors, etc. The lack of trouble codes suggests that the problem could be at or near the charging socket rather than further into the system.
  8. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Yes, Charge mode on the car works when holding HV/EV and it charges properly. I did make sure to try that before I even took it to the dealer initially.
    As for the supplied charger. I plug it in, the power light comes on. I plug into the car and then the charge light comes on. About 5 seconds or so in, the charge light shuts off. Similar to how the green light near the charging port goes green, then starts flashing and then shuts off.
  9. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    The manual says:
    "■If the charging indicator flashes after connecting the charging cable
    The charge schedule (P. 157) is registered and charging cannot be performed. To cancel charging using the timer and start charging, perform any of
    the following procedures.
    ●Turn “Charge Now” on (P. 166, 175)
    ●While the charging indicator is flashing, remove and reconnect the charging
    connector within 5 seconds "
    The page numbers are from the manual for my 2020 Prime so yours might be different.
    Do you have any charging schedules entered? If yes, but they're not activated, maybe try deleting everything.
    Did you check the date and time after you disconnected the 12V battery? I don't know if the car loses that when the 12V is disconnected.
  10. Gianni I
    Gianni I Member
    71
    40
    Long Island
    - Do you have any charging schedules entered? If yes, but they're not activated, maybe try deleting everything. - Everything is deleted and no charging schedules at all and is set to charge as soon as I plug in.
    - Did you check the date and time after you disconnected the 12V battery? I don't know if the car loses that when the 12V is disconnected. - Yes, I had to reset both date and time which is a good indication that the battery was fully disconnected and "rest". But still no charge schedules
    - While the charging indicator is flashing, remove and reconnect the charging connector within 5 seconds " - So this I HAVE NOT done. Everytime it flashes, I just let it go. I dont think I ever removed it while it was flashing and plugged it back in. I have tried plugging and unplugging very quickly, but that is before the lights start blinking. When I get home, I will plug in, wait for it to start flashing, and while flashing, I will unplug and plug back in. Maybe that will do something!
  11. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Just tried that.
    Didn’t work!
  12. Gianni I
    Gianni I Member
    71
    40
    Long Island
    So the “blinking” that I think the other poster is referring to is when a charging schedule is set. You plug in the charger and a slow blink occurs to tell you that a Charging schedule is active.
    If you unplug and plug back in that overrides the schedule and “charges now”
    the blinking I’m getting is NOT the same as that blink. It’s a much more rapid blink (like 2 to 1) when compared to the charging schedule blink.
    Good thought, but that’s not it
  13. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Check out the attached page. It talks about TWO different flashing patterns. One is okay, the other is bad.
    Actually, if you don't have a hard copy of the manual, you should try for a pdf copy. Mine has some more involved troubleshooting steps but they might not be same for my 2020 as for your 2017.
    Other than this, I'm out of ideas.
  14. Gianni I
    Gianni I Member
    71
    40
    Long Island
    That is helpful thanks. The rapid flashing is what I get exactly. I downloaded my 2017 manual and there is no section like the one you have in yours. I looked around elsewhere on the 2020 manual and every troubleshoot thing says to "Stop charging and contact Toyota Dealer" lol
    Shit out of luck now!
  15. bisco
    52,066
    call toyota and ask for goodwill warranty
  16. Gianni I
    Gianni I Member
    71
    40
    Long Island
    Not a bad idea, call Toyota Corporate I assume?
  17. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    What baffles me is that the green light is saying that there's something wrong, but the rest of the system is saying that everything's fine. It seemed like the system thought it was in the middle of a charge schedule, but it doesn't look like that's the case.
    Other than the visual inspection that I mentioned earlier, the only thing left is to load the parts cannon! The problem with that is the dealer will be using new parts at outrageous prices. You might consider buying a few used parts and swapping them yourself. If it doesn't help, at least you're not out a huge amount of cash. A charger inlet port is less than $100. The 'ELECTRIC BATTERY CONVERTER INVERTER CHARGER' module (i.e. the electronics for the AC charger function) is less than $200.
    If you can get access to the service manual there might be some more clues there. At least it would show you some potential parts/modules to replace.
    BiomedO1 likes this.
  18. BiomedO1
    3,774
    1,961
    SacTown, Ca
    IMHO; after 8 years of stabbing that charging connector into that socket - there's a high likelihood those pins got pushed back or they're waddling around back in there, therefore causing the ground fault that's tripping the safety cut-off.
    I believe another guy removed his rear panel to replace his socket, only to find a loose ground nut to the car frame. He removed the nut and connector. Cleaned up the ground point and retighten. Everything started working again. He now had a new spare J1772 socket.
  19. Gianni I
    Gianni I Member
    71
    40
    Long Island
    I visually inspected the ports and it seems totally fine. My wife has a plug in hybrid as well and I compared against hers (which charges normally) and they look identical. Can't see a single thing that looks off/bent/out of place, etc.
    I'm not taking anything apart myself, that is certainly not one of my strengths.
    I will call Toyota corporate and see if they can help me out with a goodwill warranty claim.
    Appreciate all the help and certainly keep the ideas coming!
  20. bisco
    52,066
    there should be a phone number in the back of the manual for customer service
