2006 Prius A/C Temperature Stuck?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daveyedgar, Dec 5, 2025.
  1. daveyedgar
    daveyedgar Junior Member
    Tampa
    When I camp in my prius and have it running overnight the a/c is blowing cold through the center vents
    ok. I have the auto off. It's in Florida so it is hot during the day and cold at night right now. Once I set it to
    center vents, max blower, max low temp it works fine, until I wake up the next morning and the car is warm with cool but not cold air barely coming out of the center vents as they were originally set. The blower fan is still blowing on max but the air flow seems restricted or blocked somehow.
    Its as if the temperature is stuck around 70 for example. I should be able to blow ice cold air fully through the center vents even if it is cold outside.
    I cycle through the different modes and blends and toggle the auto several times
    to try to unstick it, but it doesn't work.
    It seems like both the blend and mode door actuators are working since during
    the day when it's hot out I can cycle through the different modes and also can get it to go to heat and back to cold.
    Eventually later in the morning as I start driving the cold air finally comes
    back and blows strong. Playing with the buttons doesn't seem to have an effect.
    Have any of you experienced this? Would like some input before I start pulling stuff apart and throwing
    parts at it.
  2. Tombukt2
    13,292
    2,398
    Maybe you're evaporator core is freezing up and you're trying to blow thru a brick of ice .?
    Danno5060 and BiomedO1 like this.
  3. BiomedO1
    4,020
    2,109
    SacTown, Ca
    There should be a sensor that prevents that, but running in manual mode with max. fan speed; you never know. You on recirculate or fresh air? How does your interior air filter look? You need to take a deep dive with techstream to see what all your sensors are seeing to nail-down the problem.
    Your radiator fans may not be turning, so it can't remove the heat from the R134. It works while the car is moving, because your pushing air through the condenser.
    Good Luck.....
    #3 BiomedO1, Dec 5, 2025
  4. daveyedgar
    Tampa
    That might be a possibility because I noticed that at the bottom of the heater box behind the center console I pulled the floor carpet aside and noticed some droplets of condensation that were frozen. How could I prevent that?
  5. daveyedgar
    Tampa
    Thanks, I leave it on fresh air overnight. The cabin filter is new. I'll check the radiator fans.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    What happens if you set the temperature to 68F, or basically anything other than MAX COLD?
    You might want to verify that the drain hose from the evaporator core is flowing normally. It runs under the passenger side foot well carpet.
  7. daveyedgar
    Tampa
    Thanks, good idea I'll try setting the temp like you said. I cleaned the drain tube last september, I'll check it again.
  8. Tombukt2
    13,292
    2,398
    Manual flex temp probe up in drain hole will touch the EVAP core need about 14 inches of probe . Not too hard to make happen. Be like freezing with systems off because it's a block . Blow hair dryer not heat gun into floor or foot vent watch water roll out of drain tube . Melting .
    BiomedO1 likes this.
  9. BiomedO1
    4,020
    2,109
    SacTown, Ca
    ^ Yep; if everything is working properly - the coils should be at or just above 32F to prevent the block ice effect.
    IMHO; you really don't need to do the hair dryer thing. Just turn-off the AC compressor and keep your fan on; it should defrost naturally and drain out the bottom.
    I know some AC mechanics that'll disable the coil temperature limiter, because customers complain that the unit doesn't get cold enough. That's what leads to the ice block forming; the compressor doesn't cycle-off when the coils gets too cold.
    Just my two cents.....
  10. Tombukt2
    13,292
    2,398
    I think your Ace evap temps are going to be in the 40s not really 32 maybe out at the gat hose or line coming off compressor sometimes you see the beginning of freezing they're same at you're house . Lotsa sweating and moisture rt they're. At least that's what I've experienced.
  11. daveyedgar
    Tampa
    Well after keeping an eye on it for a while the symptoms recurred last night and this morning while at a stop light I heard a crumpling sound behind the center of the dash. Immediately after the vents blew strong cold air. I'm pretty convinced that was ice falling off the evap core on to the plastic ac air box.
    If that's the case, any ideas on why it is freezing and how to fix it? According to professor google, it could be the expansion valve or temp sensor. Would love to get input on prius owners.
    If I have to go through the trouble of removing it for inspection I'm just going to replace the core and valve. Probably do the blend and mode actuators while I'm at it.
    2006 @204303 miles.
  12. Tombukt2
    13,292
    2,398
    You connect gauges to the high and low side of the system and then you watch the gauges while the system running . When freezing starts to take place gauges start to act up gas and vapor no circulate properly etc . You can Google videos about people using gauges on HVAC systems to pinpoint freezing non-moving gas and vapor and so on . The expansion valve opens and closes as needed for processes to happen they can stick etc . Those parts are 20 yrs old now . Are the gas levels proper. Charge level can make some of this go on . I would check all the easy stuff first see what the system looks like with gauges connected and running Ive seen diagnostic setups to have gauges visible whilst moving the vehicle etc . I would think I would want to make sure that charge.. air content . Liquid or water . Desdicant . Is all up to snuff before I start doing $3,000 worth of work and ripping my Evsp box out. At least in my case personally so far and about nine of these cars I have not had to remove the EVAP case all AC have been flawless once correctly setup and sealed . And filled properly so far . That's one thing I will not live without is my AC it will become a winter car directly without it.
  13. Tombukt2
    13,292
    2,398
    Ptem0 sensor in cabin or elsewhere is tests le easily.stuff in EVAP box not so much .if folks have pumped crap into system think stop leak .
  14. pasadena_commut
    2,776
    831
    Southern California
    The valve is part of the core. Stupid design. For gen 3 they moved the valve so that it is possible to replace the valve from the engine compartment. Not perfect access, but much less work than taking the dashboard and then evaporator core out to reach it. (Although, that is still apparently what Toyota service manuals recommend.)
    - YouTube
    None of which is going to help on the OP's gen 2 though.
    If it was mine I would:
    1. Check (that it is there, not damaged) and replace the cabin air filter.
    2. Use a Toyota evaporator core cleaning kit. It squirts cleaner up into the evaporator, washes off any dirt in there, and then the now dirty fluid drips back down through the drain hose.
    If that doesn't fix it, take it to an A/C shop and have them evacuate, dry, replace the dryer sock, and refill. The goal being to confirm that the charge was/is correct and that the system is dry. See for instance the discussion here:
    AC evaporator and low side line freezes up all the way to compressor,stops cooling.any ideas? | PriusChat
    The blower moves air well when it isn't frozen up? If the air flow is compromised the evaporator will freeze up in a humid environment. I don't know what the humidity is like there now, but most of the year it is pretty damp in Florida.
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,080
    1,995
    NJ-USA
    Me, I would use a "Prius capable" scantool to watch what the evaporator core temperature sensor reads - both when the system works and when it acts up. It sure sounds like the core is freezing.
    Whatever happens, if the core gets too cold, then the ecu should slow the compressor or turn it off.
    If it's icing but the sensor shows something like 40°, then that would be a problem (maybe the sensor is in the wrong position or it's defective).
  16. daveyedgar
    Tampa
    Thanks for all the help!
    The cabin filter isn't too bad but I'll replace it tomorrow and see what happens.
    I performed the core cleaning through the drain line last week. The fluid came out a little brackish but not too bad, I could see through the liquid, there was a little sediment in it. I did the same thing last september and it came out pretty dirty, so there seems to be an improvement.
    The blower moves air very well when not frozen. I noticed overnight as time goes by the flow out of the vents decreases to maybe 30% even when the blower remains on high.
    I'm going through the service manual now. Any thoughts on 3 vs 4 port manifold gauge set before I buy one?
    I'm going to hook up techstream after the holidays to get some readings.
    I intend to have the system recharged and the dryer sock replaced. I want to solve this problem so I can address it at that time. I was going to have toyota evacuate the system and do the repairs myself.
  17. daveyedgar
    Tampa
    Do you think that using those rental a/c gauges from autozone just to measure the pressures on my prius cause any cross contamination?
  18. daveyedgar
    Tampa
    I was able to set up gauges on my ac system. Unfortunately I wasn't able to get techstream to work so I don't have those readings. I included screen shots.
    car is off.
    The next 4 are readings taken over a 30 minute period with the temp on low, fan high, ac on. first on fresh air then on circulate.
    this final image is when the car was shut off
    Would like any input thanks.
  19. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
  20. Tombukt2
    13,292
    2,398
    This is the United States right where this car is is gauges are us gauges? You don't have enough gas pressure to be doing much of anything with.
