My HV battery replacement experience - Australia.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by uart, Dec 3, 2017.
  1. kimmy176
    kimmy176 Junior Member
    27
    Sydney, Australia
    Sydney, Australia: my codes (P0A94) are pointing to inverter failure but the dealer has diagnosed the HV battery needs replacement. Has not confirmed if this will fix the codes by replacing it as I am concerned that we replace the HV battery and still need to replace the inverter.
    Here is the quote which is also high considering some of the other quotes I have seen around $2.5K-$3K mark on the forums.
    New Hybrid Battery - $5038.77
    Installed including diagnosis - $ 5764.77 (4 hours labour at $181.50 incl GST per hour).
    Battery not in stock needs to come from Japan and takes 4-6 weeks
  2. Brian1954
    Brian1954 Senior Member
    2,304
    919
    South Central PA, USA
    Yes, you should be very concerned about the diagnoses of a HV battery replacement. The dealer apparently did not go through the troubleshooting steps in the Toyota service manual for the P0A94 code that you have. The inverter problem is very well known here in the USA. There was a lawsuit about it, and Toyota USA agreed to cover the inverter for 20 years and unlimited miles. The P0A94 code is one of the codes covered by the 20-year and unlimited miles extended warranty.
    The only way I would let the dealer change the HV battery is if they agree that if it does not fix the P0A94 code, they will reinstall your old HV battery, and you do not owe them anything for the time they spent trying to fix the car.
    The dealer needs to go through the troubleshooting steps in the service manual for the code that you have. Ask them if they have done this and have then show you the steps that they have done showing that the HV battery needs to be replaced.
    Normally, if the HV battery needs replacing, code P0A80 will be set.
  3. Darek70
    Darek70 New Member
    Madrid
  4. Darek70
    Darek70 New Member
    Madrid
    Buenos días desde Madrid. Gracias por compartir tu experiencia. Yo ahora mismo estoy reacondicionando mi batería híbrida. Pero claro teniendo el presupuesto optaría por tu solución o sea poner una batería nueva
    Para reacondicionar mi batería con un cargador de cuatro canales tardaré unas dos/ tres semanas. Como me gusta el bricolaje lo tomo como un reto para mí, que tampoco soy un profesional y muy entendido en cuestión de eléctrica de coche y puedo aguantar sin coche estás semanas, pero realmente creo que teniendo el presupuesto la opción de poner una batería nueva es lo mejor. Saludos y buen fin de semana!
  5. bisco
    52,092
  6. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    If I understand you correctly, you are replacing your HV battery with OEM, but you are still going to recondition your old battery as a fun DIY project?
    Have a great weekend, yourself.
    (Si te entiendo bien, vas a reemplazar la batería de tu HV por una OEM, pero aun así vas a reacondicionar la batería vieja como un divertido proyecto DIY.
    Que tengas un buen fin de semana.)
  7. Darek70
    Darek70 New Member
    Madrid
    Hola DOLJ!
    Estoy escribiendo en español y igual por la traducción no ha quedado muy claro. Screenshot_20251129-130508.Hojas de cálculo.png
    Por desgracia no tengo fondos para poner una batería nueva .
    Pero también soy un afortunado porque podemos aguantar (mi mujer y mi hija) perfectamente un mes sin el coche
    Ya llevo una semana y poco a poco estoy empezando a dominarlo.
    Saludos
  8. dolj
    dolj Senior Member
    8,458
    4,294
    Mucha suerte con tu proyecto. Espero que salga bien.
    ¡Mucha suerte!
    (Good luck with your project. I hope it turns out well.
    All the best.)
