Tools for Headgasket Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BeanieBoo, Dec 7, 2025.
  1. BeanieBoo
    BeanieBoo New Member
    Alabama
    Hey Prius Cult!
    I’m just a few days away from diving into my first head-gasket replacement on my 2013 Gen 3 Prius. This car’s various “adventures” are what made me realize I actually love auto mechanics — enough that I’m seriously considering a career change. I’ve spent the last few months researching everything I could get my hands on, watched all the Gasket Masters videos, and I’ve got the Haynes manual in both digital and paper form. All my parts are here and ready to go.
    Before I get started, I want to make sure I’ve got every tool I’ll need. My tool collection grows with every project, but building a full mechanic’s setup takes time and money. Once I begin, I’m not coming up for air until the head is off, sent to the machine shop, and the car is back on the road.
    If anyone has a solid “don’t start this job without these tools” list or any last-minute advice, I’d really appreciate it. I’ve got a touch of the tism, so having a clear list really helps me organize and consolidate my thoughts.
    Please and thank you!
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,006
    5,287
    Pacific Northwest, USA
    Welcome to PriusChat!
    We could really use a dedicated thread to headgasket repair. It'd be awesome if you could blow this thread up with everything you've studied because there's lots of us who have been wanting to get into doing this particular repair due to so many people needing it.
    Of course because you're new hear you'll be moderated for your first 4 or 5 comments before you can share images and links. So make comments on other posts on the site so you can get this thread going!
    Also I bet @Mendel Leisk and @chapman will help us build the ultimate thread for Gen3 headgasket repair!
    And beyond this post and this one headgasket job, you could make good money specializing in Prius repairs and working for yourself... Most shops charge so much for repairs that you can make big money working for 1/2 of what they charge.
    #2 PriusCamper, Dec 7, 2025
  3. indel
    indel Member
    267
    87
    Northwest Indiana
    Agree with @PriusCamper about a master thread on headgasket repair. The conventional wisdom I keep hearing on Priuschat about head gaskets is that it is hardly worth doing that job because of the tight tolerances that the engine was designed with. Even if you do the gasket, the problem might come back again, or the timing may be off due to decreased depth of the engine after head resurfacing, so on and so forth. I do not know how much faith to put in either of those, nor will I ever attempt to tackle this job myself having watched the GasketMasters videos.
    Nonetheless, I am rather curious about how diy this job is and if it provides long term reliability.
  4. PriusCamper
    13,006
    5,287
    I know too many people who need this job done and I keep learning about it and then something comes up that I had not yet learned and I get a little intimidated about it all yet again. I'm sure once I've done a couple of them I'll wonder why I was ever intimidated by the job, but I ain't there yet.
    indel likes this.
  5. Mendel Leisk
    41,850
    Last link in my signature is the full engine section, from the Toyota Repair Manual. (on a phone, turn it landscape to see signatures)
    Don't get misled by Gasket Master's recommendation to use a "triple-square" bit for the head bolts. The correct tool is a 10 mm double hex, which is readily available on Amazon, and likely local to you, at automotive specialty stores. Seems like it's easier to find on amazon.ca than amazon.com, but anyway, here's a direct link, for both the 8 and 10 mm drivers, from one manufacturer (CTA Tools).
    Gasket Master’s mention of Permatex Ultra Black (as a form-in-place gasket) is good though: while not what Toyota specs, it's effective, and has a much more leisurely cure time. The only downside, it's recommended to wait 24 hours before adding oil and firing it up.
    If I was in your shoes (pray I never need to do this....), I'd go for the Toyota overhaul gasket kit: it's got most every gasket, o-ring and seal you'll encounter, all genuine Toyota, plus the head gasket of course, and the head gasket has had a revision, so hopefully good for the duration. I've a hunch the original head gasket's bad rep was in fact a clogged EGR system problem, but that's for another discussion.
    The Gasket Master's videos are good, but from the perspective of a time-limited pro; you'd do well to also watch priuschat member @NutzAboutBolts’ three-part series. Which you can find linked at the bottom of first post here. All the other videos linked there invaluable as well, in particular the preceding engine and inverter water pump replacement videos.
    #5 Mendel Leisk, Dec 7, 2025
    mjoo, douglasjre, BeanieBoo and 2 others like this.
  6. rjparker
    10,437
    6,545
    IF the engine was not burning oil AND it never overheated AND the hg leak was diagnosed quickly before coolant loss AND no time was wasted for egr cleaning or new plugs, THEN the odds are the head does not need resurfacing, the block is not warped and a head gasket job might last 50k miles.
    Will a dealer do a hg job? Not likely because of comebacks and high cost. Is a Hayes manual adequate? No. Is timing a common diy fail? Yes. Can an experienced and skilled mechanic get it right the first time? Yes if they accept the job.
    douglasjre likes this.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    All the tools is listed in my video description. The job itself isn’t too bad, the first time will take the longest to figure out where everything is at, after you do this 3-5 more times, you’ll be a natural at doing this job and can finish it quickly in a couple of hours… that is if you’re just doing the minimum work.
    douglasjre, priumium and PriusCamper like this.
  8. BeanieBoo
    Alabama
    Are we also replacing inverter coolant while doing all this work? I am also replacing a bunch of parts since the car is at 120,000 at this point anyway. I cleaned the hybrid battery fan filter/ replaced. I plan to replace water pump, timing chain belt/timing chain tensioner, thermostat/thermostat housing, oil change and filter, and coolant exchange on combustion side. I got engine overhaul kit from Toyota so it included new revamped headgasket and all necessary gaskets and o rings I could ever need for this job and part replacement. My research led me to believe that Toyota's 2nd attempt at this headgasket was top notch to make up for all the issues this generation (3rd) prius had, and the kit made more financial sense than the Fel-pro headgasket and then buying indivdual gaskets and o rings. The parts I plan to reuse but clean thoroughly are the oil pan and intake manifold.
  9. BeanieBoo
    Alabama
    I am saving thousands of dollars doing it myself and it is 10000% confirmed (by Toyota dealer, master mechanic friend along with the misfiring of engine and research I personally did) to be HG issue. Toyota dealer is highway robbery and I having nothing else nice to say about them so I will take the high road out.
  10. Mendel Leisk
    41,850
    Not necessary, in other words not part and parcel of the head gasket work. Worth doing per the schedule, but I'd leave it for now.
    The timing chain will likely be fine, ditto for the timing chain tensioner, and the timing chain guides. Changing the thermostat (it's one thing, no separate housing) is a good idea, in conjunction with the water pump.
    Service limit specs for all the above are in the aforementioned Repair Manual engine excerpt, last link in my signature.
    Oy vey, I would skip that. It's form-in-place gasket sealed, and a battle to pry off I think. Let sleeping dogs lie?
    Are you getting new (Toyota) head bolts? it's worthwhile: while the old ones may be fine, still within specs, it's just one less worry if you replace.
    #10 Mendel Leisk, Dec 8, 2025
  11. PriusCamper
    13,006
    5,287
    I had a leaky oil drain plug in a PriusC once and the oil pan that's same part as many Toyota's was only like $23 online and I'm like I'll just do that... Then I got under the car and after removing all the bolts I realized I was going to have to spend more than an hour and likely cause damage removing the pan. Thanks goodness problem was quickly solved by retapping the existing threads and a new oil drain plug bolt.
  12. rjparker
    10,437
    6,545
    Agree.
    If its not broke don't fix it.
  13. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    water pump, timing chain belt/timing chain tensioner, thermostat/thermostat housing: DO NOT NEED TO BE REPLACED
  14. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    Still on the original coolant pump, though I replaced the impeller, because I dropped it and it broke.
    But it was in excellent shape, Original thermostat too. Timing chain and related parts.
    I only have 381,000 miles on it. 80,000 no the head gasket....
    PriusCamper and Mendel Leisk like this.
  15. RavenPri
    RavenPri New Member
    29
    North West California
    I am in the process of doing head gasket replacement. The nutzandboltz video is the best to do step by step. Watch the whole video (3 total) and take notes. Watch the parts which step you are on. TAKE Pictures of every step as you take apart to see orientation etc and gasket directions. Label all bolts in baggies. Take pictures of bolts. For every step there will always be another step, asterisk, fine print, see below step attached with it. It will take you way longer than you think.
    It can be done though. I would do it again on another prius, it's fairly straight forward. Just all the inconveniences take your soul. Very tight spaces to work in so hopefully you have small hands. Just need the flat dry space.
    List of tools that you will need, not a complete list.
    Torque wrench, Ratchets, 10-17mm sockets + a couple bigger both short and deep, the spline sockets, the head bolt *edit* "The correct tool is a 10 mm double hex", prybar, a car jack/stand to support engine for the drop down step, HOSE PLIERS AND WIRE CLIP PULLER TOOLS (removing hoses and wire clips are the absolute hardest and most time consuming part without), Impact gun, maybe the flywheel tool but you need to get extensions and possibly might not need. Wire brush set. Extendable pen magnet. A few good shop lights. Headlamp. Gloves. Brake cleaner, cardboard shop towels and rags. The magnetic dishes are pretty useful. There's probably a few more things.
    The parts you will need are attached. Plus the 1.25inch diameter x 3.75inch long coolant hose you probably will just cut off and 2 new hose clamps. There might be a few small things I'm missing.
    #15 RavenPri, Dec 11, 2025
    NutzAboutBolts and PriusCamper like this.
  16. indel
    indel Member
    267
    87
    Northwest Indiana
    I do not understand enough about engine rebuilds, but why not replace pistons and rings while you are doing head gasket? Or does that require further disassembly?
  17. Mendel Leisk
    41,850
    Info
    Yes it does.
    #17 Mendel Leisk, Dec 11, 2025
  18. RavenPri
    RavenPri New Member
    29
    Fixed. Thank you.
