Visual Differences between updated Intake Manifold
Discussion in 'Gen 3 Prius Main Forum' started by Juntuner, Sep 22, 2021.
  1. indel
    indel Member
    84
    29
    Northwest Indiana
    I went down this rabbithole last night reading up on every comment and was dismayed to learn that x91 was not a new, better designed part. My Prius probably has x50, so I will just clean it up for now and call it a day.
    Tombukt2 likes this.
  2. ChapmanF
    18,152
    I'm pretty sure Toyota introduced it because they did consider it an improved design.
    On the other hand, maybe it won't matter to you if you don't experience the issue they improved it over.
  3. rjparker
    10,135
    6,298
    It is certain the intake was an improved design. It is designed to eliminate codes stored in certain cold starts when combined with an ecm software update.
    Toyota also updated their gen3 head gasket, pistons, rings and egr valve. All in an attempt to make the gen3 engine more reliable. In fact 2017-2021 gen3 engines sold overseas have a good reliability record even though they share the same gen3 engine. Which makes JDM engines of that vintage good options now or professionally rebuilt engines using those parts a better choice.
  4. ChapmanF
    18,152
    Somehow I keep forgetting that more than one TSB announced revisions to the gen 3 intake manifold.
    T-SB-0010-12 was the one about snorting condensed water from the EGR passages. That's the one I usually remember. It said to update to a -52 manifold in the first revision, then later to -54.
    T-SB-0103-12 was about the throttle body sticking open. Looks like I knew about that four years ago but I usually don't remember it. It says to update to a -91 manifold.
    I don't think I had ever even stumbled on T-SB-0116-15, which is also about replacing the manifold, this time for misfiring when driving with EGR active (the usual effect you'd get if the passages were gunky, fixable by cleaning them). That one also pushed the -54 manifold (rather than taking the time to clean the existing one).
    The most interesting one I forget to think about is T-SB-0103-12. The symptom is a P2111 code, which is when the ECM tells the throttle to close and that doesn't happen, and apparently that was (not) happening below 23 ℉ (−5 ℃), and they somehow meant the -91 manifold to improve that. Hard for me to guess why, but that might be the one that comes closest to giving a reason for the weird griddy gasket under the throttle body.
    Edit: typoed the number of a TSB
    #84 ChapmanF, Nov 18, 2025
  5. indel
    indel Member
    84
    29
    Northwest Indiana
    As has been discussed earlier in this thread, there is no x91 manifold. The x91 is a reference to a x54 manifold kit with all the gaskets included. So the latest design seems to be x54.
  6. ChapmanF
    18,152
    I had seen that discussion, but I might not be all on board with the conclusion yet. Why?
    A few reasons. First, this would be a departure from what we're all used to where kit part numbers start with a PNC of 04xxx-. This would be an instance of a kit having the same PNC (17120 for an intake manifold) as the non-kit item, which would be weird.
    Second, I think the main evidence advanced is that some have ordered by the 17120-37091 part number and received a manifold that has 17120-37054 visibly marked on it.
    But that kind of thing isn't terribly unusual; we've had recurring discussions on PriusChat about the way Toyota parts sometimes have numbers visible on them that aren't their part numbers. There can be different explanations; the visible number might be an engineering number, or the private part number of some constituent part, or maybe the number of a rough item before some kind of finishing step.
    I'm not sure what's happened here; it's again weird, having the visible number be the valid number of a previously-marketed part. Did they find a way to take New Old Stock x54 manifolds and rework them to be x90 / x91 equivalents? Beats me. But it wouldn't be the first time that ordering by one number gets you something with a different visible number on it.
    Also weird that T-SB-0103-12 has a big 'HINT' right in it saying the number on top of intake runner #4 is the part number. So, weird that they wouldn't grind or melt or in some way change it if they have, indeed, reworked the part somehow. Weird also because it would lead you to keep endlessly replacing the part if the customer comes back, because the x54 number is included in the list of 'PREVIOUS' numbers to replace.
    So, I totally can't say that I have the explanation. But I'm also not sure "it's a kit" is quite it.
  7. indel
    indel Member
    84
    29
    Northwest Indiana
    You are definitely onto something with your hypotheses. I was, until recently, not aware that the kit numbers all started with "04...". My experience comes from ordering the EGR valve kit (04004-58137) and then seeing the valve listed in other places as (25620-37130). So it took some research to finally figure out that the kit came with gaskets and the regular valve didn't.
    You would think a competent dealership would be able to shed some light on the progression of manifold part numbers, but we are probably expecting too much from them.
  8. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    Let's take this back a bit for those just now tuning in !!:D
    How much different can plastic intake manifolds be for a direct replacement?
    I mean,(n) if your engine (and the way you use it), makes a lot of moist and oily fumes, and they are sucked into the intake to be digested,
    how different can it be?
    Maybe the original had low points that collected the moist gunk?(n) The new one doesn't? (y)
  9. ChapmanF
    18,152
    Maybe there's such a thing as taking it back a bit too far.
    We'd probably have to at least remember that the manifold design was revised at least twice (from the original to the x52 and then x54 number, and then to the enigmatic and elusive x91), and that these revisions got touted in at least three different bulletins that were about solving three different issues.
    Two of the differences so far mentioned are: (1) a difference in routing of the small EGR gas passages, and (2) cut to accommodate, under the throttle body, a different gasket with a weird grid insert.
    I think I kind of know what the EGR passage changes were meant to do. The griddy throttle-body gasket baffles me, but it is something that started appearing in more cars around a certain time.
    Bill Norton likes this.
  10. indel
    indel Member
    84
    29
    Northwest Indiana
    I finally bit the bullet and ordered a new intake manifold (17120-37091) and will report back on whether they actually send me x91 or x54.
  11. ChapmanF
    18,152
    You'll be reporting back on whether the one they send you has x91 or x54 as the number visible on it—which, because numbers visible on Toyota parts are not always their official part numbers, is a subtly different question.
  12. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    Pretty sure you will let us know that the manifold has 54 stamped on it and the box has 91 on it.
    The manifold will come with the designed gaskets.
    Would be awesome if there is an actual new molded manifold but I doubt toyota did that.
  13. indel
    indel Member
    84
    29
    Northwest Indiana
    Yeah, I guess so. I also sent an inquiry to Toyota's corporate office to get them to explain the issue with x54 stamp on x91 boxed manifold. I doubt I will hear anything, but may be we will get lucky.
  14. indel
    indel Member
    84
    29
    Northwest Indiana
  15. indel
    indel Member
    84
    29
    Northwest Indiana
    So I finally received the intake manifold (17120-37091). It is, as expected a 17120-37054. Let the pictures speak for themselves:
  16. ChapmanF
    18,152
    Or, at least, it is a manifold with the number 17120-37054 visible on it.
    For whatever reason, I see no pictures, but there is extra blank space in the post.
  17. rjparker
    10,135
    6,298
    From post 95
    IMG_0809.jpeg IMG_0810.jpeg IMG_0811.jpeg IMG_0812.jpeg IMG_0813.jpeg IMG_0814.jpeg IMG_0815.jpeg
    StarCaller likes this.
  18. ChapmanF
    18,152
    I wonder why none of that shows up when I view #95? Where are the original pics hosted?
  19. Mendel Leisk
    41,411
    Imgur
  20. indel
    indel Member
    84
    29
    Northwest Indiana
    It might depend upon what device you are using to view the forums. The pictures are posted on imgur which I find to be a much better platform than posting them directly on priuschat.
