2024 LE AWD wish to add dash cam to rear view mirror area
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by BlueZebra, Aug 17, 2025.
  1. BlueZebra
    BlueZebra New Member
    Richmond
    2024 Prius
    LE AWD-e
    and of course looking to tag into any existing supply.
    So, got mirror surround access door off, surround off, I see 1 harness that branches 1 time.
    The main harness goes into a box that looks expensive, maybe 14 wires, maybe 4 large.
    The branch adapts to what looks like an antenna.
    I see (online) how to also remove overhead console, 'chandelier' easily?
    I'm a pretty good tech.... where can I tag off 2 amps of 5 volts (switched) or 12 v, not too close to big $.
    THX!
  2. indybong
    indybong Junior Member
    Indianapolis
    I used this in my 2025 LE
  3. VelvetFoot
    VelvetFoot Active Member
    531
    165
    New York State
    2026 Prius
    I also could be interested in adding a front dash cam.
  4. otatrant
    otatrant Active Member
    320
    194
    San Francisco
    2023 Prius Prime
    XSE Premium
    VelvetFoot likes this.
  5. VelvetFoot
    531
    165
    New York State
    2026 Prius
    Wow. Sensational directions for the port installers!
  6. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    It won't be the same in your car, but you might be able to follow the idea I used for mine.
    The bottom line is that if you buy a short subscription to the official repair manual and interactive wiring diagram, you can get some very good information that makes this installation pretty easy.
    I did that six years ago and the system is still functioning flawlessly.
    Good luck!
  7. broderp
    broderp New Member
    Wednesday
    OH
    2024 Prius
    Limited AWD-e
    View attachment 285087 View attachment 285087 View attachment 285088 View attachment 285087 View attachment 285088 I bought the Toyota dashy cam. Works well and does what I need. Have not needed it yet (knock on wood) but I captured a few times when someone cut me off and had there been an accident i could prove they would have been at fault.
    I attached the instructions, tells you everything you need to know regarding disassembly, mounting and where to get power. The instructions mention a template/ service tool - very much needed to align the camera for a clear view out the windshield. The TSS Cover will be visible in most locations if you don't place it where it says to, I tried. This leaves the camera somewhat lo on the windshield but it doesn't impact visibility too bad. The worse thing is that on the 5th gen Prius, the camera must go on the passenger side, due to the rain sensor mounted to the drivers side. I 3D printed the Toyota service tool based on the template. I would be happy to share the file should anyone want to install this camera.
    Cheers,
    #7 broderp, Nov 20, 2025 at 8:07 AM
  8. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    For what it's worth, you can order a replacement adhesive panel if you make a mistake or end up not liking the placement after a time. I had to pay the full $35 the first time because I didn't know the part number and had to order through my local dealer. But you can get it for as low as $18 from the right dealer during a sale.
    PT949-08210-AD
    otatrant likes this.
  9. mingc
    mingc Junior Member
    36
    17
    Portland, OR
    2023 Prius
    XLE AWD-e
    This is for this Toyota Integrated Dashcam?
    I installed it and don't like how the template places it to the right of the hole in the header for the wire. But I didn't figure that out until I had already stuck the adhesive panel onto the glass. I had to route my wire asymmetrically around the two legs of the plastic spacers that go under the header, in order to get the wire into the hole, which annoys me. I'd like to move the whole thing so it sits directly under that hole. How did you get the old adhesive panel off and what did you use to clean up the old glue? That glue is pretty strong stuff.
  10. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes, it's for the integrated dashcam. Basically the same thing happened to me. I followed the instructions and used the template and didn't like where it was placed. So I got my first replacement panel(at full price). I'm still not super happy with the placement, so I bought a second replacement at a steep discount while buying some other parts. Haven't gotten around to redoing it again.
    It's not tons of fun getting the old one off. Nylon tools to work a corner up, then lots of pressure. IIRC, the adhesive mostly stayed with the plastic, so I think I used Goo Gone and/or rubbing alcohol to get any residue off. Heat also helps soften the adhesive, but be careful using external heat(like a heat gun) because it can melt the plastic between the glass layers which will cause it to expand and shatter the windshield. The safest choice is to wait for a hot, sunny day and let that soften the glue.
    A trick I figured out when trying to place it somewhere other than the template position is to put painters tape on the glass where the dots are or any other obstructions. Then plug in the camera and use the Toyota dash cam app to watch the live feed as you move the dashcam around to find the best spot. You might not see all the dots because of the extreme closeness, but you'll be able to see the sharp line of the painters tape.
  11. mingc
    mingc Junior Member
    36
    17
    Portland, OR
    2023 Prius
    XLE AWD-e
    Thanks! Sounds like a fun project to ruin a perfectly good summer's day! Great tip about using the live feed to check placement. I'll add the template to my shopping cart for Black Friday.
