Refrigerant Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C-in-DC, Apr 10, 2023.
  1. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Windows closed. Won’t go to green.
    #121 C-in-DC, Aug 13, 2023
  2. rjparker
    10,227
    6,386
    40f is excellent. This system protects itself from freezing the evaporator. This isn't your father's car ac!
    After fifteen minutes or less you normally need to turn down the fan.
    The ac repair manual is 400 pages long. Here's a taste:
    priumium likes this.
  3. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Guess I was fortunate. Thank you again to everyone. The tools I bought will collect dust but maybe I’ll get to charge another vehicle before r134A is completely phased out. If someone needs a vacuum pump, gauge manifold, oil injector, message me. I’ll sell at 50% the original cost.
  4. rjparker
    10,227
    6,386
    You work on your central ac next. Its easier.
  5. Gourockian
    Gourockian Junior Member
    75
    New Port Richey
    Don't rent from O'Reilly's as they only give a you a few days to return anything before you end up forfeiting the full price for things that others have already used, whether you wanted to or not. I almost got caught out until I saw the terms on my receipt and managed to returm them on time.
    Autozone and Advance Autos have a better policy where you can rent for much longer before being penalized.
  6. Gourockian
    75
    New Port Richey
  7. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
  8. Gourockian
    75
    New Port Richey
    Well, that is good news but I hope that R134A doesn't cause issues with the compressor later on. There must be a reason for that warning.
  9. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Are you basing this warning on this website listing only? It is wrong.
    Gen3 uses R134A, so this seems misinformed by autozone galore. It’s the AC oil that’s relevant for these models gen2 and gen3, it needs to be ND-11 (expensive) or a POE 80 (POE 100 not preferred since different viscosity than ND11)….
  10. rjparker
    10,227
    6,386
    The best r134a for a gen3 top off is usually the cheapest can without any oil, dye or sealant.
    Good advice here
    Refrigerant Replacement | Page 6 | PriusChat
    For best performance without repairing the leak, vacuum, purge gauge hoses with refrigerant and weigh in the refrigerant. If not weighing in, its best to slightly undercharge based on the sight glass.
    Today's self sealing cans need a hose that does not pierce the can. Throw grandpas piercing hose away.
  11. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Always avoid any additives and add dye yourself if needed, it’s very cheap. Straight up R134a is the best but if you have replaced any components that can hold oil, add some Edgar Allan Poe80.
    @rjparker it seems you are not commenting on why autoZ would not recommend this can for electrical compressors? Please enlighten me.
  12. rjparker
    10,227
    6,386
    Additives beyond pure R134a has to be the answer. All recent hydrids and most cars since ~2017 don't use R134a.
    With that said, trusting anything Autozone, their code scanners or employees say is foolish. But in this case the customer could be foolish if they ignore the warning.
    Gourockian likes this.
  13. ASRDogman
    ASRDogman Senior Member
    7,647
    3,936
    It is always best to use what the maker of the item is, tells you what to use.
    They designed it....
  14. Gourockian
    75
    New Port Richey
    I'm well aware of the need to use ND-11 oil with the Gen 2 and 3 models and not the normal PAG oil that is used in many belt driven compressors.
    My concern is that if the supplier clearly states that this product is "Not for Hybrid vehicles with electrical driven compressors", why would anyone in their right mind even consider using it for one of these vehicles.
    Unfortunately, Autozone's website only shows one view of the can so it is not possible to check online to see if it contains any oil or other additive. Apart from that, a 12-oz can of straight R134a is cheaper at Walmart so, better to play safe instead of taking chances.
  15. Gourockian
    75
    New Port Richey
    Instead of getting rid of it, it could still be used with one of these.
  16. Gourockian
    75
    New Port Richey
    I'm not sure why the link didn't show but here's another one.
    A/C Pro A/C Charging Adapter Kit DVA-1
  17. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    But it’s much more likely they have a DB error that states this. It’s R134A that is recommended for the gen2 and 3, so we don’t want to confuse folks looking for answers here with invalid AutoZone info. Nothing indicates this can has additives. It only indicates they have a bug.
  18. Gourockian
    75
    New Port Richey
    Whatever!
  19. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    That’s the spirit.
