Defog Windshield without dehumidifying
Discussion in 'Gen 3 Prius Technical Discussion' started by FrugalBeeotch, Nov 20, 2025.
  1. FrugalBeeotch
    FrugalBeeotch Junior Member
    People's Republic of Seattle
    2013 Prius Plug-in
    I have a 2013 Prius Plug-In. I live in PNW, so it is very humid in the winter, but also cold. I've noticed if I try to defog my windshield, suddenly very cold, dry air is coming from those vents and it feels like the A/C is on, as it immediately kicks on the IC engine. When the windshield is defogged, I switch it to blow out the vents to warm me and the pup, but suddenly it blows out all the humidity that was in the A/C coils, and I'm back to a foggy windshield.
    So here's my question: is there a mode, or a setting, where I can defrost the window with only heat (no dehumidifying)? I absolutely hate having the A/C running in the winter. It dries my sinuses and causes me all kinds of trouble.
  2. BiomedO1
    3,968
    2,091
    SacTown, Ca
    The quick answer is NO. Warm humid air recirculating around will simply lead to refogging of the glass. Add to that the air you and your pup are exhaling into an enclosed space with cold glass all around you. It's a lot worse than a foggy bathroom mirror because the other sided of the glass is much colder. It's simple physics - same reason a cold beverage glass sweats.
    Bottom line; you need to lower the humility of the air within the cabin to keep the glass from refogging.
    YMMV
  3. ASRDogman
    ASRDogman Senior Member
    7,724
    3,960
    Cold air outside, warm air inside.
    Are you using the defogger button so it blows A/C air on the windshield?
    You can also use a rag to wipe the windshield off...
  4. VelvetFoot
    VelvetFoot Active Member
    1,079
    407
    New York State
    2026 Prius
    Does spitting on it first help with the effectiveness, like with a diving mask?
  5. VelvetFoot
    1,079
    407
    New York State
    2026 Prius
    Has that changed over the generations? I'm pretty sure my Gen 5 doesn't automatically crank up the A/C on defrost, but I'll check the manual.
    How about a mix of defrost and front vent? Is there a position for that?
  6. BiomedO1
    3,968
    2,091
    SacTown, Ca
    There are a few anti-fog products in the market, but due to the high humility - you'll constantly be reapplying it.
  7. VelvetFoot
    1,079
    407
    New York State
    2026 Prius
    It's not like you have it on recirc, right?
  8. BiomedO1
    3,968
    2,091
    SacTown, Ca
    You actually need it set for recirculate to dehumidify the cabin and prevent other glass in the cabin from refogging. I'm surprised that a lot of people don't know that. While your windshield may be clear and your rear glass, only if you've got the defogger ON back there too. All your side glass will fog up, so your door mirrors would be useless. The good thing is that you won't see that T-bone coming at you.:( Or the cars in the lanes next to you.
    FWIW; it's raining today where I'm at. HVAC in manual mode, lo fan speed temperature set for 68F; didn't have to defog anything nor did I have to turn-on any defogger.
    #8 BiomedO1, Nov 20, 2025
  9. VelvetFoot
    1,079
    407
    New York State
    2026 Prius
    Gee, I wonder how people lived without air conditioning in their cars. :)
  10. BiomedO1
    3,968
    2,091
    SacTown, Ca
    I'm a bit bougie; I had a swamp cooler option in my 1950 Oldsmobile.:cool::D:LOL::ROFLMAO: The heater core in that would turn the interior into a sauna. Manual doors, no fancy solenoid controlled mixer doors. DMV made me install seat belts on a safety check - told me they were missing. I told them that wasn't an OEM option, when it was new....:(o_O
    VelvetFoot likes this.
  11. AzusaPrius
    AzusaPrius Senior Member
    2,220
    929
    Very simple, set temp to HI and select the front defrost button.
    You will still get heat from your normal vents and the windshield vents will defrost the window.
    You should not be using or seeing the
    "A/C" button/light on.
    When selecting the front defrost button, if you have the system using recirculation button on, it will switch to vent in air from outside.
  12. ChapmanF
    18,418
    Pressing the front defrost button will not light the A/C button if you don't have that turned on.
    However, that's not the same as saying an OBD-II scanner showing AC Watts will show zero.
  13. Mendel Leisk
    41,785
    All our previous cars being Honda, I was a little surprised, to see no windshield-only option. Screen-grab from a 2017 Honda Fit:
    Short of stuffing something in the footwell heating vents... :rolleyes:
    It's been a while since I've used front-defrost, but I seem to recall it does light the A/C button (if it's initially off). Still (as you intimate regarding ScanGauge's AC WATTS?), it definitely is using AC.
    #13 Mendel Leisk, Nov 22, 2025
  14. BiomedO1
    3,968
    2,091
    SacTown, Ca
    If your caught in a rain storm and your wet.
    Set HVAC to recirculate, AC - ON, crank up the heat. This will dehumidify your cabin and dry you off relatively quickly. Added bonus, all your windows will remain fog free, because of the lower humidity inside. If you don't recirculate and draw in cold wet air, any glass that doesn't have a heater vent blowing directly on it, will fog up due to the temperature differential you've just created.
    Hope this information helps...
  15. ChapmanF
    18,418
    A rainstorm or other extreme outside humidity event may present about the only example where recirc would be a better setting for defogging.
    Any other time, it's fresh for the win, as that purges the car of the humidity you and your passengers produce.
    In any case, the car's going to make that choice for you:
  16. Mendel Leisk
    41,785
    Of note, at least with our Canadian spec gen 3: if you set vent mode to heat/defog, and have AC off, the car will surreptitiously use AC, as evidenced by the increasingly cool/dry feeling air coming from vents, plus ScanGuage shows AC WATTS alternating between zero and modestly higher value. The AC button light is not lit.
    priumium and BiomedO1 like this.
  17. BiomedO1
    3,968
    2,091
    SacTown, Ca
    I'm assuming; if you don't use that windshield defrost button and only the HVAC controls - it won't over-ride your re-circulation choice.
    I pretty much only use that button to force the engine-on, after an oil change - rather than do the witch-doctor dance with the pedals and buttons.
  18. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    But where does this water go? How is it removed from the cabin if at all?
    I do like this idea/concept since I always end up with foggy side windows when I think I am doing what Toyota wants. But if humidity outside is saturated (100%) then this does seem like a more logical solution if I could understand what would remove the water gas from my cabin without opening windows TM …. :D
  19. BiomedO1
    3,968
    2,091
    SacTown, Ca
    As the air moves though the cold AC coils, water participates out of the air, then the air travels through your heating coil - so warm dry air is coming out of your vents. It's the same thing when storm clouds run into mountains, it begins to rain. The water drains out of the bottom of your HVAC system. Sometimes that drain hose gets disconnected and people complain that they're foot-well is wet or it gets clogged and smelly HVAC air. Simple physics.....and your not in an air tight container.
    #19 BiomedO1, Dec 4, 2025
    priumium likes this.
  20. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    That’s why I always open my back windows when humidity is high and cabin temp is over 22°, since I know hydrology by education, but recirculating air is not ”natural” and rarely recommended in our northern climate.
    But I will definitely try this concept and reconnect here.
