08 prius keep dying
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Oct 16, 2025.
  1. Brian1954
    Brian1954 Senior Member
    2,137
    828
    South Central PA, USA
    It looks like you also need pages 05-1159 and more of the repair manual to follow the steps.
  2. richard203
    richard203 Member
    268
    57
    SF
    ya after 05-1159 its gonna be more work. the step i posted just to test the ecu or the wires bad. hoping its either the ecu or wires and not major stuff.
  3. richard203
    richard203 Member
    268
    57
    SF
    I have a question any 1 know what cable hes talking about? Because I have my hybrid battery replaced by Green Bean, before this problem happen and the guy said it was a cable that wasn't grounded when changing out the big battery don't know if its the hybrid or 12v but I did replaced both battery.
    Here's the video.
  4. richard203
    richard203 Member
    268
    57
    SF
    I have a question when you saying the detection condition Transmission control ECU IG OFF command malfunction, - do that mean the transmission control ecu is not getting any power or signal?
    I saw alot of people jumping the fuse box when they got the parking P malfunction error on their mfd but they never say what code they got.
    Tombukt2 likes this.
  5. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    That's just the very brief memory jogger the manual says in the DTC chart. What you need to do to actually diagnose the code is in the HV section of the repair manual.
  6. Tombukt2
    12,900
    2,315
    Yeah I'm totally confused by all that no doubt . Not sure what ground slips off at engine for HV battery replacement? I've never been to the front of the car had the hood up for a battery replacement hv that is .
  7. richard203
    richard203 Member
    268
    57
    SF
    do you know if the jumping the fuse with a wire works? I see alot of people on youtube using that trick. people say some times the fuse to another fuse wire it get corroded or the wire get loose and throw a p malfunction on the MFD.
  8. dolj
    dolj Senior Member
    8,428
    4,285
    There is no "jumping the fuse" that I've read.
    There is a jump wire you can install to bypass a broken wire in the plug or connect that is at the top of the engine bay fuse box.
    This thread has the details: Jumped wire in fusebox.
    It is a fix if you get the P Lock message on the MDF. Otherwise, it won't be of much help.
  9. richard203
    richard203 Member
    268
    57
    SF
    I won't know if I got the P lock message since my MDF is broken
  10. dolj
    dolj Senior Member
    8,428
    4,285
  11. Tombukt2
    12,900
    2,315
    C2310 I believe is the p lock error or one that involves the p lock error this is wer they talking about pin13 needing to detect 12V to remember the park lock position ..
  12. Tombukt2
    12,900
    2,315
    Look for 2310 then chk.pin13 in fuse box top rt corner under bulk plastic cover pin 13 has battery voltage you should not need jumper .
