How many miles between oil changes?
Discussion in 'Gen 3 Prius Main Forum' started by taxce, Nov 22, 2025.
  1. taxce
    taxce Junior Member
    25
    california
    How many miles can you actually go between oil changes? The Prius manual says 10k but I notice the mechanic who changed my oil last put a sticker on my car to change in 5k.
    it has been about a year since my last oil change and I’ve only driven the car 4k miles this year. I need to drive another 1000 miles at the beginning of January to get back home from where I am now and was thinking maybe I can just gett it changed after that.
    Thoughts?
    51,996
    a lot of people here recommend 5k because of the head gasket issue. idk if it's true or not.
    you can't go wrong changing it early except for the financial, time and environmental costs.
    if you drive less than 5k/year, change it every spring.
    you'll be fine driving home 1,000 miles and changing it when you have time.
    how many miles on her?
    taxce likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,795
    5,180
    Pacific Northwest, USA
    In general with cheap crappy motor oil you can go 5K miles and with high quality full synthetic you can go 10K but I prefer 8K or once a year, whichever comes first.
    taxce likes this.
  4. Mendel Leisk
    41,519
    5k miles is a good number. FWIW, for gen 3's (per yours), that what Toyota Canada recommended.
    We're doing about 3k kms per year now (~2k miles), I change ours yearly.
    When mechanics put a next-oil-change sticker on your windshield, it's both advice and a calling card. Seems like sound advice in this case, but take it with a grain of salt.
  5. BiomedO1
    3,665
    1,899
    SacTown, Ca
    The old dino oil recommendations for old cars was 7500 miles. With good quality full synthetic oil, they say you should be able to go 10K miles between changes. People pick 5K mile changes because it's easy to reminder - just look at your odometer in the thousandth position; if it's a 0 or 5; it's due for another oil change. Technically speaking, oil manufactures say follow OEM recommendations or one year, whichever comes first. I really don't think oil goes bad in a year - but there you have it.
    Now that you got the information; you can now make an informed choice.
    Good Luck....
    taxce likes this.
  6. Mendel Leisk
    41,519
    Every previous car we've had I recall 5k miles (aka 8k kms), the official manufacturer's recommendation. Our son's 2018 Mazda CX-5 is no exception (see attached). Lovely format btw, Toyota would do well to adopt it, the entire schedule in one table, second page has more explanation.
  7. BiomedO1
    3,665
    1,899
    SacTown, Ca
    AI is coming up with 3K-5K or 3-months; I've never heard that before. I know Jiffy Lube was the one that started the 3K oil change interval nonsense. I found this in an old Hayes manual that references 7.5K, but oil changes at 3K intervals. Hopefully someone has an old OEM maintenance guide laying around to check. This is the reason I like PAPER; makes it more difficult to gas-light people.
    1988-1996 Ford F-150, F-250, F-350 Pickup Truck Routine Maintenance FAQ - Haynes Manuals – Haynes Manuals North America
    I believe my old 80s-90s Honda OEM change interval was 7500 miles and that was industry standard for GM and Fords, I believe back then. Somewhere in there Jiffy Lube stated that if you wanted your car to last - they recommended 3000 mile oil changes at a very cheap price. Pretty much the McDonalds of oil changes. IMHO, great marketing and franchising hype, but poor quality parts and services. Had more than a few friends pull out of there without their oil cap. They save money by hiring high school 'wannabe mechanics'. What can go wrong.....
    They may have ASE certified mechanics at current surviving franchises now.
    #7 BiomedO1, Nov 22, 2025
    taxce likes this.
  8. fuzzy1
    10,481
    The original U.S. 2010 Prius manual (April 2009) said 5k, only later did they boost it to 10k and send a notice to earlier owners, including me. But after these engines later began displaying oil and head gasket problems, there was talk that maybe 10k was a bit too "aspirational".
    taxce and BiomedO1 like this.
  9. BiomedO1
    3,665
    1,899
    SacTown, Ca
    @Mendel Leisk you made me walk to my book shelf.:mad:
    1996-1997 Honda CIVIC service manual P/N 61S0302 page 4-4; replace engine oil every 7.5K or 12 months. 3.5 US quarts.
    thought I was losing it again......:cool:o_O:rolleyes::ROFLMAO::LOL::whistle: I probably am.....:(
    taxce likes this.
  10. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    Read the "severe" driving conditions. It will tell you to change it more often.
    Like 3000 miles.
    It will depend on how long you want your engine to last.
    Albert Barbuto likes this.
  11. taxce
    taxce Junior Member
    25
    california
    about 45k
  12. Mendel Leisk
    41,519
    You've got that right:
    from: honda-accord-sedan-1990-owners-manual-linked.pdf
    With the caveat, "severe driving conditions", halve the intervals. Too, the "or 6 months" is presumably whichever comes first.
    In the early 2000's (not sure exactly when, our 06 Civic Hybrid was thus), Honda went to the Maintenance MInder system, no official, printed schedule, just a built-into-the-dash system, that worked quite well, and was a good bargaining chip when dealing with pushy service departments. IIRC with that our oil changes came up around 8~10k kms. The system seems decidedly smarter than Toyota USA's purely odo-driven maintenance reminder.
    #12 Mendel Leisk, Nov 23, 2025
    BiomedO1 likes this.
  13. BiomedO1
    3,665
    1,899
    SacTown, Ca
    Yea; I remember that; It would pop-up maintenance A,B,C, or D - depending on level of maintenance required. I believe these were 'hard-set points' programmed into the semi-electronic dash.
    My early 2000s GMC seems to have a variable maintenance minder. A friend has the same model but a year newer, his oil change minder pops around 3K-4K miles - but he tows and has a heavy foot. I don't tow and mine goes off around 7K-8K miles. FWIW
    #13 BiomedO1, Nov 23, 2025
  14. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Wow transmission fluid at 30,000 miles?
  15. BiomedO1
    3,665
    1,899
    SacTown, Ca
    Kinda makes you question the wisdom of lifetime ATFo_O:rolleyes::whistle:
  16. Mendel Leisk
    41,519
    It’s a traditional automatic, and only about half drains each time. That said…
  17. ETC(SS)
    7,183
    Oil has TWO jobs, not just one.
    There's lubrication, and it also hauls combustion by-products, and other nasties over to the filter SOME of which are held there until the next oil change. This is why the oil turns from a nearly clear fluid to the nasty black that those of us who know where the dipstick is located are familiar with.
    Generally speaking, if you're only going to keep the car for about 6 years or 150,000 miles - then all of this isn't a 'you' problem - it's an issue for the next owners.
    Oil Change arguments are like people arguing about whether or not it's a bad idea for humans to eat lots of cheeseburgers.
    It's a different argument after about 60 laps around the sun.... ;)
    Again, it depends on which 'lifetime' you're talking about.
    The car or the warranty?
  18. ASRDogman
    7,607
    3,915
    "Lifetime" in the automotive world means until the emission warranty expires.
  19. BiomedO1
    3,665
    1,899
    SacTown, Ca
    Dealership and OEM definition of lifetime is definitely 'WARRANTY PERIOD'.
    FWIW; it's also used to transport heat away from components too (ie. turbo chargers). That's why it's important to use fluids that's OEM spec'ed or better. Most heavy-duty and high performance cars has engine oil coolers and ATF is routed into the radiator to cool down and prevent thermal breakdown.
