Lowest mile Gen 2 Prius. 5,156 miles. Back on the road after sitting 12 years.
Discussion in 'Gen 2 Prius Main Forum' started by ericbecky, Nov 1, 2025.
  1. indel
    indel Junior Member
    43
    Northwest Indiana
    That car looks like a dream now. You should make a video ad and post it on youtube.
    ericbecky likes this.
    51,843
    gen 2 best gen!
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,425
    3,299
    Madison, Wisconsin
    I fully expect this car to go 300,000+ miles.
    Assuming an average of 15,000 miles per year, that's more 20 years on the road.
    During that time you can already estimate much of the expenses you might incurr because the common maintenance and failures have already been discovered.
    It's like knowing the future, today.
    I find it an interesting experiment.
  4. indel
    indel Junior Member
    43
    Northwest Indiana
    You might just keep it for yourself and pass it on to your children. That would be a fitting tribute to your efforts to restore it.
    ericbecky and Prodigyplace like this.
  5. audiodave
    audiodave Active Member
    800
    272
    US
    What happens to oil in a year?
  6. PriusCamper
    PriusCamper Senior Member
    12,688
    5,134
    Pacific Northwest, USA
    Probably not that much. However I suspect if you pushed the oil to maximum performance limits with extreme low temps and extreme high temps as well as high RPM conditions it wouldn't work as well as brand new oil does.
  7. Prodigyplace
    12,532
    11,753
    Central Virginia
    Additived deteriorate and it accumulates condensation, the amount depending on the engine.
  8. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    Took care of some small items
    Cleaned up and gathered items for the the rear under storage tray. Jack handle, lug nut wrench, prop up bar.
    Found tie down straps and instructions. Was going to throw out the bag for the floor mats, but found floor mat hooks in there. Glad I checked. Set the hooks separately and folded up the bad and kept it.
    On the dash I was going to "fix" the tab that was not affixed on the CD warning label sticker. Realized that that's actually how it came and the unaffixed section was so the owner could more easily pull off that sticker. Decided to leave it in place.
    Re-affixed the airbag warning tag on the glove box edge. Cool to have for completeness.
    Here are some other warning tags that came with the car. Basically explaining odd noises the car may randomly make.
    20251114_102254.jpg 20251114_102301.jpg 20251114_102831.jpg 20251114_104827.jpg 20251114_104849.jpg 20251114_104909.jpg 20251114_144153.jpg 20251114_144215.jpg
    #68 ericbecky, Nov 15, 2025
    Prodigyplace likes this.
  9. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    When I took it to the dealership for the oil change they gave a multi-point inspection.
    They identified that the rear strut assemblies needed to be replaced. Slight leaking.
    So I grabbed a set and installed them today.
    Overall there were quite a few cobwebs and leaves in the wheel wells and the underside of the car. Quite a bit of debris tucked up on top of the gas tank lip. So I vacuumed/blew that out while I was underneath there.
    Also pereed at the drum brakes, which of course look great.
    Also refurbished the bracket for the brake booster capacitor. It was little crusty.
    20251117_111904.jpg 20251117_112038.jpg 20251117_113043.jpg 20251117_113215.jpg 20251117_115858.jpg 20251117_122838.jpg 20251117_130033.jpg 20251117_132634.jpg 20251117_133738.jpg
    #69 ericbecky, Nov 17, 2025 at 4:40 PM
  10. pasadena_commut
    pasadena_commut Senior Member
    2,586
    767
    Southern California
    Last time I opened mine there was quite a bit of brake dust. They didn't look like your picture until after all of that was removed.
  11. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    First time they've been opened in over a decade.
    I bought the car without even turning it on. I wasn't even sure if it would move. There was definitely a possibility that the brakes could be locked up just from sitting so long.
    I was pleasantly surprised when I could put it in neutral and roll it.
  12. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    Put on some new Bosch Icon Wiper blades. I've had them before and seem to last a long time.
    Ran one more 15 minute ozone treatment.
    Wasn't really necessary, but figured I'd give it a session anyway. I had borrowerd the machine and needed to return it today.
    Replaced the battery in the spare fob with a Duracell 2032. Double checked that it was fully functional. Yep! Good to go.
  13. xw20_driver
    xw20_driver Junior Member
    PNW
    IMO to keep the original appeal, I would have installed original Toyota wiper inserts if the car still had the factory metal blades. The Toyota inserts are replaceable and work very well, especially the rear factory blade.
    Front Left Windshield Wiper Blade - Full Assembly
    Part Number: 85222-47020
    Right Front Windshield Wiper Blade - Full Assembly
    Part Number: 85212-47021
    Left Front Windshield Wiper Insert - Rubber Insert
    Part Number: 85214-44140
    Right Front Windshield Wiper Insert - Rubber Insert
    Part Number: 85214-46011
    Rear Window Windshield Wiper Insert - Rubber Insert
    Part Number: 85214-47010
  14. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    Good thought. I'll keep the originals in storage just like I kept all the original other parts.
  15. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    I got a few small plastic parts from the dealership today.
    During disassembly some of the plastic fasteners were too brittle and broke.
    In other cases, they previously had been replaced with the incorrect fasteners, like on the engine compartment front trim piece.
    Headliner, engine garnish, bumper, in ER wheel well shields.
    I also got a new cover for the rear windshield wiper arm.
    None of these things are critical, but feels better to replace them properly given how complete the rest of the car is.
    Classic_pri, dolj and xw20_driver like this.
  16. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    Polishing up the headlights today.
    Here's an unpolished one and the polished up one for comparison.
  17. Mendel Leisk
    41,326
    Looks much better. How long did that take you, and what did you use?
  18. ericbecky
    4,425
    3,299
    Madison, Wisconsin
    Takes me 30 to 45 minutes per side.
    I find it easier to have the headlights out of the car to do it. It's so messy.
    I use the 3M headlight restoration system. #39008 (FYI. This forum automatic makes its own link for this product, although it's probably wrong. I didn't create that link.)
    You need that drill for attaching the spindle that holds the sanding and polishing pads.
    It has really good instructions.
  19. pasadena_commut
    2,586
    767
    Southern California
    I suggest before going whole hog on a headlight first try washing it thoroughly with some Dawn, then lightly polishing it (I have some ancient Turtle Wax metal polish, probably almost any polish will work), then coat with Nu Finish (the liquid car polish, not their other products). Often the haze results from dirt trapped in fine pits and scratches, and removing that, then filling the defects with Nu Finish is good enough. It doesn't remove (much of) the original lens coating, or if that is gone, the plastic underneath. That is all I have done on our 2007, which we bought used in 2019, and its headlights looked that bad by about 2020. Going this route it is necessary to wash off the Nu Finish every 4-6 months and reapply. I have tried other coatings in the past and they either got dirty faster (wax) or actively attracted dirt (a silicone based product by Blue Magic).
    If after cleaning a headlight (first step above) it looks clear when it has a good coat of water on it then this should work. If it still looks cloudy with water on it then the plastic itself is damaged internally and it must be sanded down enough to remove that damage.
