Gen 2 Snow Tires on Prius V 5
Discussion in 'Prius v Accessories and Modifications' started by MandaPanda, Dec 2, 2025.
  1. MandaPanda
    MandaPanda Junior Member
    The Commonwealth
    2014 Prius v wagon
    We just purchased a Prius V five (The one with the moon roof) after losing our 08 Gen 2 Prius in a car accident.
    Even though our Gen 2 was a touring model with the 16 inch wheels, we were able to use a set of 15 inch snow tires that my dad had used on the previous. Prius was 15 inch wheels. We still have them in our basement.
    Could we get them put on our V? would there be any drawbacks?
  2. MandaPanda
    The Commonwealth
    2014 Prius v wagon
    Year is 14 (built in late 13, if it matters)
  3. rjparker
    10,335
    6,467
    The gen3 v hole pattern is different from a gen3 hatchback or a gen2.
    Prius v has a wheel bolt pattern of
    5x114.3mm
    Many Camry wheels have the Prius v bolt pattern.
    Gen2 and Gen3 Hatchback
    The Prius hatchback has a 5 x 100mm bolt pattern
    Wheel-Size.com :: Global Wheel Fitment Database For Vehicles
    MandaPanda and Air_Boss like this.
  4. MandaPanda
    The Commonwealth
    2014 Prius v wagon
    Darn! And thank you so much for helping us out. Looks like we’ll be shopping for snow tires (and wheels).
  5. Leadfoot J. McCoalroller
    8,120
    7,613
    Pennsylvania
    2018 Prius c
    I think it is important to note that you'd only want to re-use the wheels anyway.
    The rubber compounds that all tires are made of continue to harden after manufacturing.
    Snow tires are made from an extra-soft compound. This is both why they work so well on snow and ice, and why they aren't recommended for use in warmer temperatures- they'll wear down very quickly in the heat.
    But once they're more than say, 6 years old? They've lost all that softness that made them so good in the first place. Not worth the effort for a false sense of security.
  6. Mendel Leisk
    41,739
    Also, gen 2 spec tires are significantly smaller outside diameter. Here I've plugged in the smaller tire size for both the gen 2 Prius and Prius v. Worth noting, while both vehicles have optional larger diameter rims, the outside diameters of the tires will not vary significantly. Gen 2 on the left:
    From here:
    Tire Size Comparison
    Air_Boss likes this.
