Shudder, cylinder 3 misfire, check engine light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, Mar 6, 2019.
  1. padroo
    padroo Senior Member
    2,763
    2,252
    I see a lot of bad reviews and have not used one myself and it looks like everyone is using the same manufacturer and putting their name on it. Buyer beware!
  2. Mendel Leisk
    41,425
    The Repair manual says to torque to the spec'd value, paint a mark on the head of the bolt, then go another 90 degree, and a further 45 degrees. This doesn't seem ultra critical.
    Also, has anyone mentioned the bi-hexagonal socket driver. If you google that you'll find lots of sources, on Amazon.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    It's also a 12mm bi-hexagonal wrench, not 10mm. Don't ask me how I know this - I specifically paid $40 for the AST 10mm bi-hexagonal wrench to find out that it is the wrong size.
    Note: I used a triple-square bit in lieu of the proper bi-hexagonal. I heard they are similar but not identical. But it worked fine for me...
    m.wynn, Raytheeagle and Mendel Leisk like this.
  4. Mendel Leisk
    41,425
    You were for sure the first one removing those bolts? Grasping at straws...
    FWIW, here's a Toyota tool description and part number:
    Toyota tool: 10MM BI-HEXAGON SOCKET p/n: 09013-7C310
  5. Mendel Leisk
    41,425
    Noticed this comment, on a replacement head bolt amazon page, coroborates your experience:
  6. Groundpounder17
    104
    77
    AR
    Can anyone give me the correct number for the head bolts? I can’t find it on Camelback Toyota website.
    What about the belt and idler pulley? Do they need replacing too?
  7. Mendel Leisk
    41,425
    At about 17:50 in the video I linked (first page, post #12), he describes the head bolt socket as "number 12", which I think means 12 mm. Snap-On I think?
  8. Mendel Leisk
    41,425
    Head bolt part no's are in this tsb:
  9. Groundpounder17
    104
    77
    AR
    Thanks. I’ve added the head bolts to my cart.
    I found the part number for the Toyota wrench but it looks like 10mm and worried the head bolts will be 12mm.
    Nevermind on the serpentine belt question lol
    #49 Groundpounder17, Mar 7, 2019
  10. The Critic
    3,193
    2,333
    CA
    Mine were 90910-02166. So it may be different depending on VIN (or it was superseded); I had my parts guy look up by VIN.
  11. The Critic
    3,193
    2,333
    CA
    I am the original owner of my Prius and I have never had any head work done.
    The socket was still on my workbench. It is definitely a 12mm “XZN.” Not saying it is the correct one, but it fit securely and I was able to do the job.
    m.wynn and Raytheeagle like this.
  12. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    You probably used a 12mm triple square. The correct tool is a 10mm double hex. The angles of the points are different, buy the 12mm triple square will usually work.
    If anyone reading this would like to know, here is my recommendation:
    CTA Tools 9295 Toyota Head Bolt Wrenches –Double Hex 1/2-Inch Square Drive Set
  13. Mendel Leisk
    41,425
    Here's a pdf of triple square dimensions:
    http://www.metalnerd.com/content/assets/43/439614/Specialty_Bits_and_Drivers/triplesquaretable.pdf
    The point-to-point dimension of a M12 triple square is indicated as 11.6 mm.
    If I draw a hexagon with 10 mm face-to-face, the point-to-point dimension is 11.547
    Here's a 12mm triple square (magenta) per the pdf dims, superimposed with a bi-hex 10 mm (cyan):
    The (magenta) triple square protrudes slightly more at the points:
    That's in mm's, and jives with (11.6-11.547)/2
    There'll be some tolerance factor in the bi-hexagon, I've just drawn it 10 mm face-to-face exact.
    #53 Mendel Leisk, Mar 9, 2019
    Shig, athlete11, Patrick Wong and 5 others like this.
  14. The Critic
    3,193
    2,333
    CA
    Thanks!
    Now that makes perfect sense. Thanks for the analysis.
    Groundpounder17 and Mendel Leisk like this.
  15. working1
    working1 Active Member
    121
    112
    The "Torque Turn to Tighten" method is done to achieve a consistent clamping force. Suggest following the procedure exactly as described.
    http://www.boltscience.com/pages/a-case-study-in-torque-angle-tightening.pdf
  16. Mendel Leisk
    41,425
    I recall a while back someone mentioning that a 10 mm hex wrench fit perfectly. Obviously not the right tool, but corroborates the size/shape.
    I'd still like to understand the underlying dimension of the triple square series. An M12 for example, does it have a 12 mm dimension in some direction? You'd think so. AutoCad's good for sussing out stuff like that.
    Off-topic rambling:
    I was a draftsman and checker for years, and one thing I found frustrating was translation of measurement method. A case in point was a tunnel, and conveyor belt line, shown on Materials Handling arrangement drawing with slope of 1.1935 degrees. I went around asking everyone what was with this number; no one could come up with an explanation, recall where it came from.
    One of the Structural draftsmen wandered over, said he recalled it was 1/4" in 12" pitch, at the outset.
    #56 Mendel Leisk, Mar 10, 2019
    Groundpounder17 and The Critic like this.
  17. Groundpounder17
    104
    77
    AR
    Picked up the head
    Raytheeagle and The Critic like this.
  18. Raidin
    Raidin Active Member
    238
    183
    Houston, TX
    Had this issue and posted in other threads detailing it from other users. Turned out to be the intake manifold getting gummed up where the EGR system connects to it. Replacing the manifold solved the problem.
    Misfire and Air-fuel ratio imbalance | PriusChat
    Gshadow325 likes this.
  19. Groundpounder17
    104
    77
    AR
    I’ve been soaking parts on hot water, oxyclean and purple power. I’ve also pressure washed a lot. The intake and EGR were filthy....so was the injectors
  20. Groundpounder17
    104
    77
    AR
    Clean parts. You can see through the cooler when light is in the background, but I still haven’t got that broken wire out
