Number crunching
Discussion in 'Fred's House of Pancakes' started by Leadfoot J. McCoalroller, Apr 22, 2022.
  1. bisco
    51,837
    her system quote claims 135% of usage, so that would help with the heat pump electrical usage.
    she's on natural gas, which is skyrocketing. so a price comparison would be interesting.
    either way, i will advise her to leave the furnace in place if possible.
  2. bwilson4web
    16,187
    What utility company?
    To address this problem, make sure your battery can not be charged from the grid (an option) nor discharge into the grid (an option). In effect, the battery is only connected to the house load and never can load or return power to the grid. This means the battery can never be a load or source to the grid. But this assumes you are not "selling" your excess solar to the grid.
    Another work around is to have two EVs. One is used for daylight errands and the other is charged during the sunlight hours. The next day, swap the cars so the fully charged one runs errands and the 'drained' one takes the solar charge.
    Another option becoming more available is V-to-G converters. In effect, the EV (the utility doesn't have to know about) buffers the excess solar. However, this has to be 'engineered' just it may defer the forced transformer upgrade.
    My Huntsville utility had to be dragged to a permit to operate. So I lost about three months of solar because the "permit wasn't posted!" Part of the TVA system, they are NOT friends to home solar. Regardless, here are my specs:
    • 4.8 kW - peak solar production
    • 13 kWh battery - solar ONLY!
      • 5 kW max rate
      • no grid charging to battery
      • no grid discharging from battery
      • measured round-trip efficiency 86%
    • Significant loads
      • 7.5 kW - Tesla (44 kWh), derated to 3.7 kW but online adjustable.
      • 7.3 kW - BMW i3-REx (28 kWh), derated to 3.4 kW
    • Emergency power generator
      • 16 kW - only when grid is down and battery drained to 5% SOC
      • Does not charge solar battery
    In 2016, I upgraded from 100 A (25 kW) to 200 A (50 kW) service when transitioned from Prius to EVs. That was also when I added the 16 kW, emergency generator that is natural gas fueled.
    My November 1 to 19 metrics:
    • 339 kWh - solar production, saved $0.14/kWh (cost avoidance of high usage rate)
    • 217 kWh - grid production, $0.12/kWh
    #522 bwilson4web, Nov 20, 2025 at 6:03 AM
  3. Leadfoot J. McCoalroller
    8,068
    7,549
    Pennsylvania
    2018 Prius c
    We paid a little too much for our heat last year when we were proving out the heat pumps. They worked as advertised, but we could've saved a few bucks by burning oil for a few weeks.
    So this year we expect to fire up the oil boiler sometime in January and shut it down around March 1 and see how that works out as a hybrid system.
  4. fuzzy1
    10,402
    Are you doing this purely for lowest cost, or also to reduce carbon emissions?
    I'm often willing to pay a bit extra for the later.
  5. Leadfoot J. McCoalroller
    8,068
    7,549
    Pennsylvania
    2018 Prius c
    At this point I'm trying to put some numbers into a spreadsheet. Since moving in, we did eight seasons all on oil, one season electric, now I want to see how where the numbers go with a hybrid approach.
    Very generally speaking, when I have some numbers recorded, I can make some better decisions. After this season I'll have seen all-oil, all-electric and a mix.
    Salamander_King likes this.
  6. rjparker
    10,073
    6,238
    There are "all electric" heat strips, there are electric heat pumps with heat strip backup and there are dual fuel heat pump/ hydrocarbon solutions.
    In many parts of the country oil is not an option, metro areas have natural gas while propane is the only hydrocarbon for most of us.
    Dual fuel is an excellent option for the rest of us since heat pumps are at least 1/3 of the operating costs of heat strips alone and propane costs as much as heat strips to operate standalone.
    Dual fuel means the system can switch automatically and can be set to do so based on an economic or performance balance point.
    You get ac by default with a heat pump.
    In my mind the downside of heat pumps, with inverter based low ambient compressors or standard one or two stage psc compressors, is they are complex and don't have the same kind of truck stock serviceability as hydrocarbon based heat solutions. These days, parts can be a week out if available at all for most inverter based systems. Inverters are now shipping in traditional one or two stage units in the form of variable speed blower and condenser fan motors.
    In addition heat pumps are lucky to maintain rated btus at 32f and most lose btus as it gets colder. Meanwhile the heat load is increasing.
    Hydrocarbon heat can easily supply rated btus at any temperature and are usually oversized to begin with.
    The other advantage of hydrocarbon solutions is the relative ease of generator backup which is nearly impossible for a week of ice storms when depending exclusively on a heat pump.
    Overall I like dual fuel which costs a little more upfront but provides reliable comfort in winter and nice ac in the summer.
    #526 rjparker, Nov 20, 2025 at 3:50 PM
  7. Salamander_King
    Salamander_King Senior Member
    11,016
    8,946
    New England
    So far in shoulder season with day time temperature not lower than 25F and daytime high above 32F, the heat pumps works wonder. It is quiet, efficient, comfortable, and economical compared to using whole house oil boiler hot water heating system. As long as our electricity consumption does not go above net-zero, I will keep using electricity only to heat our home. But if the heat pump usage trips the net-zero into red, then oil boiler will be turned on. But I am curious how far down in low temperature our heat pump can function and at what efficiency. As I commented, the spec says it can work down to -31F and max HSPF2 up to 14. I am closely monitoring electric consumption of each unit and our outside and room temperature now. If the efficiency drops substantially or it can not heat adequately when outside temp gets colder, then that will indicate the heat pump alone is not suitable for whole house heating in our area. We will see how it goes. Today was the coldest day so far since we had the heat pump installed in May this year. Today morning time low was 23F and day time high temp was 36F. We still have a few more hours left today, but looks like we are going to use more than 20kWh total on heat pump operations alone. With other consumption added, ~25kWh solar generation today is not going to cover it. We started digging into the summer saving credit already. And we still have 3 months+ of real winter ahead of us.
