Rattle going over potholes
Discussion in 'Gen 2 Prius Main Forum' started by james909, Oct 11, 2025.
  1. james909
    james909 Member
    106
    Leeds, U.K
    It's definitely coming from behind the nearside rear passenger seat but that could be under the car then vibrating or echoing into the hatch. It could be the shock absorber. I only had the springs replaced. The rest of the strut is original.
  2. PriusCamper
    PriusCamper Senior Member
    12,687
    5,123
    Pacific Northwest, USA
    Wondering why only the Spring and not the shock? Did your mechanic recommend that or against that? If it was your mechanics recommendation and the noise is the shock then maybe you can get a discount from the mechanic and save some money.
  3. james909
    james909 Member
    106
    Leeds, U.K
    In the UK we generally only change shocks if there's a visible fluid leak. The springs were £75 each to change. I also had a front shock changed for £90. This got me through the inspection. Really 4 new strut assembly's would have been ideal. It needs other things though and costs add up. It needs two new tires soon and new brake discs on the front. The brake actuator recharges every third press.
  4. qmanqman
    qmanqman Active Member
    428
    146
    CO
    She don't look 50. She looks alien.
  5. james909
    james909 Member
    106
    Leeds, U.K
    I'm thinking it could be one of the shields attached to the underside of the car.
  6. james909
    james909 Member
    106
    Leeds, U.K
    UPDATE
    I think it's the brakes. Going over the same bumps with brakes pressed and there's no noise. Pads were changed a few months ago and I notice there are no anti squeal plates or original hardware.
  7. james909
    james909 Member
    106
    Leeds, U.K
  8. ChapmanF
    18,072
    Your gen 2 rear brakes are different from our US ones; the best answers will come from people familiar with how yours are put together.
  9. james909
    james909 Member
    106
    Leeds, U.K
    Yeah you have drums and mine are discs. They are the same as the front ones though unless your front ones are different too. It's a floating caliper on slide pins. The bottom pin is where the play is. I'm hoping to remove, lube and put back. Might need a new pin and boot. Worst case the bore in the carrier has worn and needs replacing.
  10. ChapmanF
    18,072
    In some of our US models, one or both of the slide pins will come with a rubber or plastic bushing on it to control play (diagrams in the repair manual show which one, if it's only one). Perhaps such a bushing is worn, or in a past repair, a bushingless pin was installed there.
  11. james909
    james909 Member
    106
    Leeds, U.K
    You could be onto something there. I had the pads changed in July and I don't know if that's when the noise started. This is what I've seen on eBay. Screenshot_20251122-202109_eBay.jpg
  12. Mendel Leisk
    41,318
    Looks like you're missing the lower bolt, through the caliper ear and threading into the slide pin. They forgot something on hat recent brake work?
