Defog Windshield without dehumidifying
Discussion in 'Gen 3 Prius Technical Discussion' started by FrugalBeeotch, Nov 20, 2025 at 10:17 AM.
  1. FrugalBeeotch
    FrugalBeeotch Junior Member
    People's Republic of Seattle
    2013 Prius Plug-in
    I have a 2013 Prius Plug-In. I live in PNW, so it is very humid in the winter, but also cold. I've noticed if I try to defog my windshield, suddenly very cold, dry air is coming from those vents and it feels like the A/C is on, as it immediately kicks on the IC engine. When the windshield is defogged, I switch it to blow out the vents to warm me and the pup, but suddenly it blows out all the humidity that was in the A/C coils, and I'm back to a foggy windshield.
    So here's my question: is there a mode, or a setting, where I can defrost the window with only heat (no dehumidifying)? I absolutely hate having the A/C running in the winter. It dries my sinuses and causes me all kinds of trouble.
  2. BiomedO1
    3,488
    1,813
    SacTown, Ca
    The quick answer is NO. Warm humid air recirculating around will simply lead to refogging of the glass. Add to that the air you and your pup are exhaling into an enclosed space with cold glass all around you. It's a lot worse than a foggy bathroom mirror because the other sided of the glass is much colder. It's simple physics - same reason a cold beverage glass sweats.
    Bottom line; you need to lower the humility of the air within the cabin to keep the glass from refogging.
    YMMV
  3. ASRDogman
    ASRDogman Senior Member
    7,541
    3,894
    Cold air outside, warm air inside.
    Are you using the defogger button so it blows A/C air on the windshield?
    You can also use a rag to wipe the windshield off...
  4. VelvetFoot
    VelvetFoot Active Member
    531
    169
    New York State
    2026 Prius
    Does spitting on it first help with the effectiveness, like with a diving mask?
  5. VelvetFoot
    531
    169
    New York State
    2026 Prius
    Has that changed over the generations? I'm pretty sure my Gen 5 doesn't automatically crank up the A/C on defrost, but I'll check the manual.
    How about a mix of defrost and front vent? Is there a position for that?
  6. BiomedO1
    3,488
    1,813
    SacTown, Ca
    There are a few anti-fog products in the market, but due to the high humility - you'll constantly be reapplying it.
  7. VelvetFoot
    531
    169
    New York State
    2026 Prius
    It's not like you have it on recirc, right?
  8. BiomedO1
    3,488
    1,813
    SacTown, Ca
    You actually need it set for recirculate to dehumidify the cabin and prevent other glass in the cabin from refogging. I'm surprised that a lot of people don't know that. While your windshield may be clear and your rear glass, only if you've got the defogger ON back there too. All your side glass will fog up, so your door mirrors would be useless. The good thing is that you won't see that T-bone coming at you.:( Or the cars in the lanes next to you.
    FWIW; it's raining today where I'm at. HVAC in manual mode, lo fan speed temperature set for 68F; didn't have to defog anything nor did I have to turn-on any defogger.
    #8 BiomedO1, Nov 20, 2025 at 6:07 PM
  9. VelvetFoot
    531
    169
    New York State
    2026 Prius
    Gee, I wonder how people lived without air conditioning in their cars. :)
  10. BiomedO1
    3,488
    1,813
    SacTown, Ca
    I'm a bit bougie; I had a swamp cooler option in my 1950 Oldsmobile.:cool::D:LOL::ROFLMAO: The heater core in that would turn the interior into a sauna. Manual doors, no fancy solenoid controlled mixer doors. DMV made me install seat belts on a safety check - told me they were missing. I told them that wasn't an OEM option, when it was new....:(o_O
    VelvetFoot likes this.
