I have a 2013 Prius Plug-In. I live in PNW, so it is very humid in the winter, but also cold. I've noticed if I try to defog my windshield, suddenly very cold, dry air is coming from those vents and it feels like the A/C is on, as it immediately kicks on the IC engine. When the windshield is defogged, I switch it to blow out the vents to warm me and the pup, but suddenly it blows out all the humidity that was in the A/C coils, and I'm back to a foggy windshield. So here's my question: is there a mode, or a setting, where I can defrost the window with only heat (no dehumidifying)? I absolutely hate having the A/C running in the winter. It dries my sinuses and causes me all kinds of trouble.
The quick answer is NO. Warm humid air recirculating around will simply lead to refogging of the glass. Add to that the air you and your pup are exhaling into an enclosed space with cold glass all around you. It's a lot worse than a foggy bathroom mirror because the other sided of the glass is much colder. It's simple physics - same reason a cold beverage glass sweats. Bottom line; you need to lower the humility of the air within the cabin to keep the glass from refogging. YMMV
Cold air outside, warm air inside. Are you using the defogger button so it blows A/C air on the windshield? You can also use a rag to wipe the windshield off...
Has that changed over the generations? I'm pretty sure my Gen 5 doesn't automatically crank up the A/C on defrost, but I'll check the manual. How about a mix of defrost and front vent? Is there a position for that?
There are a few anti-fog products in the market, but due to the high humility - you'll constantly be reapplying it.
You actually need it set for recirculate to dehumidify the cabin and prevent other glass in the cabin from refogging. I'm surprised that a lot of people don't know that. While your windshield may be clear and your rear glass, only if you've got the defogger ON back there too. All your side glass will fog up, so your door mirrors would be useless. The good thing is that you won't see that T-bone coming at you. Or the cars in the lanes next to you. FWIW; it's raining today where I'm at. HVAC in manual mode, lo fan speed temperature set for 68F; didn't have to defog anything nor did I have to turn-on any defogger.
I'm a bit bougie; I had a swamp cooler option in my 1950 Oldsmobile. The heater core in that would turn the interior into a sauna. Manual doors, no fancy solenoid controlled mixer doors. DMV made me install seat belts on a safety check - told me they were missing. I told them that wasn't an OEM option, when it was new....
Very simple, set temp to HI and select the front defrost button. You will still get heat from your normal vents and the windshield vents will defrost the window. You should not be using or seeing the "A/C" button/light on. When selecting the front defrost button, if you have the system using recirculation button on, it will switch to vent in air from outside.
Pressing the front defrost button will not light the A/C button if you don't have that turned on. However, that's not the same as saying an OBD-II scanner showing AC Watts will show zero.
All our previous cars being Honda, I was a little surprised, to see no windshield-only option. Screen-grab from a 2017 Honda Fit: Short of stuffing something in the footwell heating vents... It's been a while since I've used front-defrost, but I seem to recall it does light the A/C button (if it's initially off). Still (as you intimate regarding ScanGauge's AC WATTS?), it definitely is using AC.
