My Gen.2 -Now only holds 31/2 gallons of gas in the tank bladder
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Nov 14, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,670
    791
    Southern California
    I suspect the problem with pressurizing the bladder to expand it is that it can break some connection inside the tank. The bladder itself may or may not be able to expand more after this treatment, but if one of the fittings to the bladder now leaks it isn't a win.
    This bladder tank brings to mind the pistons used in thermodynamics class - perfect seal, frictionless, massless. I can just picture some Toyota engineer mulling a gas tank with an equivalently unobtainable large flat piston sitting on top of the gas in a steel tank, moving up and down as it fills and empties, never allowing a gas pocket to form on top. One moving part, almost no evaporation. Minor problem - impossible to make that way. Then maybe they thought, let's put a bladder in the tank and keep it pumped up to fill that air space. Complicated thing keeping that filled properly, but the tank would otherwise have been completely conventional. In retrospect, it would likely have been many fewer parts, but prone to failure when the pressure regulation mechanism broke or glitched. Then they had an insight, let's put the gas in the bladder, all we need is a few tubes and valves! Clearly one of those situations where the lack of a manager willing to to enforce KISS let things get out of hand.
  2. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    You guys are going down the "blame the bladder for everything" rabbit hole.
    The bladder is not to blame, just a convenient scapegoat because you don't understand how the system as a whole really works.
    Stop flogging a dead horse.
  3. pasadena_commut
    2,670
    791
    Southern California
    True, also not true. If the bladder wasn't there the evap system would be so much simpler (see the pix of the Japanese vs. USA tanks I posted earlier) that it would likely only have two valves, a CC, and some hoses. So while the bladder itself might not be causing the problem, the fact that it is present made the whole system much more complex and harder to fix.
  4. dolj
    dolj Senior Member
    8,450
    4,291
    That's why I said knowledge of the whole system.
  5. ChapmanF
    18,251
    Gen 3 evap system, no bladder:
  6. Mendel Leisk
    41,536
    "Purge VSV" looks to be that little black box gizmo mounted on underside of intake manifold, incoming hose from gas tank, outgoing hose to spigot at 6 o'clock of the circular base of intake manifold, just below throttle body.
  7. ChapmanF
    18,251
