2009 Prius - dash lights but no codes?
Discussion in 'Gen 2 Prius Technical Discussion' started by jimrothstein, Nov 18, 2025 at 1:22 AM.
  1. jimrothstein
    jimrothstein New Member
    Eugene, OR
    I have had 2009 Prius Hybrid for about 1 year. Total miles 120K.
    Last 3 days, I've had these these lights (see image)
    Car seems to drive fine.
    - Big red triangle
    - VCS
    - Brake (yellow)
    - "CHECK"
    At AutoZone the scanner found no codes; no problems ?!
    Appointment at repair shop tomorrow. Shop wants to do tests, which can add up quickly.
    My concern is not getting overcharged, especially for "tests"
    And if it is big battery, what kind of questions should I be asking? Check modules?
    Thanks for any thoughts.
  2. dolj
    dolj Senior Member
    8,422
    4,283
    Wellington, New Zealand
    The only thing those lights tell you is that there are diagnostic trouble codes (DTCs) that need to be read. Until you do that you're flying blind.
    The most important thing you can do is ask that your shop read the codes, document them, and give you a copy of them.
    Armed with those codes, more advice can be given.
    Brian1954 likes this.
  3. bisco
    51,832
    make sure you go to a shop with prius aware scanner, otherwise, they might be flying blind.
    shouldn't cost much for a scan, don't let them do anything costly until you look up the code meanings
  4. jimrothstein
    Eugene, OR
    Update from OP:
    Car in shop; tech showed me voltage on modules(?) 1-5 constantly switching; other banks the voltage was stable.
    Shop will now examine battery and will advise.
    (AutoZone device showed NO codes).
    Possible just some corrosion and he can remove. Otherwise, looking at battery replacement. (age is 16 years).
    Now, I am learning battery 101. Tech will advise, but I need to understand various options he may suggest: new Toyota battery, new 3rd party ?, or find rebuilt battery, etc.
