Intake Manifold and EGR Cleaning/Replacement - How hard is it really?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ksyolsen, Oct 26, 2025.
  1. Mendel Leisk
    41,900
    Last time I did ours the one thing I missed, was connecting the PCV hose to intake manifold. It more or less has to be done after intake manifold install, and it’s easy to miss.
    ditto for MAF sensor electrical connector.
    ksyolsen likes this.
  2. ksyolsen
    ksyolsen Junior Member
    66
    28
    Haslett, MI
    2013 Prius v wagon
    Got it all put back together tonight, took about 3 hours to get the new water pump and thermostat in, oil catch can, intake, etc. etc. and all buttoned up.
    I am paranoid I forgot something since there are so many places you can forget something, but so far, no massive coolant leaks, no CEL's, and I was able to drive it home from where I was working on it without a hitch! (About a 25min drive, and the coolant level was stable when I arrived home).
    Had a slight bit of rattle/knock when I had it in maintenance mode that sketched me out, but that may have either been due to it having sat for so long this week, or the coolant working through the system, or the fact I forgot to hook up the air hose to the MAF at first lol.
    Seems to have stopped that knocking, so, hoping it was just coincidental and nothing I did wrong haha. I'm not sure if it's placebo but it does seem smoother when switching between EV and the ICE kicking in, not as much of a jolt which is great!
    Thank you to all for your help! I couldn't have done it without the guidance and suggestions you provided! I have expanded my skillset and saved a few thousand in labor costs :)
    Will followup with any updates if there are any (but hopefully no news will be good news haha)
    Thank you again :)
    Air_Boss likes this.
  3. Mendel Leisk
    41,900
    With 165k miles on the odometer, while belated EGR cleaning is always good, it doesn't amount to a "reprieve from the governor". I'd start researching head gasket mitigation, which could be simple gasket replacement, or engine swap, or something in between.. An additioanal factor in the decision: dealing with Toyota's "low-tension" piston rings, if oil consumption gets out of hand.
  4. ksyolsen
    66
    28
    Haslett, MI
    2013 Prius v wagon
    So far, the oil level has yet to drop, but will continue to monitor. I used a bore scope camera when the old spark plugs were out and the pistons have some carbon but were relatively clean, almost suspiciously so, but it was hard to tell and i haven’t had experience looking at many others so I could just be paranoid about the HG.
    I’m also using Valvoline restore and protect to help the rings if they are stuck in any way.
    How difficult is a head gasket replacement compared to the work I just did? It seems daunting, but so did the EGR work and I was successful (so far haha)
    Although I will add that I hope since there is no coolant loss, no misfires, no white smoke, passed coolant exhaust gas test, etc etc that the work I did would help preserve the HG. Of course it isn’t as ideal as if the previous owner had done it sooner, but nothing was fully clogged so that should bode well at least.
    If I can get a couple years before HG issues I will be happy. But it’s basically a game of wait until something happens haha.
    #84 ksyolsen, Nov 21, 2025
  5. ksyolsen
    66
    28
    Haslett, MI
    2013 Prius v wagon
    Here’s an image from cylinder 2 iirc, I didn’t take pictures from the others as the spark plugs were all similar condition so I figured I’d see the same thing in them all, so I only looked in 1 and 2 before just swapping the other plugs out
  6. Mendel Leisk
    41,900
    That looks a little too clean.
  7. ksyolsen
    66
    28
    Haslett, MI
    2013 Prius v wagon
    Well, figured I’d hop on here and give a little update.
    Turns out I won’t have to worry after all lol
    Deer ran out and hit my car on 12/15. Damage didn’t seem that bad so I figured they’d get it fixed. However yesterday I heard confirmation from insurance that after the supplement was sent by the body shop, they declared it a total loss.
    Thank you again for everyone’s help. Second car in 2025 to get totaled but at least now I won’t have to worry about whether the head gasket is good or not. Not my problem anymore I guess lol.
    I learned a lot and enjoy being able to say I accomplished what I didn’t think I’d be able to, and I owe it to this forum for getting me there!
    Thanks again and Happy New Year!
  8. Brian1954
    Brian1954 Senior Member
    2,402
    962
    South Central PA, USA
    I hit a deer on Dec 9th with my 2011 Prius (156k miles). The repair estimate is $5,400. The insurance adjuster will be looking at my car tomorrow to determine its value. I should know within a week if it is a total loss. If so, I will be looking for a newer Toyota.
  9. ksyolsen
    66
    28
    Haslett, MI
    2013 Prius v wagon
    Yeah, my initial estimate was about $1500, but once they got stuff apart it added another $5k. $6,500 total, vehicle was only worth about $7500 based on KBB, so I knew right away they were almost certainly gonna total it.
    I am currently leasing a 2026 Corolla LE that I negotiated a pretty good deal on. Hopefully will provide some stability for a few years to give me a break from everything that happened in 2025 lol
    Don't love the idea of a lease, but it made the most sense for our situation at this point. Stable and predictable without being locked down to owning something I don't love.
    Best of luck to you! I hope whatever happens it works in your best interest.
    Brian1954 likes this.
  10. GlitterPsycho
    GlitterPsycho Junior Member
    Temple, GA
    2013 Prius v wagon
    I had a mechanic clean mine about six months ago and the light came back on in December. I had him do it again, because i really don’t want a car payment but he did tell me it’s likely to keep happening at this point because he thinks it’s caused by the engines burning oil. No clue how accurate that is, but that’s what he told me.
  11. Mendel Leisk
    41,900
    He cleaned the EGR components, including the intake manifold? How many hours did he charge?
    You say the “light came on again”: what light, was the car scanned for codes, and what were/are they?
    what’s the miles?
    what’s the rate of oil consumption?
  12. Mendel Leisk
    41,900
    Ahh, some info here.
