Coolant loss- any connection to a fuel injector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Dec 2, 2025.
  1. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Ah, but also a measurement of compressors capacity is pressure, so that’s air volume/time unit (normally one minute), that would end up at apx 4.5 bar/65 PSI (minute volume). Correct? That’s good enough.
    indel likes this.
  2. indel
    indel Member
    261
    83
    Northwest Indiana
    Most people who are cleaning the coolers are first using some kind of solvent, then blowing it out with a pressure washer before finally spraying air to make the passages completely dry. Merv and many others have used wires to disengage the carbonized dust from the passages. To date I have not found a wire that works for me.
    In the used JDM cooler I bought from ebay, every little passage has a slanted metal plate inside it dividing the the passage into two triangles. I do not know if that's the standard design but it makes it harder to insert wires in there. I will report back once I receive my brand new cooler today.
  3. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Yep, I am aware and also considered this. But as soon as you add liquid to this ash it’s much harder to blow out (with air).
  4. rjparker
    10,404
    6,519
    The cooler can be clogged with a hard sticky material if the engine is burning oil. Otherwise it is fine. A good gen3 engine will show no observable oil loss in 5k miles. An oil burner can be fixed with pistons and rings demonstrated thousands of times under warranty.
    A wire chucked on a drill does work on the serious sticky oil residue.
    priumium likes this.
  5. indel
    indel Member
    261
    83
    Northwest Indiana
    Can you provide the gauge or example of the type of wire you used for this purpose? A link would be very helpful.
  6. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    A good G3 engine will therefore not have oily residue in the EGR cooler.
  7. Mendel Leisk
    41,815
    Guess I’m an outlier: dipstick never budges, and when I clean the EGR valve, cooler, pipe and the intake manifold (twice now), the “ash” is closer to anthracite coal, lol.
  8. indel
    indel Member
    261
    83
    Northwest Indiana
    My 2012 Two has 142.5K miles. I bought it just a little over 1K miles ago. So far, my oil level has not dropped any at all and I am hoping the streak continues.
    priumium and Mendel Leisk like this.
  9. Mendel Leisk
    41,815
    Yeah, until partway through model year 2014, they’ve got low tension piston rings. Kinda like being born with a heart defect.
  10. rjparker
    10,404
    6,519
    I did it many moons ago (maybe 120 moons kemosahbee) but it was something like a thin clothes hanger wire - stiff but still flexible enough to make a slight bend.
    Chucked in a drill, you literally bore through the gunk. Start with a short piece and progress to 2/3 length.
    This was after several days in a professional parts cleaner failed and we simply bought a new one.
    The clogged cooler was later cleaned by rotating wire followed by solvents over many more days as a passion project (it will not and did not defeat me!).
    It found a new home on the next gen3 needing one - recovering most of the new cooler's cost. The cleaning labor was a sunk cost, something most shops can't afford to charge for and keep customers when a new one is 1.5 hours labor and much more efficient. Plus no lye in the eye.
    #30 rjparker, Dec 5, 2025
  11. indel
    indel Member
    261
    83
    Northwest Indiana
    Do you have to remove the head to
    I haven't used that type of clothes hanger in a long time, but if memory serves right, those wires were pretty thick. I did have some luck inserting a picture frame hanging wire (the thinnest I could find) in there, but it bends too easily and it might break if I try rotating it inside. That would be a terrible thing to happen.
  12. Mendel Leisk
    41,815
    I found regular cable TV wire about the right gauge. There's a "heavier duty" version, and it was slightly too thick.
  13. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Hmm, what is that? Sounds dry to me.
    If the deposits are dry thru the entire passage into the intake, then the PCV system works as intended indeed.
    #33 priumium, Dec 6, 2025
  14. C Clay
    C Clay Member
    356
    69
    Lexington, KY
    thanks for the discussions- Here's where I am at today- many cold damp days here, and I work for a large company that starts with an A- I'm putting in about 70+ hours a week and 12-15 hours of traveling. Not much time for Prius working until I get more time and/or the sun shines.
    Fuel System Cleaner 500 miles/7 days ago and no death rattle .... until
    I go to add Antifreeze and after reading the manual- fill the reservoir up to the B mark and let it run in maintenance mode. It knocked on me this time. Isn't there a relationship to the pressure when you release the cap/leave it on/off and these hard knocks upon starting? I know some seem to think you can take the o ring off or something and it eliminates hard starts. I don't necessarily subscribe to this thought process, just asking the question. How much antifreeze was needed? Maybe 1 inch. I've never added any that I can think of this year.
    This car doesn't burn any oil by the way, nothing appreciable. I no longer have to add any between 5000 miles changes.
    I'm kind of in a holding pattern- but if it were August, I'd really like to look at cleaning the manifold and looking at the EGR cooler. As far as the EGR test mentioned above with the spatula - if this isn't knocking consistently, I don't think that would prove out any test would it?
  15. Mendel Leisk
    41,815
    Was this just a top-up? If so, no reason to go through all that rigamarole. Is the level in reservoir dropping, relatively quickly?
    The knocking may be the head gasket letting go, again. Cleaning the EGR is always good, but don't expect it to "heal" the head gasket. I'd do a borescope inspection of the cylinders, looking for coolant.
    C Clay likes this.
  16. C Clay
    C Clay Member
    356
    69
    Lexington, KY
    Is it dropping quickly, I don’t really know. Coolant is one of those that things I don’t check until there is an issue. I guess it probably dropped an inch during the week of hard starts.
  17. indel
    indel Member
    261
    83
    Northwest Indiana
    Place a cardboard under your engine bay overnight and see if you find any coolant in the morning. If you don't, it may be leaking into the cylinders. You can also bring it to a competent mechanic to check the cylinders for coolant presence with a boroscope. It may be a couple of hours of labor. So it's the least time consuming and least expensive thing to do before you go through the trouble of cleaning up the EGR system. Don't get me wrong, the EGR system does need to be cleaned but if your engine is shot, you have bigger fish to fry first.
  18. Mendel Leisk
    41,815
    That sounds like head gasket failure.
    C Clay likes this.
  19. C Clay
    C Clay Member
    356
    69
    Lexington, KY
    Remind me of the scenario, can you have head gasket, failure, coolant seeping through and it not starting hard? If so, I assume you would see white smoke coming from the exhaust.?
  20. BiomedO1
    4,003
    2,103
    SacTown, Ca
    You can see white smoke coming out of your exhaust on any cold morning - condensation in your exhaust pipe evaporating. Not a valid test. Do you expect to see a tea kettle to blow white smoke all the time? Because that's actually actively boiling a few liters of water. Your losing about an inch in your reservoir out of 1.75 gallon total volume, how much white smoke are you expecting???? You can also say that your oil isn't mixing with your coolant, so therefore your don't have a blown head gasket too....
    Just my two cents.....
