Coolant loss- any connection to a fuel injector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Dec 2, 2025 at 6:06 AM.
  1. priumium
    priumium Member
    161
    37
    Sweden
    Ah, but also a measurement of compressors capacity is pressure, so that’s air volume/time unit (normally one minute), that would end up at apx 4.5 bar/65 PSI (minute volume). Correct? That’s good enough.
    indel likes this.
  2. indel
    indel Member
    84
    28
    Northwest Indiana
    Most people who are cleaning the coolers are first using some kind of solvent, then blowing it out with a pressure washer before finally spraying air to make the passages completely dry. Merv and many others have used wires to disengage the carbonized dust from the passages. To date I have not found a wire that works for me.
    In the used JDM cooler I bought from ebay, every little passage has a slanted metal plate inside it dividing the the passage into two triangles. I do not know if that's the standard design but it makes it harder to insert wires in there. I will report back once I receive my brand new cooler today.
  3. priumium
    priumium Member
    161
    37
    Sweden
    Yep, I am aware and also considered this. But as soon as you add liquid to this ash it’s much harder to blow out (with air).
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,135
    6,297
    Texas Hill Country
    The cooler can be clogged with a hard sticky material if the engine is burning oil. Otherwise it is fine. A good gen3 engine will show no observable oil loss in 5k miles. An oil burner can be fixed with pistons and rings demonstrated thousands of times under warranty.
    A wire chucked on a drill does work on the serious sticky oil residue.
    priumium likes this.
  5. indel
    indel Member
    84
    28
    Northwest Indiana
    Can you provide the gauge or example of the type of wire you used for this purpose? A link would be very helpful.
  6. priumium
    priumium Member
    161
    37
    Sweden
    A good G3 engine will therefore not have oily residue in the EGR cooler.
  7. Mendel Leisk
    41,405
    Guess I’m an outlier: dipstick never budges, and when I clean the EGR valve, cooler, pipe and the intake manifold (twice now), the “ash” is closer to anthracite coal, lol.
  8. indel
    indel Member
    84
    28
    Northwest Indiana
    My 2012 Two has 142.5K miles. I bought it just a little over 1K miles ago. So far, my oil level has not dropped any at all and I am hoping the streak continues.
  9. Mendel Leisk
    41,405
    Yeah, until partway through model year 2014, they’ve got low tension piston rings. Kinda like being born with a heart defect.
  10. rjparker
    10,135
    6,297
    Texas Hill Country
    I did it many moons ago (maybe 120 moons kemosahbee) but it was something like a thin clothes hanger wire - stiff but still flexible enough to make a slight bend.
    Chucked in a drill, you literally bore through the gunk. Start with a short piece and progress to 2/3 length.
    This was after several days in a professional parts cleaner failed and we simply bought a new one.
    The clogged cooler was later cleaned by rotating wire followed by solvents over many more days as a passion project (it will not and did not defeat me!).
    It found a new home on the next gen3 needing one - recovering most of the new cooler's cost. The cleaning labor was a sunk cost, something most shops can't afford to charge for and keep customers when a new one is 1.5 hours labor and much more efficient. Plus no lye in the eye.
    #30 rjparker, Dec 5, 2025 at 3:10 PM
  11. indel
    indel Member
    84
    28
    Northwest Indiana
    Do you have to remove the head to
    I haven't used that type of clothes hanger in a long time, but if memory serves right, those wires were pretty thick. I did have some luck inserting a picture frame hanging wire (the thinnest I could find) in there, but it bends too easily and it might break if I try rotating it inside. That would be a terrible thing to happen.
