Highest Mile Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Dec 26, 2017.
  1. kirill626
    kirill626 Junior Member
    27
    32
    Los Andgeles
    My 2017. I'm the second owner and I don't know how many EV miles it was possible to drive when the car was new. Now depending on the outside temperature it is from 20 to 30 miles. On average 25.
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    I’m pretty sure there have been a couple pushing 400k about 6 months ago
  3. kirill626
    27
    32
    Los Andgeles
    Regular, not Prime. From securitas company and Wheels seller. I bought 2019 Prius in 2020 at Golden Gate Adesa with 198k miles and a head gasket has failed and the CR 3.5 all OK.. 200k miles in a year and a half! fixed it and still runs
    like this
    #23 kirill626, May 10, 2024
  4. Hydrocket
    Hydrocket Member
    79
    39
    CA
    Technology
    I have 250k kms on my 2017...
    SM-G981W ?
  5. pasta4breakfast
    121
    59
    Anaheim, CA
    2020 Prius Prime
    If you look at the Hwy_boy’s most recent reply to their pinned comment on the above YouTube video, they have a 2019 Prius prime with 522,000 miles on it as of nine days ago. The YouTube video is of the Car Care Nut inspecting it about a year ago with 341,000 miles on it. I think I remember Hwy_boy mentioning they have only done scheduled maintenance and transmission fluid drain and fill every 80,000 to 100,000 miles.
  6. Scarface2005
    Scarface2005 Member
    93
    47
    San Bernardino Mountains
    I’m at 145k miles on my 2020 prime. Only issue so far is the stupid smart 12v battery is a puny worthless piece of crap, and car won’t start after sitting at the airport for a week. But, I have a portable jump pack there in the car so that’s a relatively minor inconvenience. I bought it used in 2022 with 109k miles and a solid maintenance history. It’s running great and has averaged 63.7mpg over the 36k miles I’ve put on in 18 months.
    I also have a 2017 prime w 140k miles. Same thing; only issue so far has been 12v battery. So far I’ve only done oil changes every 5k-10k miles, and throttle plate cleaning every now and then. The 2017 seems due for new spark plugs bc of rough start when the engine kicks in cold.
    I have maintained four different prii for over 500k of driving thanks to the folks here at PriusChat :)! we were chasing the California HOV lane stickers. Each one could’ve run to a million miles or more. Looks like we’re still waiting to see what issues the first gen 2017-2022 prime will have…?
    john1701a likes this.
  7. pasta4breakfast
    121
    59
    Anaheim, CA
    2020 Prius Prime
    Hwy_boy just re
    Hwy_boy just recently sold his 2019 prius prime with ~ 620K miles on it due to headgasket issues. He drove mostly highway miles and barely ever plugged it in. .
  8. BiomedO1
    4,253
    2,231
    Left Coast
    Did he monitor his ECT or ever change his electronic coolant pump? They're know to get lazy and/or intermittent around 150K miles of 'normal' driving. Probably should start monitoring or preemptively replace it around 300K all highway driving, rather than rely on the dummy lamp.
    Just my two-cents.....
  9. pasta4breakfast
    121
    59
    Anaheim, CA
    2020 Prius Prime
    I believe he changed the water pump at about 490,000 miles, but only after it through a code, not preemptively.
    BiomedO1 likes this.
  10. BiomedO1
    4,253
    2,231
    Left Coast
    So he could've been running hot for a good long while without knowing it - since it's mostly highway driving. Pop goes the head gasket. I plan on installing one of those HUD units and program an alarm - before I break 100K miles; so I can hopefully side step this issue.
    pasta4breakfast likes this.
  11. pasta4breakfast
    121
    59
    Anaheim, CA
    2020 Prius Prime
    Interesting. What coolant temperature would you set the alarm for and would this alarm you before any codes or check engine light?
  12. BiomedO1
    4,253
    2,231
    Left Coast
    The Prius doesn't store overtemps or trigger the CEL. I believe water pump over-rev or under-rev may trigger a CEL or if the pump is totally dead, full open or close circuit. Just a lonely flashing or solid temperature lamp. If you drop back below the threshold, the lamp will extinguish. I find it amusing when people say that the lamp only came on for a second then disappeared when they release the accelerator pedal, so they think everything is A-Ok...
    I drive in the Sierras a lot so I know I'm stressing and heating up the engine on those long climbs. I understand the cars normal operating temperature is 185F-205F, so I thinking of setting the alarm at 210F. If the alarm goes off on hard climbs; I'll know to back-off. The OEM lamp triggers around 248+F. So you could be running hot 245F all day long, day-in and day-out; not knowing that your chipping away and headed for a head gasket failure.
    All of my other cars had a temperature gauge; don't know why these don't....o_O:rolleyes::cry::sleep:
    #32 BiomedO1, Nov 30, 2025
  13. pasta4breakfast
    121
    59
    Anaheim, CA
    2020 Prius Prime
    Good to know. Most of my miles are in reasonably flat populated areas, but I am doing a road trip to Yosemite in May. I will definately plug my OBD scanner for the trip to monitor the coolant temp. Unfortunately, most car manufacturers have eliminated the coolant temp display gauge on the dash in their newer models.
