Highest Mile Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Dec 26, 2017.
  1. kirill626
    kirill626 Junior Member
    27
    32
    Los Andgeles
    My 2017. I'm the second owner and I don't know how many EV miles it was possible to drive when the car was new. Now depending on the outside temperature it is from 20 to 30 miles. On average 25.
  2. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    I’m pretty sure there have been a couple pushing 400k about 6 months ago
  3. kirill626
    27
    32
    Los Andgeles
    Regular, not Prime. From securitas company and Wheels seller. I bought 2019 Prius in 2020 at Golden Gate Adesa with 198k miles and a head gasket has failed and the CR 3.5 all OK.. 200k miles in a year and a half! fixed it and still runs
    like this
    #23 kirill626, May 10, 2024
  4. Hydrocket
    Hydrocket Member
    79
    39
    CA
    Technology
    I have 250k kms on my 2017...
    SM-G981W ?
  5. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    If you look at the Hwy_boy’s most recent reply to their pinned comment on the above YouTube video, they have a 2019 Prius prime with 522,000 miles on it as of nine days ago. The YouTube video is of the Car Care Nut inspecting it about a year ago with 341,000 miles on it. I think I remember Hwy_boy mentioning they have only done scheduled maintenance and transmission fluid drain and fill every 80,000 to 100,000 miles.
  6. Scarface2005
    Scarface2005 Member
    93
    47
    San Bernardino Mountains
    I’m at 145k miles on my 2020 prime. Only issue so far is the stupid smart 12v battery is a puny worthless piece of crap, and car won’t start after sitting at the airport for a week. But, I have a portable jump pack there in the car so that’s a relatively minor inconvenience. I bought it used in 2022 with 109k miles and a solid maintenance history. It’s running great and has averaged 63.7mpg over the 36k miles I’ve put on in 18 months.
    I also have a 2017 prime w 140k miles. Same thing; only issue so far has been 12v battery. So far I’ve only done oil changes every 5k-10k miles, and throttle plate cleaning every now and then. The 2017 seems due for new spark plugs bc of rough start when the engine kicks in cold.
    I have maintained four different prii for over 500k of driving thanks to the folks here at PriusChat :)! we were chasing the California HOV lane stickers. Each one could’ve run to a million miles or more. Looks like we’re still waiting to see what issues the first gen 2017-2022 prime will have…?
    john1701a likes this.
  7. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    Hwy_boy just re
    Hwy_boy just recently sold his 2019 prius prime with ~ 620K miles on it due to headgasket issues. He drove mostly highway miles and barely ever plugged it in. .
  8. BiomedO1
    BiomedO1 Senior Member
    4,600
    2,414
    Left Coast
    Did he monitor his ECT or ever change his electronic coolant pump? They're know to get lazy and/or intermittent around 150K miles of 'normal' driving. Probably should start monitoring or preemptively replace it around 300K all highway driving, rather than rely on the dummy lamp.
    Just my two-cents.....
  9. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    I believe he changed the water pump at about 490,000 miles, but only after it through a code, not preemptively.
    BiomedO1 likes this.
  10. BiomedO1
    4,600
    2,414
    Left Coast
    So he could've been running hot for a good long while without knowing it - since it's mostly highway driving. Pop goes the head gasket. I plan on installing one of those HUD units and program an alarm - before I break 100K miles; so I can hopefully side step this issue.
    pasta4breakfast likes this.
  11. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    Interesting. What coolant temperature would you set the alarm for and would this alarm you before any codes or check engine light?
  12. BiomedO1
    4,600
    2,414
    Left Coast
    The Prius doesn't store overtemps or trigger the CEL. I believe water pump over-rev or under-rev may trigger a CEL or if the pump is totally dead, full open or close circuit. Just a lonely flashing or solid temperature lamp. If you drop back below the threshold, the lamp will extinguish. I find it amusing when people say that the lamp only came on for a second then disappeared when they release the accelerator pedal, so they think everything is A-Ok...
    I drive in the Sierras a lot so I know I'm stressing and heating up the engine on those long climbs. I understand the cars normal operating temperature is 185F-205F, so I thinking of setting the alarm at 210F. If the alarm goes off on hard climbs; I'll know to back-off. The OEM lamp triggers around 248+F. So you could be running hot 245F all day long, day-in and day-out; not knowing that your chipping away and headed for a head gasket failure.
    All of my other cars had a temperature gauge; don't know why these don't....o_O:rolleyes::cry::sleep:
    #32 BiomedO1, Nov 30, 2025
  13. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    Good to know. Most of my miles are in reasonably flat populated areas, but I am doing a road trip to Yosemite in May. I will definately plug my OBD scanner for the trip to monitor the coolant temp. Unfortunately, most car manufacturers have eliminated the coolant temp display gauge on the dash in their newer models.
  14. OptimalPrime
    OptimalPrime Active Member
    172
    100
    Keene/Nashua
    I feel like I'm slacking with only 151K miles in 107 months of owning my '17 Prime.
    Mechanically and battery-wise, it seems as good as new.
    Some scrapes and dings, occasional clicking noises from the inlet air door, that's about it.
    An ex girlfriend who I helped get a deal on a '17, 3 months after I got mine, recently sold hers.
    After discount, rebate, state EV incentive, and Federal tax credit, the car had cost her $16K new.
    Somehow, I had gotten her a $500 better deal than on mine. Maybe the second negotiation session was a charm.
    Anyway, she recently sold it with 162K miles on it, for $10K, with numerous scrapes and dings.
    She was quite happy with having owned it for under $0.04/mile depreciation, while also getting reimbursed a lot of business mileage.
    So, she actually made money owning the car (if you ignore operating costs, and maybe even if you don't ignore them), as I had predicted when I convinced her to stop using a minivan for commuting and business miles.
    pasta4breakfast and dig4dirt like this.
  15. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    Just back from my road trip to Yosemite. The coolant got up to 208.9 degrees F going up the grapevine in 91 degree F weather, so I turned off the AC for a bit and slowed down below 55 mph behind a truck till it went back down. I took the 41 from Fresno to Yosemite instead of the Tioga pass, so the trip wan't too hard on the cooling system apart from the grapevine in the afternoon. This was actually in my 2013 prius C with 173,000 miles. I am trying to limit the miles on my prime until I hit 150,000 inorder to keep that HV battery warranty as close to 10 years as possible. An alarm would be nice, so you don't ever have to take your eyes off the road.
    #35 pasta4breakfast, May 24, 2026
  16. OptimalPrime
    172
    100
    Keene/Nashua
    It's a double-edged sword to gamble on whether to run a car hard, versus nursing the max years out of the battery warranty. What if it fails after 10.1 years regardless of mileage? Then maybe you could have gotten an extra 50K or 100K miles out of the original battery before it fails. Likewise, some people try to abuse their battery so it will fail before the 150K miles, and it's not quite dead yet, but fails at 160K.
    Personally, I decided to go pretty easy on my battery and let the cards fall where they may as far as how long it lasts. No sign of any degradation after 9 years and 153K miles now.... and I had moved from a 150K mile state to a 100K mile state not long after 100K miles!
  17. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    I agree. I worked my battery really hard the first 6 years. I drove about 110,000 miles over that time, plugging-in the battery 3 times a day, 5 days a week. I charged the car at home, at work 35 miles away and at a free charger half-way to work. Most of the year I could do the whole commute without any gas. However, I had to use less AC than I probably should have. The battery continued to behave very well for 6 years. Then I noticed a steep drop in estimated battery capacity last December.* See graph below. I knew I would reach 150,000 miles in 8 years and I figured there was a reasonable chance that my punishing routine could wear the battery out between year 8 and year 10. My wife has a shorter commute, so I now have her drive it 40 miles with 1 charge instead of my 70 miles with 2+ charges. It may have been a coincidence, but the battery capacity actually bounced back. Then in May the free mall charger became $0.43 per kWh plus a $1 connection fee, which made the decision even easier. Maybe all this charging would just affect the battery’s capacity, which isn’t covered by the warranty. However, if it actually causes it to stop working, I would prefer that to happen while it’s under warranty or at least get the maximum amount of EV miles out of it. On a road trip, the prius C doesn't get much worse mpg than the prius prime and its battery is much cheaper to replace if needed.
    * battery capacity estimated by the amount of kWh accepted from a charge point station to fully charge it
    #37 pasta4breakfast, Jun 21, 2026
    OptimalPrime likes this.
